Question about Bosch Dishwashers
I have a BOSCH 8280 dishwasher which at the end of its cycle still has soapy water in the bottom of the machine. The dishes, and especially the cutlery, are left smeared and looking unfinished. I lifted out and cleaned the filter in the floor of the machine but the water still doesn't drain away. Are there any other filters etc which may be causing the problem? Any ideas. Thanks.
There is a float, which controls water level, that caused this draining problem.
Lift out the main filter assembly in the floor of the dishwasher.
You can now see a small cover, positioned at the front right of the area normally covered by the filter assembly.
Click this small cover off. You should now be able to push the small float out (upwards) with your finger.
Clean the float, removing any scale or other gunge which is on it,
Refit (reverse of the remove instructions) and all should now be functioning correctly.
Posted on May 03, 2008
Bosch Model shu9925uc/u12 not draining throughout cycle. Dirty, soapy water left in bottom of dishwasher at end of cycle. Help!
ensure filter in bottom of machine is not blocked. if clear
suspect blocked pipe or defective evacuation pump.
i hope this was helpful
Dec 12, 2010 | Bosch SHU9925UC Built-in Dishwasher
I ran a load of dishes and the soapy water leaked out on the floor. The dishes were done, but there was standing water in the bottom of the dishwasher. Do I need a repair man?
Someone put dish soap in your machine. Put some ... SOME ... salt in your machine and run it empty - turn off the heaters for this cycle.
If you are CERTAIN THIS IS NOT THE CASE, maybe you should call the repair guy in your area.
Mar 26, 2010 | GE Nautilus 24" Built-in Dishwasher
Bosch dishwasher is not draining all the water at end of cycle. In the bottom of the dishwasher under the mesh trap there is about a cup of water remaining after each cycle.
This is normal with a Bosch. They don't really vent out when they heat, and use a type of evaporation technology to dry the dishes. Best bet is to make sure first that the filter in the bottom is clean, (the little circle thingy on the bottom, turn it a quarter turn and pull it out, run it under cool water till it's clear, then put it back in the same way.) If the water is bothering you or is beginning to make a bit of a smell in there, leave the door cracked a little after you empty the dishes out. unfortunately though, it'll always leave water in the bottom. European technology.
Sep 06, 2009 | Bosch Dishwashers
Water standing at the end of the cycle in my Bosch dish washer
where is the water is it visible above the filter plate or is it in the bottom of the sump
if its in the bottom of the sump thats normal it will always leave water in the sump
Mar 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishes are not clean due to insufficient water. Arms are clean, strainer is clean, water supply is OK,some soap is still in opened dispenser
Disassembled solenoid, found plugged inline strainer (caused by water shut-down in building to replace recirc. pump) Pulled and flushed filter basket, problem solved. Solenoid must be removed to access filter which is in sol. body. I hope this can help anyone who does'nt have a tech manual or flow diagram.
Mar 29, 2008 | Bosch 24 in. SHU66C05 Stainless Steel...
Dishes are not coming out fully clean
first if the pump is running and you can hear it washing it should clean now hot water cleans dishes not the washer the hotter the better at least 130-135 degrees modern dish washers use less water than older models so if you don't get the water as hot as you can stand it at the sink before you turn the washer on you can fill it with cold water second its important that you use jet dry and if your dishes aren't dry at the end of the cycle then on most washers you can turn the disp up for more hope that helps let me know
Dec 01, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Dihes not clean
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
HElp Dishes not coming clean
Dishwasher not cleaning dishes. Casade cleaner not disolved.???
Dishwashers Logo
88 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
