I just brought a new laptop and it will not connect to my home wireless system. i no it works because i can use it on other wireless routers, just not mine. it keeps coming up with 'can not connect to netgear'
    Problem Solver:
  • 9 Answers
Give it the same IP address range of your Home Wireless network manually
Posted on Apr 23, 2008
Cant connect to d-link DIR-615 wirelessly, can someone help me?
What is the operating system on your laptop?
Can you access the Internet if you connect the computer to the router with the Ethernet cable?
If the wired connection is working then it must be the problem with the wireless network.
If the wired connection is also not working then you may need to reset and reconfigure the router.
If only wireless is not working then you can try creating a new wireless network and then connect your laptop to the new wireless netwok.
I can suggest you a website which may help you for Home network connection.
May 20, 2012 | D-Link DIR-615 Wireless Router
My new laptop doesn't work
To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Mar 12, 2012 | Samsung Computers & Internet
I am trying to add a new mac ip address to my wireless router i started with 1 pc then brought a laptop and a wireless d-link router they work fine i just brought home another pc it has a card put through...
Please follow the steps mentioned below on the Computer where the internet connection is working normally and check if the issue is resolved.
  • Please type "http://192.168.0.1" into the address bar, then hit "Enter" or "Return."
  • Please Use "Admin" as the user name and leave the password blank when the login screen appears.
  • Please click on Wireless, enter the Wireless SSID name (name for the Network) and under Security, select the Security type and type the Security Key.
  • Save the settings and try to connect to Wireless on the Computer having the issue.
  • It will ask for the Security Key, enter the Security Key provided during the Wireless setup.
This should resolve the issue.
If the issue is not resolved, reset the Router to factory settings and then try connecting.
Please try to locate the Reset button near the Ethernet ports and press for 10 seconds.
Good Luck!!!!
Please let me know if you require further assistance.
Thank you for contacting.
Jun 23, 2010 | D-Link SWT DSL-504T ADSL MODEM with 4...
Computer does not connect
NEW LAPTOP? Noticed a lot of post for same Laptop as same time.
If try to use wireless - you need to set-up wireless part of router and wireless part of laptop (Wireless Software).
Setup your network same it is on the PC.
Use Network setup wizard, if not know how in system manager, in the control panel.
Network Name is same on both, MYHOUSE is good.
The only thing different should be NAME, like SYS02,
PC would be SYS01, and IPaddress ( first 3 sections same as PC - Last section is indivual system - example follows:
PC = 192.168.1.40 then LT = 192.168.1.41
Suggest you hard wire laptop to router to verify network connection then work on wireless connection setup after you get connected thru hard line.
Mar 17, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
When I use my wireless land line phone I lose my Internet connection with my laptop computer. I have a Dynex wireless G router and the number on the back is 7J29A. Is there anything I can do to fix this...
Your wireless router can be configured to use different "channels." Each channel is a range of frequencies (around 2.4GHz) which is also what your phone uses. By default most wireless routers are usually set to channel #8. Change it to channel 1 or channel 2. If that doesn't work you need a different wireless router or phone, so the frequencies won't match.
Feb 13, 2010 | Dynex Computers & Internet
New computer cannot connect to wireless
is there anything interfering with the signal? such as Tv senders?
Also there could be problems with youre router, whats the router make/model?
have you checked if the wireless radio is on? also if its discoverable?
Sep 09, 2009 | Computers & Internet
ZyXeL P320W Won't connect to internet
check weather urwireless zero configuration is disable go to the my computer right in that manage in the manage go to the services in that go to the services in that one service is there in down wireless zero configuration just start it if already start just go for the restart
Mar 28, 2009 | Zyxel Prestige 320W Wireless Firewall...
Wireless connection problems
How bout setting ur mom's laptop to remove all wireless connection history and then try to make new connection to the router at her home. It also recommended to see from the router
administrative tool is your mom's laptop detected? no kind of blocklist applied in the router? Hope it helps :)
Dec 18, 2008 | D-Link DI 514 Wireless Router (DI-514)
I just bought a used powerbook g4 laptop. It worked great and I used it at work to connect wirelessly to the internet. I brought it home and cannot get it to connect to my wireless network. I have a belkin...
You could try changing the security. Some of the older laptops have trouble with the new WPA2 security. Use WEP and you should be OK if this is the problem. Good luck TT
Dec 13, 2008 | Apple PowerBook G4 Mac Notebook
Wireless with no cable to wireless laptop
this is just the first setup step for you to access the router interface page to setup your wireless network name or SSID, encryption type, encryption key, etc ....
Jul 04, 2008 | Computers & Internet
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
