For that press FN key + F5 on laptop so you can see wifi and blue tooth button turn on the blue tooth. Also make sure it;';s driver installed and enable. You can check it in device manager. For that right click on my computer icon then click on property then click on device manager then you can see all drivers list make sure bluetooth device driver is listed there and enable. Let me know if you need further assistance. Thanks for using FixYa.
On the T4210, Bluetooth and Wifi can be turned on and shut off
simultaneously but toggling the switch on the left side of the tablet
pc. You can also turn on/off Bluetooth and Wifi individually by using
the Fujitsu Radio Control in the Control Panel.
There is an update for this.
What it does is that it stays in the system tray. It allows you to check
the status of your connections, toggle wifi and bluetooth connections
(separately). You can also have this program automatically on startup by putting it in the Startup folder in Start
Menu. I uploaded it to Rapidshare because the forum wouldn't accept .exe
files. Here's the link:
http://rapidshare.de/files/37279577/...oth_Toggle.exe
PRevious expert solution did not work
