Problem with rundell.exe and ntvdm.exe
dear mewms.
I am using windows2003(vistacapable)& ie-7,this is office p.c,
My problem is-
Fewdays b4 I had got some virus-(funnyusscandal,killer.exe,lsass.exe,sms.exe,renounce.exe..and some more)
At that time I was using avg7.0,but it had not helped me,
Then I uninstalled avg gone to macafee,it had found all the viruses,but ti cant delite.
The virus still tried to attack my p.c,after 4days the macafee was automatically disabled.
Then I uninstalled then installed for several times but still it was like that,
Then I uninstalled it compleately and gone for for kaspersky,but still
There was a button of macfee in my toolbar,
Kaspersky helped me to clean all the files which was attaked by this virus
except one and that was-Win32.injectpath.exe,any way after somedays I had delited that..
after that my pc was running cool,Then one day when I restarted my pc..
I found that somany black blank peges with haeding c:\programs\(admin name)-1\...Adobe\Rundell.exe.
It was being opening one by one I cant close that or open anyother application,
I had restarted again and again but stil it comes…
In between that it was showing that ntvdm.exe failed to installation.
Then I gone>taskmaneger>application>endtask,but still it was opening one by one..,
Then I gone>taskmaneger>process>clicked Rundel.exe >end process.
After that all the problems was solved for a while,
But now my realheadace is-
I cant see anything when I click mouse until I dragdown,and and after dragging the words are being found but,
Gaps inbetween them,and also some times mouse is not working well sometimes,
Display performance is being too bad..,
So now I pray for you give me ramedy for this..,
I was knowing the password of admin,bt I had forgot that now..,
So pls give me a solution..,I cant sleepwell,and also I had not
Restarted/shutdown my pc after that,
With prayers,
Jai..
Ntvdm.exe
Posted on Oct 23, 2008
    Genius:
  • 1,027 Answers
AvastFREE
Free antivirus select your language and country, download and open, select run a boot time scan restart.
After the unit is virus free we'll work on the next problem, but rundll errors generally occur when infected by malware or trojans.
Posted on Apr 23, 2008
The ntvdm cpu has encountered an illegal instruction
I took this from another web site:
Michael Chiew said:
What did you do before this happened? What were your last deeds on the machine before the pop-up appeared?
I think what you're referring to is NTVDM CPU, not NTDVM CPU. Am I correct?
What do you know about 16-bit and 32-bit applications? Well, 16-bit applications are those that must work within the DOS (Disk Operating System) environment, a real-mode arena. NTVDM stands for NT Virtual Dos Machine.
In Windows XP, as in Windows 2000, or Windows 98, there are 16-bit and 32-bit environments (real mode and protected mode respectively).
Windows XP can only operate in 32-bit mode. All 16-bit applications must work within its own theatre of operation, typically, the first MB of physical memory (ram). Conversely, 32-bit applications must function above the first MB memory line. If either of these applications happens to slip into "alien" territory, you get an error message like "something" has encounter an illegal instruction. In other words, the wayward application is trying to slip by the immigration checkpoint.
In your case, updatemgr.exe (I suspect updatemgr.exe is a 32-bit application) has in all likelihood wondered into the 16-bit arena. Hence, NTVDM CPU issues that warning.
Why do you continue to get the message. It's because updatemgr.exe incessantly misbehaves itself on start-up, always trying to load itself into a particular memory address where it is not welcome. Why the persistence? Updatemgr.exe has gone bonkers. It is either corrupted or damaged.
On the other hand, one cannot discount the possibility that NTVDM (NTVDM.EXE) is corrupted or damaged. So your problem lies with either updatemgr.exe or NTVDM.EXE, or both.
There are 2 things you could do.
First, establish who owns updatemgr.exe, Microsoft or some third-party owner. Second, rename updatemgr.exe and see whether the message goes away.
To establish ownership (and the function of updatemgr.exe), do a search for the file.
Click START, select FIND. In the FIND dialog box, type: updatemgr.exe. See the directory in which the file has lodged. In Windows Explorer, get to the file, right-click on it, select PROPERTIES. Who owns it? Is there an indication of its function.
