Question about Minolta EP1030/1030F CS/PRO Copier
Minolta 1054 when i switch power on it switches itself off get error code c004
  • Anonymous Jun 08, 2008
    isee in the screen code c04 00 but the buton Reset ne fix pas my problem
    sorry my language eng is bad
    if any one have a solutuon plz contact me rf.r@hotmail.fr
  • Dilman Akram
    Dilman Akram Oct 12, 2011
    i have this yellow light flashing in my Minolta 1054 Copier Machine , the Machine stop working
Hi if you open the clamshell, and look at upper part of the machine
( fuser end ) you should see the main pcb. better viewed from the rear. you will see 2 pins on the pcb and i believe just below that you will see a very small micro switch this is the reset.
with the machine switched on press the switch do not use an implement. just your finger there are no high voltages to worry about
once reset make sure that you do not leave the lid of the machine up. as sun light will hit a sensor in the optics thus c0040
Hope this solves your problem
Regards Myott.
Posted on Jun 01, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Minolta Master
  • 1,362 Answers
Check fuser unit
Posted on Apr 23, 2008
I have a kodak esp office 6150 printer that when its powered on says document feed paper jam but there is nothing there. i press ok and it says rear access cover not attached (code 3514) but the cover is...
Error codes can't be bypassed. You have to solve the problem. Sometimes the sensor itself is the problem. Or the logic board it is communicating with. But you really have to investigate the whole paper flow, if not just a scrap of paper is in some corner. Then switch off the printer complete (remove the power cord is you can't find the power switch) and switch on again. If the error comes back, you have to call the service centre, sorry.
Jan 09, 2015 | Kodak ESP Office 6150 All-in-One Printer
Error code c4801 For C284e
You may have main board issues. Maybe Try error code reset.
Open front door and locate main power switch on the bottom left and turn off.
Press and hold the reset button , button on control panel.
Turn main power switch back on whilst pressing reset.
after 1 - 2 min a white screen with 1 button saying"error code reset will appear , let goo of reset button.
Press error code reset and then turn main power switch of for 20 seconds. turn main power switch.
If code returns contact me on my phone to discuss
Sep 02, 2014 | Konica Minolta bizhub Office Equipment &...
Error code c004
Missing a letter at the end of C-004 A/b/c/d. which one? each one is a different fan on the machine
Sep 15, 2012 | Minolta EP4000/5000 CS/PRO Copier
It was working fine until yesterday. It shut itself off. I powered it back on and befor the screen could come back on it shut itself off. I checked cables and uplugged it for 24 hours. The first time...
Hi Daniel,
Please check if you can access the "error code operational check" to narrow down where the fault came from.
How to enter to error code operational check.
Note : The TV must be in shutdown and not have been switched off. When the TV is switched off, the error code automatically resets to 12 (no error).
Press the buttons on the front panel "Input/Device" and "Menu" at the same time and hold it for 5 sec, activate the error code mode. The LED light will flashes denoting a two digit error code.
Example : if the error code is 22, the led will flash two times pause and then flash two times and will repeat the error code for five times.
If you can't access the error code operational check , please let me know the exact pattern of the flashes of the led light and its color. Check if it will continually flashes green to give you the caused of the symptoms and best solution.
Good luck and take care.
Nov 15, 2011 | Mitsubishi VS-50805 50" Rear Projection...
Whirlpool TXFE366LVQ. When I turn selfclean after few minutes it shuts itself off and displays code F5E2
An F5 error code indicates that you need to check the oven door or the latching switch. The switch is used when cleaning the oven, for safe closure. If you find that the door or the latch switch do not function, you may need to replace them
F5-E2 means latch during clean error; the door and latch switch need checking and possible replacement.
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Hope helps.
Jul 14, 2011 | Ovens
Hello i restored my computer now it won't let me go on
Try running System File Checker. Need to know which Windows version you're running but if you search for system File Checker on Microsoft website it will tell you how to do it.
Apr 25, 2010 | Acer Aspire 5500 5570-2609 Laptop
We have a Minolta EP4050 with an error code C004. Do we need to get serviced?
Yes you need to call service this indicates problem in your fusing unit. A busted Heat lamp is the reason or broken thermistor.
Jan 07, 2010 | Minolta EP4000/5000 CS/PRO Copier
Cannon gp200 - we have an error code 803-switch power on and off
we have an error code 000 - the message is switch power on and off- we tried this and the same code/message shows again please answer
Apr 03, 2009 | Canon Office Equipment & Supplies
52 Scanner error
52 scanner error means yoy got got an error with the scan assy, it could be many problems. If it not helps with turn off /turn on, try reset the printer. Turn off power press and hold * and #, turn on power, wait 20 sec and release the buttons. If printer not goes to ready, disconnect power cord when printer initialize and turn off power switch. reconnect power cord and turn on power switch. If you get the printer to ready state, upgrade firmware.
Oct 15, 2008 | HP LaserJet 2840 Printer
663 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
