Question about iLO 3200 32 in. LCD Television
Can't change output source and tv sensor wont work
I bought the tv as an "open box display" item everything works ok but im guessing the sensor doesnt work because no universal remote will work and i cannot change the output source, i can only view regular tv no dvds and i have to change the volume on the actuall tv. how do i fix this or where can i get a new sensor???
    Problem Solver:
  • 13 Answers
Souns like the ir sensor board is gone, shopjimmie.com may have one ,they are probably around 15 bucks and real easy to change ,its one connector i believe ,i have not found any universal remotes that work with ilo yet either,good luck i hope i was of help
Posted on May 02, 2008
Manual says only audio inputs are output to the rca audio outputs. How can I get digital audio inputs to output to where I can connect wireless speakers.
Does your receiver have a set of rca connectors labeled "tape out" or "tape monitor" those might work as a better output. As far as the delay goes, if you have your tv hooked up via hdmi, then you will not be able to get the audio to sync up with it. the tv takes longer to decode and display an hdmi output than your receiver does for an audio input.
Jan 14, 2016 | Marantz SR6001
I have audio but no picture, just "Video 1"
You didn't mention tv make / model so thjis is only a guess . The tv may need tuning to find the direct tv cable.
Jan 07, 2015 | Audio Players & Recorders
Install home theater insignia
How are you connecting the devices?
If you have used the cable box audio out (RCA) to the audio in (the ones just right of the digital coax audio out and the S-video out) on the home theater system, make sure that you have selected the correct Source. (Use the Source button on the front of the system to select AV1 or AV2. This toggles between AV1, AV2, tuner and DVD. It's the right-most button below the display screen. Alternatively, use the Tuner/Aux button (second from the bottom on the left) on the remote.) Note with this connection, the video source cable should go to the TV directly. Unless it is a composite video signal. Then connect the RCA video out (REC out). Make sure that the audio digital output is off. Press Setup/Exit (just above and to the right of the arrow keys) on the remote. Go to the audio menu (press the left arrow key twice) and press OK. The first item in the list is the digital output and should be blank unless you are feeding the audio to another system.
Next try a different audio cable and check that your speaker wires are all connected. Check that the cable box is getting power and a signal from the provider. Connect it to the TV to recheck. If it isn't, make sure that the cables didn't come loose on the box while you were making the connections to add the system.
If you have a newer cable box with HDMI or digital audio out, these most be connected differently. A digital to analog audio converter will work with the second option. For an HDMI connection, connect that cable to the TV, then connect the TVs analog audio out to the NS-H2002. Then go to the Audio menu of the TV and turn on the external audio and turn off the internal speakers. (If your TV has a headphone jack as the only analog out, then this step may not be needed. However, you'll need a 3.5 mm to RCA stereo cable or adapter.)
Check if the audio works with another source (like a DVD). If another external source works, then it's the cable box or the connections to it. If no external sources work but you can here a DVD play, it's probably the input jacks on the system.
I hope this helps. Please add a comment with more information about the cable box outputs and the TVs inputs and outputs if you need additional assistance.
May 22, 2012 | Insignia NS-H2002 Theater System
Have sound and a black / white picture ? through our sky box
change the output to pal or ntsc on the sky box, then it should display in colour. If that doesnt work change the input on the tv to pal or ntsc.
Apr 17, 2011 | NEC 60XP10 TV
No response to remotes
if the batteries are down change them if it still doesnt work then walk to your console at the left of where to put the disc open the cover and open the cover in where you put the remote batteries and then press sync in the wii remote and wii console just click them dont keep pushing the for more that 10 seconds or everything that is on will turn of except the wii it may not work if it doesnt ask the question for me helper9 that it still doesnt work
Feb 13, 2010 | Nintendo Wii Console
On a Daytek 46 in LCD TV, no AV Digital Cable Signal, but HDMI OK
Had the same problem.
Fixed by unplugging everything from the power source, leaving for 2 minutes then plugging back in.
Works fine now.
Aug 11, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
My sky remote wont control the volume on my tv
Hi Re Easytouch 42" HD TV - look for Hisense - I took a guess and LCD3204 EU code 376 - remote works but buttons don't tally up - getting there slowly!
Just bought a madeforyou 4:1 remote that is programmed on my PC.
Ok - not proper solution yet but nearly there!
Dec 19, 2008 | Televison & Video
Sony HDZ235 HDMI
use component outputs of that unit to play on tv.Or use component or video output of sony unit and connect to cable box if available and use the source switching on cable box to change sources that way you wont have to unplu HDMI cable..By the way HDMI has a new challenger in the near future called ' DISPLAY PORT' ..
Dec 03, 2007 | Sony HOME THEATER SYSTEM System
I cant see anything on my vizio 32 inch television
I just spent an hour trying to fix the VIZIO with the same problem. The screen had no picture at all, but could hear the sound perfectly!! But we i figured out the solution! UNPLUG THE CABLE BOX AND LET IT RE-BOOT! and it WORKED!!!!!
Aug 05, 2007 | Vizio L32 32 in. LCD HDTV
iLO 3200 32 in. LCD Television Logo
140 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
