Question about Sony KP-53V80 53" Rear Projection Television
Cobweb hanging inside screen
I have this tv. and there's a lot of cobweb inside.What should I do to clean it.plss help me..
thank's jollyme
  • sony-fan1964 Jun 29, 2008
    i have like a web net kind a like i want to clean it any help please
OK I DID IT I WAS AFRAID TO OPEN IT , BUT IT IS SO EASY IF YOU DO IT LIKE I DID IT , FIRST UNPLUGGED EVERYTHING WITH THE TV , TRY IT IN OPEN SPACE AND WITH LIGHT , UNSCREW ALL THE SCREWS FROM THE BLACK COVER IN THE REAR OF THE SET ONE BY ONE THE USUALLY HAVE AN ARROW MARK POINTING TO THE HOLE, INCLUIDING IN THE BOTTON OF THE COVER , ALSO UNSCREW THE OTHER SCREWS FROM THE RECTANGULAR COVER TOO THE ONE THAT HAS THE HOLES FOR THE VENTILATION OF THE POWER SUPPLY, SO AFTER THA IT IS DONE , PULL OFF THE ONE WITH THE HOLES AND THEN THE BIG BLACK COVER PULL IT FROM THE MIDDLE AND BE CAREFUL WHEN YOU DO IT BECUSE IN THE INSIDE IT HAS A MIRROR ATTACH TO IT SO BE GENTLE WHEN YOU PUT IT DOWN , ONCE IS DOWN YOU CAN FLIP IT SO YOU CAN CLEAN IT . OK NOW YOU CAN SEE THE WHOLE BACK OF THE T.V. WITH A CLEAN PAPER TOWEL YOU CLEAN IT . THEN PUT IT BACK TOGETHER USE WATER ONLY , GOOD LUCK
Posted on Jun 30, 2008
Cobwebs inside screen
you need to take the top back off the tv. and mind the glass at the top of the rear part top it is very fragile, most of the projection tv have a side cover on each side so you can clean the rear of the screen, as you not said what type screen you have i cannot tell you further.
Feb 25, 2014 | RCA Televison & Video
I have what appear to be cobweb like lines of dust between the shield and the screen, how do I clean this?
TWO ways, hard way is remove entire front screen from the set.
Easy way is unplug set and remove back cover; with a swiffer like duster reach up and carefully remove the webs etc---do not press hard on inside of screen as you can scratch it.
Also clean the three large round black lens with a lens cloth or paper towel with glass cleaner on it.
Should be a ten minute job.
Make sure set unplugged when you do this!
If this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Aug 21, 2010 | Toshiba 51H83 51" Rear Projection...
Hi I have a Sony KP-41DS1U projection TV. There is hair or cobweb that 'floats'on the screen. Can I get access to 'blow' or clear it. Many thanks John
You could unscrew the screen frame from the rear cabinet. You only need to get a bit of a gap to gain access. Then use a flexible cleaning wand to clean those spider flowers out of there.
Mar 15, 2010 | Televison & Video
How doI take the cover off to clean the inside of the protective screen? sony KP-53v80
I removed about 6 or so screws took back cover off and used a duster to clean the inside screen it cured my cobweb problem.
Sep 12, 2009 | Sony KP-53V80 53" Rear Projection...
Cleaning cobwebs from philips rear projection tv model 51PW9363/1
I had the exact same problem and the fix is easy to do. Unplug the TV first of all and wheel it out so you can easily get to all of the rear screws.
  1. Remove the screws from the ventilated back panel (the piece of wood with a bunch of holes in it surrounding the AV connection panel.
  2. Remove the wood panel you just unscrewed.
  3. Remove all screws from the upper plastic case on the back.
  4. Remove the back plastic case carefully. This is a little tricky due to two metal pins that it hangs on. Lift it upwards and you should be able to free it from these pins
  5. At this point you should be able to see the entire workings of the TV, and consequently the massive amount of dust that has accumulated.
  6. Carefully take a vacuum and remove all the cobwebs, taking care not to bump the mirror or the lenses.
  7. First, I used some compressed air to clean off the lenses and then used a clean microfiber towel to remove all the dust from the lenses, the mirror, and the screen on the inside. Make sure the part you are wiping the mirror and lenses off with is free from any dust or dirt or you will risk scratching them.
  8. Reverse the dissasembly process to put the case back together.
  9. I went through the convergance settings at this point and found that they were all out of calibration and as such recalibrated them. Use the mulitpoint calibration for best results.
  10. Enjoy a much cleaner brighter TV!
Jan 25, 2009 | Philips 51PW9363 51" Rear Projection...
Cobweb in projection tv
take the back cover off as the mirror is attached to it then you can clean the mirror and the inside screen and colour gun lens's (3off) there should be 8 to 10 screws around the outer edge of frame and about 6 to 8 holding the screen portion to the chassis
Jul 23, 2008 | Televison & Video
Cobweb inside of TV
i did mention this in my problem post incase it can help you but in the event where you overlooked it try some dust-off it may help you better than it did me
Jul 05, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
How do i clean my screen
You can clean the screen from the back - take off the access panel. I clean mine once a year whether it needs it or not.
Apr 23, 2008 | Sony KP-53V80 53" Rear Projection...
Cobweb?
You'll need to have the frame of the tv either opened so you can reach in there or the top mirror block assy will need to be removed to get inside to the screens. You may want to have a Sony ASC do this type of repair. Call Sony for a referral.
Dec 26, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Cobwebs in the screen
pop the front grill off and you will see some screws onthe bottom of the screen. pull these out and the grey trim peice should pull right off.
Oct 14, 2007 | Philips 60PP9202 60" Rear Projection...
Sony KP-53V80 53" Rear Projection Television Logo
95 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
