Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
D52w20 cable question
So I was trying to split the cable connection outside with a splitter when a blue spark jumped out of the cable that was connected to my tv. Now my tv does not get cable channels. Did I fry that part of the tv? It does everything thing else fine. Plays dvd and xbox and I can still use my computer on it. So whats the desl?
    Sergeant:
    Champion:
  • 319 Answers
You were trying to use the wrong type splitter. You need to call your cable service to find what type would work with your TV. The spark you saw was the difference in ground potential between your TV set and cable network system. The cable company MIGHT recommend a good commercial diplexer, but they usually get real touchy about useing outside devices on their systems. It would be best to have them do the installs
Posted on Apr 23, 2008
I have no signal,what can I check?
OK Joan,, I might need more info. not getting signal could be caused from several things.. one make sure the Dish Antenna is mounted correctly, (level, and true, [one degree off on earth is like 700 miles off at the Satellite.]) check you cables and make sure they is now wire touching the center core of the coax. if the coax has splitters, connections etc outside check for the corrosion inside the threads.
make sure the coax coming into the house is connected to the right place on back of the 222k. make sure u are on the right Video stream for the HDMI. are u getting any picture showing the Dish set up or is the screen all Blue.. if it is blue try to use the remote that came with ur TV (RCA, Vizio, Phillips,,,,etc) and look for the input, source , or Antenna button and push it to match your HDMI input..
Oct 28, 2014 | DISH Network Vip 222k Hdtv Satellite...
Trying to hook tv up outside of house ran cable from box in my house wont run my tv outside can I buy hdmi ******* and have it work ? Thanks
I'm hoping you hooked the cable you ran for the outside tv to the output of the cable box and didn't make the mistake of splitting the cable that comes into the satellite box. If you take the cable that goes to your TV inside you should be able to put a splitter in it and run the TV inside as well as the one outside. If it is a long distance to the outside TV you may want to buy a powered splitter that amplifies the signal. You should also be using RG6 coaxial cable to cut down on lose.
Sep 22, 2014 | Audiovox Directv Rca Drd430rg Receiver...
Im trying to hook up two sets of passive speaker, one pair is connected to a QSC amp and the other pair is connected to a Kenwood amp. Is this possible without using another mixer like a mackie 1402.
you should be fine, you can get splitters, little adapters to split the input cables into 2, so that you can use one ouytput to run 2 channels. just hook up the output cables to the output on the numark, and use the splitter adapter to split the sound between the 2 amps.
Oct 05, 2010 | Numark CD Mix2
Horizontal lines across screen picture going fuzzy in and out and then no picture at all
A horizontal line that rolls from the bottom to the top of the tv could be a Hum Bar. This is from a bad ground either for the house electric system or for the cable system. By code, these grounds are supposed to be connected (bonded) together. In other words, the electrical interference is going through your tv instead of into the ground. Fuzzy picture is usually from low cable signal. This can be due to bad cables, connections, or splitters or problems outside with the drop (cable line outside that runs to the house). Splitters, by design, lower the cable signal (i.e. a 2 way splitter cuts the signal in half). If you have unnecessary splitters you should remove them. If you have more than about 6 or 7 tvs, you may need to add an amplifier.
Jun 25, 2010 | Vizio VF551XVT 55 in. HDTV
I use the RCA model 425 modem through Media Com. My wiring for internet enters a bedroom. Now I also want to hook up a tv using this modem. A Media Com employee suggested using a splitter. Will this work...
Theoretically you can because the purpose your cable serves is a conduit for data transmissions. Just a few cautions here. Just as in any circuit, the more the wire is spliced,split, or anything that taps into it on its way . to the modem will add resistance to the line, thus it could degrade or "slow down" your signal. There is a splitter I know mediacom haves that will help with lessening this effect.
Feb 04, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Our first tv has a booster amplifier on the coaxial cable, i have purchase a new tv and need to know what product i need to us to attached the new tv's coaxial cable too. We have used a splitter box, but...
