Question about IBM ThinkPad T43 Notebook
Hard drive failure on IBM T43
I had my hard drive fail on my IBM T43. when I power up the laptop I get the IBM banner screen and then the screen goes black and in the top left corner it displays:
A disk read error has occured
Press Ctrl+Alt+Delete to restart.
When I press Ctrl+Alt+Delete it just does the same thing. It will not read the hard drive. Is there any way to retrieve the data and or settings that were on the hard drive?
  • jaimiescomp May 21, 2008
    my computer will only turn on the the computer, it bring up the ibm thinkpad load screen and says hit the access ibm button to interrupt the normal startup process, yet nothing i press works
I have a ThinkPad T43,
Now it's hard drive is broken so when i change the new hard drive Hitachi 160GB it display the message as below.
Could you help me to terminate this error message.
2010: Warning: Your internal hard disk drive (HDD) may not function correctly on this system. Ensure that your HDD is supported on this system and that the latest HDD firmware is installed. Press <Esc> to continue
I try to update firmware of the harddrive but still appear the message the same.
Posted on Dec 26, 2008
  • 144 Answers
Hi suzi,
Its still possible to retrieve data by taking the harddisk out and put it in external harddisk frame.Connect that external frame trhough USB on some other PC or Notebook and see you could see information inside.Incase you can't see any information inside then you need to use some other recovery program like Getdataback,Recoverymyfile,etc.
Posted on Apr 23, 2008
Audio driver ibm
Do a google search for: ibm thinkpad t43 drivers and it should bring up links to the ibm support/download site. Just make sure you know what OS you are running when you find the driver you are looking for. I had to do this for my t43 not too long ago after a hard drive replacement.
Dec 04, 2011 | IBM ThinkPad T43 Notebook
Ibm t-43 laptop cannot find hard drive even though there is one and hard drive was reimaged successfully. rebooted laptop and keep getting error message
Make sure harddrive is set for CS check jumper on drive, Make sure no pins are bent on hard drive, Stop the computer at the bios setup and check the bios is set right..If all this fails you could have an motherboard issue, since you have mention that "the drive has been reimaged"
Feb 24, 2010 | Lenovo IBM ThinkPad T43 Notebook PC -...
Ibm t43 compatible hard drive
with ibm when u change new hard disk you much find ibm hadr disk support for laptop, if another type u much run fix hdd
you go here to download soft to do and search hdd supported
Jan 19, 2010 | IBM ThinkPad T43 Notebook
T 43 says "operating system not found"
Sounds like you have a bad hard drive. Boot up with a Windows CD and select repair at the setup menu. It should dump you to a command line. Type "chkdsk /f" without the quotes and it will check the hard drive for errors. When it's done, reboot normally and it should get you into windows. If it doesn't, replace the hard drive and install windows on the new HDD.
Oct 26, 2009 | IBM ThinkPad T43 Notebook
My ibm thinkpad t43 displayed a message "hard error D0014" on a small blue screen. when i shut it down by pressing the power button for a few seconds, it restarted. but the programs won't work.
This could be a problem, not sure if its a software related or if the hard drive is bad. If you can find a windows xp cd. Try and wipe out the hard drive and install windows xp on it. If it goes thru then you'll just need the drivers. If it errors out on you then you know its a problem with the hard drive and you'll need to replace it. If you get windows xp installed on it, let me know and I'll help you with the drivers.
Jun 04, 2009 | IBM ThinkPad T43 Notebook
IBM T43 Screen Turns OFF After Removing Charger Cable
Sounds like a bad battery to me. If you have a DC voltmeter you can check the battery.
Feb 23, 2009 | IBM ThinkPad T43 Notebook
Ibm t43, xp pro won't recognize my WD my book
please write down the error and contact me now
anaesarora online
Feb 06, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Boots up to Safeguard blank blue screen..loggin failed
This generally indicates a hard drive failure. You will need to replace the hard drive and reinstall the operating system.
Jul 01, 2008 | IBM ThinkPad R40 2723 Notebook
MY IBM T43 fails to boot
Take out the hard drive and see if the laptop still shuts down. If it doesn't then your hard drive might be the issue. You can also try reseating your memory.
Dec 26, 2007 | IBM ThinkPad T43 Notebook
IBM ThinkPad T43 Notebook Logo
1,299 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