Next, rename the file. Right-click it, select RENAME and rename it to, say, updatemgr.old. RESTART your computer. Do you still get the error message. Not likely.
To clean things up a bit, perhaps it is a good idea for you to replace the current NTVDM.EXE with a new copy. Find out where NTVDM.EXE is. Then, click START, select RUN. Type in the RUN dialog box SFC to run the System File Checker. Insert your OS CD, follow the prompts, extract a copy of NTVDM.EXE and send it to its place of residence. Of course, you should also replace a copy of updatemgr.exe.
That should eliminate your problem for good.
Dec 25, 2008 | Microsoft Windows XP Home Edition
Ntvdm.exe
boot to safe-mode - goto start then run and type msconfig -
Within Msconfig you should see a startup tab. Look in there and remove or uncheck all that appear to be using ntvdm.exe
Also check in start, programs, startup, remove anything there as well.
Let me know if that does not help.
G'luck
Oct 23, 2008 | Computers & Internet
dear mewms. I am using windows2003(vistacapable)& ie-7,this is office p.c, My problem is- Fewdays b4 I had got some virus-(funnyusscandal,killer.exe,lsass.exe,sms.exe,renounce.exe..and some more) At that time I was using avg7.0,but it had not helped me, Then I uninstalled avg... Read more
Jul 31, 2008 | IBM ThinkPad T60 Notebook
Need ur valuable remedy
It is a virus definitely. I have a friend who had the exact same problem with Vista on his Sony Vaio laptop. Lucky for him it was under warranty, and he was able to get it replaced. It is definitely a virus. Mozilla doesnt shopup and IE7 having problems connecting to any site.
I recommend that you try this online utility to scan for malware, virus, adware, etc:
http://housecall65.trendmicro.com/
I generally run my antivirus and Syware remover software on a daily basis, and thought my system was clean. However, I chanced upon this site and simply did a scan (its FREE!!) and it found 2 trojans, 3 malware and a host of other stuff. I really recommend you try it..its FREE after all :)
If that doesnt resolve your issue, I recommend doing a system restore. there is no other way.
Hope you rate this solution as Fixya. I would greatly appreciate your show of gratitude.
Cheers!
IrishDruid
May 06, 2008 | Computers & Internet
I need your valuable help
Cheers!
IrishDruid
Please help me please...
Hi friend,
Yes it is a virus. do one thing do a system restrore.But take all the backup first because once you do a system restore it will restore you PC to earlier time and all the data will erased.to do a system restore go to start>programs>all accessories>system tools>system information.
If you don't want to do a system restore then just remove the firefox and run a virus scan.Kaspersky is waste use bit defender and spyysweeper both to remove all the viruses.
Goodluck..
Please help
Ok i want to know the which site is on the home page. if it is like a adult web page or any other spy ware pages. If it is spyware virus it affects the whole system and someother take whole control of your system. So if you think it is spyware you have to install the spyware antivirus There are many spyware is available like spyware doctor, adware,spyboot etc., . try it and inform
Explorer error
Cheers!
IrishDruid
Explorer error plase help
Cheers!
IrishDruid
May 06, 2008 | Microsoft Office Outlook 2003 for PC
i think there was one more virus called smss.exe with those 1 s in your system have a check ...
i think now also smss.exe file is attacked by virus in your system ...
those are trojan viruses ....
if you delete those ones also it will not go .... it will just multiply ...
if you insert pen drive in to pc then that virus will get attacked to your pen drive too ...
download some good trojan remover and then remove all viruses ...
some operating system files have got corrupted just reinstall the windows XP ...
make reinstall after removing virus only ...
or if you have the linux live cd then boot from that cd then delete those files and then reinstall XP ..
you cant install the office update from microsoft site because the microsoft office & windows you are using is not the genuine version so microsoft allows to download and apply the updates for the genuine users ....
download some good antivirus like kasperky,norton,mcaffe and install it
any doubts reply me
i am always here to assist you
thank you
bye
Apr 11, 2008 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
376 people viewed this question
David Payne
David Payne