To have good picture quality you need zero DB (decibels) for one TV without a splitter. You can use and inline amplifier for each individual TV hooked up to the cable input with a output leg connected to each TV. If your house in wired in parallel (one main input hooked up to a splitter with all of the other TV's run off of the splitter) you can use a whole house amplifier hooked up inline between the input line and the splitter. If you house is wired in series (the input goes to the first outlet, then splitter to second outlet and so forth) each splitter knocks your signal levels down 50% each splitter. Amplifier placement depends on how the home is wired and how many TV's are in the home. Splitters can be either balanced (50/50 split) or imbalanced (75/25) etc. On a two way splitter 75% of the signal goes out one leg, while 25% goes out the other (usually for FM transmissions). If you have a three way splitter the signal is divided by the number of output legs. Splitters do go bad as well (sometimes only one leg). You can also buy an amp that is multi- port (which splits the signal and amplifies in one unit/ one input and 2,3,4 outputs). Amplifiers are electric and there is no way that the splitter can interrupt the power that would take all the signal away. If you meant that it drops the signal level so the picture is unacceptable, that's different. If you have another splitter in the house try using that one, the other might be bad. All in all you can purchase most anything you need at a Radio Shack and are very inexpensive. Amps can be purchased in different gains (boost). +10db, etc. I cannot believe that your cable company is giving you such minimal signal that 1. you need an amp?, and 2. that one splitter drops your picture to nothing? Your line extenders (amps for the lines that feed your neighborhood) might have problems or need adjustment by the lazy, cheap, cable co. also. I had problems with my cable company (when I had one) my modem would not stay online. 4 months later, they diagnosed the problem and my drop (RG56 cable line that feeds my home from their tap in the cable box outside) was bad. My friend could stay online and 2 months later comcast adjusted their amps (line extenders) in the neighborhood and then he was fine. I know this is a lot to digest, but I'm just trying to draw a clear picture so you can understand it all. I hope this helps and good luck!
Nov 07, 2009 | Televison & Video
Tiling on HDTV
FIXED MY TILING PROBLEM-FINALLY !!!!
After months and months of freezing pictures and audio drop outs, I took it upon myself to see if I could fiquire this out.
In the attic I located my main cable feed was connecting to a 5-way splitter. That means my signal is being split 5 different time to go to 5 different TV jacks.
FIRST, I disconnected the main cable line from the 5-way splitter and connected it to a 2-way splitter.
SECOND, I connected the line that goes to my main TV (cable box) to the 2-way splitter.
THIRD, I connected a cable from the 2-way splitter back to the 5-way splitter.
THAT'S IT !!!!
My other TVs which don't use a cable box, never had any tiling issues, just the HDTV with the cable box. So now the signal to the HDTV is only split twice instead of 5 times.
Mark Matherne
Apr 01, 2009 | Televison & Video
Can't get PIP to work on my Samsung LCD 46"
its talking about the analog tuner in your tv. split the cable before it hits the box plug the cable strait into your tv if there is more than one coax connector on your tv you will need a second two way splitter run one into ant a and one into ant b yo will not be able to use pip and hd at same time you can only do pip with the analog tuners built into you tv
Mar 17, 2009 | Zenith Z36X31D TV
Dish satellite system with two tvs and 1 hdtv cable
What are you splitting? Coax - just split the out to tv line. A\V cables or componet cables you'll need to split all wires (a\v- yellow and at least white, red to if you want stereo. componet- green, red, blue for video and red and white for audio.
Mar 12, 2009 | Televison & Video
Splitter not splitting.
Could be...try to connect each PC by then selves straight to the jack to make sure its not ur PC. If both work and connect the splitter, if problem still exists it the splitter......trash it!
Oct 22, 2007 | Unicom Network splitter (SMJ-50108-B)
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
29 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
