Question about ASUS Computers & Internet
I bought a Asus X53S Laptop around 5 weeks ago, the button you press to release the catch for the screen to come up is broken, It took 2 mintes to work out the that button is broken and thats all, is there anywhere where I can just get a new button sent to me as ASUS won't deal with me direct by sending me a 10 pence button but want me to send the latop for repair to scotland and charge me lots when I can do it myself and the button is only a bit of plastic that I can fit, Please help
  • grant26 Aug 29, 2008
    Hi There, I'm prett sure its the same machine,thanks for replying
Is it the same as this one : Asus X53S ?
Posted on Aug 28, 2008
Hello Grant, I have seen an x53s for sale but they don't mention the ram or hard drive size or the running system, xp or vista still trying to get hold of them if you could tell me those details I would be grateful, my email address is: bulldogmeghan@aol.com
M44DMMHany thanks, Rob.
Posted on Oct 25, 2008
Black screen upper left coner with line -
Please do the following carefully and let me know result :
1. Shutdown and Unplug your laptop.
2. Remove the battery from the laptop.
3. Wait 2-3 minutes
4. Now press ON (power button on laptop) for 1 minute
5. Then release the finger and wait one more minute.
6. Now plug in the power cable (dont insert battery yet) and press ON button.
7. Did your screen start working now ? (do you see windows loading)
The other option is to change the screen.
Here is the link to disassemble and replacement.
http://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
best of luck!
Mar 11, 2012 | Acer Aspire Z5600 PC Desktop
Laptop will not come on at all
You can try to reset hardware using following steps
1 Disconnect battery and ac adapter
2 Wait for 5 minutes.
3 Press and hold power button for 60 seconds and then release power button
4 Connect adapter (do not connect the battery ) and try to start by pressing the power button.
If it does not help, check ac adapter next
If the adapter is good, there can be some problem with motherboard
Sep 19, 2011 | Computers & Internet
When I turn my computer on I get a black screen
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
Please release the flea power
to do so..turn off laptop. take battery out as well as unplug the power cord to ensure that no power source is connected to the computer.
hold and press the power button of the laptop for 5-6 seconds.
then alternatively turn on the laptop on both battery and adapter mode and see if it makes any difference.,
If the above does not help try the below
please restart the system and tap the F8 key on initial system logo.
in the advanced menu select the safe mode option.
login as an administrator
Click start...all programs...accessories...system tools...system restore...
in the window that appears, restore computer to earlier date and time and click next
select a date may be a week or 2 back when system was running fine and click next
follow the onscreen steps
the system restore should reverse any changes to the system that might have caused the issue to occour.
let me know in case issue persists so that i can help you further.
Nov 16, 2010 | Dell Dimension 4300S (Refurbished)...
Computer won't start up
sounds like the cpu is dead, if your fan was full of dust theres a high chance it wasnt working properly for a while which would of caused the cpu to fry from lack of proper cooling and also the dust in the vents would have prevented heat from escapeing so its highly probable that the cpu is dead try replaceing it, i cannot gaurentee that anything else internally got fried from the heat tho, i had a similar problem a week ago
May 03, 2009 | Computers & Internet
Startup
dear sir.
"checking disc comes up" this message is hard disk message and it's showing becoust missplase of harddisk thru yr laptop scoket if u know bout laptops u need to plug off then reconnect yr laptop harddisk otherwise contact system wonder near u.. it's help u.
Jan 01, 2009 | Computers & Internet
Fan runs loud,constant on HP a1620n
cheek the cable of cable properly plug in
R
OFF YOUR pc and system cell put out for 10 mint put back in to the system and stat your system
R
cheek out fan for electric shot
repaly me if i solve your problem
Dec 13, 2008 | HP Pavilion a1620n (882780664494) PC...
Hello!I've got laptop Asus M50VM.I bought it 2 months ago.But now I have a problem with it-when I switch it on, I can use it no more than 5 minutes,then it hangs.To use it again I need to reboot it.And in...
Hello.
First thing, is the laptop getting very hot very fast? possibly dust in the ventilation blocking airflow or other component level issue causing overheating.
2nd, have you tried using the recovery discs? does the problem remain even after a fresh install?
Check these two things and report back.
Thank you,
I will fix it!!
Nov 14, 2008 | ASUS Computers & Internet
Hello I have Asus G1S notebook. My screen is blank when I starting my computer, I'm able to here windows login sound but is nothing on the screen. I try use external monitor it doesn't work same HDMI. I...
You could leave it off for a few hours, but there is a much faster solution that does pretty much the same thing. Turn your computer off, unplug ur AC and battery. Then press and hold the power button for about 15 seconds. This will drain all of the power remaining in ur computer. Then plug ur ac adapter back in and it should be fine.
Oct 13, 2008 | Computers & Internet
Laptop Screen is broken
Laptop screens are usually very pricey to fix. Chances ar eyou will need a new one , and the price of a new one + labor for someone to install it usually isn't worth it. For the same price you can purchase a brand new one!
Sep 30, 2008 | ASUS Computers & Internet
Computers & Internet Logo
1,499 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
