Question about HP Photosmart C4280 Aio Printer
Connecting USB during install freezes computer
I recently purchased a HP Photosmart C4280 all in one. Installing it went fine until I had to plug in the USB cable. It completely froze the computer. The USB connections at the back are on the motherboard and there are 4 in total. If I don't have anything else on the USB ports it works fine, only if there is more than one device attached, adding the printer freezes everyting up. Now I got it working using the USB at the front of the computer but that isn't how I want it to remain b/c I cannot use it for other devices (memory stick, camera etc).
Any one else come accross this problem or better have a solution to let it work on the back USB ports.
Motherboard specs: MSI 965 Neo F.
  • saboura1 Nov 19, 2008
    Hello, I have the same problem... It comes when I use a combination of devices (printer-flash disk) in various usb ports, mostly in mainboard's back usb. I believe it's motherboard's problem but prior to windows boot-up in bios devices appear correctly
    Windows XP Pro SP3
    Motherboard: MSI P965 NEO!!!
  • 88 Answers
There are many possible reasons why your computer will shut down when your USB is used but most probably your PC power supply might not have enough power, try unplug other devices such as printers, scanners, other input/output devices except the mouse & keyboard.
Posted on Apr 23, 2008
I have a hp printer/scanner 3510 and hp computer, the printer works fine but it won't scan!! the lcd screen says, "the computer is not responding. check if the usb cable is attached" the cable is...
Unplug the USB cable to the printer. Uninstall the HP printer software. Reboot. Reinstall the HP printer software and WAIT until the installation program tells you to plug in the USB cable.
Mar 09, 2014 | HP Photosmart C4280 Aio Printer
HP PHOTOSMART C4280 ALL IN ONE WHEN USING IMAC 10.5.7, PRINTER SHOWS MESSAGE USB NOT CONNECTED
You need to try isolating the problem first.
1. Try connecting the USB cable into different USB port of your Mac Leopard.
2. Make sure that your computer could detect other USB devices.
3. Try connecting the printer into different computer to see if the printer would be detected or not.
4. Use different USB cable.
If you get the same problem, you need to contact the printer manufacturer. I believe that it is more on physical connection.
Have a great day!
Jun 22, 2009 | HP Office Equipment & Supplies
Windows keeps re-installing HP Photosmart C4280
I have a customer with Windows XP and the same issue. Told him to unplug the printer cable when starting the computer and/or restarting it. Wait until all auto-start programs have loaded, including and specifically the HP Monitoring Utility program. Once Windows is up and he's at the desktop, THEN plug the printer cable into the computer. He's been doing that for several days now with no duplicate printers installed.
Mar 13, 2009 | HP Office Equipment & Supplies
Can't install HP Photosmart c4280
You have to know first if your printer is Vista compatible.
If yes, you need the vista drivers in order to get your printer connected with vista.
When the system prompt for the driver, click BROWSE and Select the location
Open the folder when the downloaded driver is and click OK
This must be fixing your problem
Oct 29, 2008 | HP PhotoSmart C4280 Laser Printer
Hp photosmart c4280 all in one needs disk install & I don't remember when to plug in cords
You do not connect the USB cable until you run the software and it prompts you to connect it.
Here is a link to the setup guide in pdf format:
C4280 Setup guide
Oct 27, 2008 | HP Photosmart C4280 Aio Printer
Running windows 95: Cannot get C4280 program on computer.
Hi Dannysone,
If you look at the minimum system requirement(on the box or cd) you will find that win 95 is not supported. You probably can still use the printing function by using the hp deskjet c550 when you go to add printer. You really need to upgrade the computer. You probably will still be able to use the picbridge functionality on the photosmart to print pictures directly from the camera but thats about it.
hope it helps
cheers
Oct 10, 2008 | HP Photosmart C4280 Aio Printer
HP Photosmart C4280 All-In-One Will Not Scan
hi
i had the exact same problem and i installed and un-installed
over and over again
and then it hit me !!!
why bother ??? , just download a 3rd party scanning software like "VueScan" or any other you find on google and it does the job !!
it's light, recognize the scanner (C4280) automatically and scan !!
cheers
Sep 22, 2008 | HP PhotoSmart C4280 Laser Printer
OFFLINE PROBLEM
disconnect USB, go to RUN and type in services.msc and then find print spool and right click, then choose restart .plug in usb
Mar 02, 2008 | HP PhotoSmart C4280 Laser Printer
I cant install my hp photo smart c4200 series printer becauce I have lost the disk
Jan 30, 2008 | HP PhotoSmart C4280 Laser Printer
Installation Problems, Please help!
try downloading the software from the HP website and then reinstall the printer. But also try to uninstall it using control panel add/remove programs, restart your computer, and then reinstall using the downloaded driver.
Jan 27, 2008 | HP Photosmart C4280 Aio Printer
HP Photosmart C4280 Aio Printer Logo
150 people viewed this question
Seeker5211
Seeker5211
