Question about Acer AL1916W 19" LCD Monitor
Monitor resolution conflict
Hi, I have just bought the 1916W monitor to go with my Travelmate 7510. Problem is that the screen asks me to set the resolution to 1440 x 900 but mt laptop does not let me have that setting - result is a blurry screen image. Any ideas?
  • 221 Answers
Install the Drivers for your New Monitor and then try increasing your resolution. If fails to solve, contact your Monitor Vendor (Seller).
Sahaja Yoga is FREE OF CHARGE and is the MAHAA YOGA.
Posted on Apr 23, 2008
Change screen resolution
computer monitors in the past have been output only. With the invention of touch screen you have two way communication. Control for a monitor would mean sending codes to the monitor circuitry, which is usually done from the driver to the monitor and from the monitors menu.
Nov 22, 2013 | Computers & Internet
When i put pc on this message comes up on screen saying input not supported and it floats round in a little box.
This generally means you have the display resolution set higher then the monitor can support. To fix this press F8 after you turn the computer on. You may have to press it a couple times before the windows loading screen. A black menu will come up. Select safe mode. Your PC will load into safe mode with minimal drivers and settings. Go to the control panel and select display. Change your screen resolution to something lower then the setting is is at right now. If your screen is 19" or smaller try a setting of 1024x768 for starters. If its 20" or higher try 1280x1024 for starters.
Regards, Chris
Jun 30, 2011 | Acer Computers & Internet
How do i set the monitor so the text and icons appear clean and crisp?
go to acer website and download driver for monitor or graphics monitor. Make sure you download AL 1916W and NOT AL1916. Make sure after, you set your resolution to 1440 x 900. That should do the trick.
Feb 03, 2011 | Acer AL1916W 19" LCD Monitor
Pop up of monitor adjust screen
Hi, you probably have to set the correct resolution that fits on your monitor. The correct resolution is: 1920x1200 You can set it by right-clicking on your desktop and choosing "Screen Resolution" in Windows Vista and Windows 7. If you use Windows XP, right-click on your desktop and choose "Properties" Then open the rightmost tab to choose the resolution
Jul 19, 2010 | CTL 261UW 26Inch Wide Screen LCD Monitor...
My laptop displays extended out of screen and i cant click or even put my password. any suggestion?
If you can get to the desktop, right-click on it and change the properties settings for resolution
Mar 24, 2010 | Acer TravelMate 6291-6753 Notebook
Osd lock in my LCD
Check your switchers resolution settings .....
You might have to change your resolution settings....
This solution is for AOC Monitors......
Setting the Optimal Resolution
The recommended resolution for this monitor is 1680 by 1050. To setup the monitor to this resolution, follow the steps below.
  1. Click START.
  2. Click SETTINGS.
  4. Double click DISPLAY.
  5. Click SETTINGS.
  6. Set the resolution SLIDE-BAR to 1680 by 1050.
External Controls
Press the power button to turn the monitor on or off. The other control knobs are located at front panel of the monitor (See Figure ). By changing these settings, the picture can be adjusted to your personal preferences.
* The power cord should be connected.
* Press the power button to turn on the monitor. The power indicator will light up.
203-35.jpg Hope this helps ,
Rate me please,
Cheers Misterdj
Aug 12, 2009 | X-10 LM929 19IN LCD 12X10-.294MM SPK BLK
923nw samsung resolution problem
on ooptions screen, click box that says only show settings the monitor can handle. Then try changing the horizonal and vertical settings on monitor to match it up with your settings.
On your windows main screen, right click, then properties, then settings, check all the settings
Jul 09, 2009 | Samsung 923NW 19" LCD Monitor
Repairing the MB for the (Acer) AL1916 monitor
Apr 24, 2008 | Acer AL1916W 19" LCD Monitor
Hansol Mazellan 500A is it not compatible with 128MB Video Card?
your monitor does not support the screen resolution that your windows install is set to. hook your pc back up to your computer guys monitor, and reduce the screen resolution, then hook it back up to your monitor.
Jan 08, 2008 | Hansol 500 A Monitor
Screen resolution
hi, try playing with the aspect ratio .. let me know
Dec 11, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
118 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
