Question about Samsung Refrigerators
SL39WJ1/XEU FRIDGE FREEZER The Fridge compartment of the appliance is not working. The Freezer compartment is fully functional. What would be the first approach to rectifying this problem. Hoping you can help, Sue Barnett
  • Dazmiesta Nov 15, 2009
    Samsung Cool'n'cool FF - sl39wj1/xeu.
    The problem is that it keeps turning itself off and on with a single long bleep. The display just stays on "--" .
2 Suggested Answers
SOURCE: hi i have a fridge
water in fridge on shelve from freezer.( I am assuming) Have defrosted and cleaned fridge and freezer removed all visable ice and water. Took off vent in fridge no ice. what else can I check out before calling repair man?
Posted on Dec 31, 2008
Kelvinator cyclic 410 Upside Down Fridge Freezer. Fridge not getting cold. Freezer is working fine.
Is the fan in freezer compartment working? Is the damper fully open to allow cold freezer air into fridge section?
Sep 23, 2017 | Refrigerators
Hi I have a samsung fridge freezer. Sl39wj1/xeu. Doesn't seem to be doing anything no light but is continually flashing f5
not sure what you mean water in fridge and ur assuming? did it freeze everything or not freeze? is fan not running or compressor? any noise or sounds?
Mar 14, 2015 | Samsung Refrigerators
Samsung sr-l3426bs fridge not getting cold
you would need your fridge defrost sensor replace, check for ice build up within the vents of fridge section,
best to a tec to come and replace it for you,you would need the sensor to be reset on your fridge computer board
Nov 04, 2012 | Frigidaire FRS26R4A Side by Side...
My Samsung Freezer isnt working but the fridge is fine
without checking equipment you can only assume things that may go wrong...1st..try fully defrosting complete unit,clean all vent/drain holes then switch back on and let unit do its thing for 24 hours.then check temperatures are minus 18-20c for freezer and plus 2-5c for fridge (approx)unless you have electrical meters to check, this is just about all you can do..
Feb 19, 2010 | Samsung RS2630SH Side by Side Refrigerator
Zanussi fridge compartment has stopped cooling but freezer is ok
How to check everything
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 24, 2009 | Zanussi ZI918 / 12K Bottom Freezer...
Hi i have a fridge freezer which is a samsung sl39wj1/ xeu and i need help coz it keeps coming up with f5
Dec 31, 2008 | Refrigerators
Fridge not working
I've had this happen to my Kenmore 73503 several times. The 1st time took me a few hours to figure out what the problem was.
Basically the fridge is cooled from the freezer, so when you say your freezer is -2 degrees, it's a big tip off to the problem.
If you look very close in the freezer compartment at the back, you'll notice an opening with a little door at the top of the freezer compartment. This opening extends up the inside of the back of the fridge to the top of the fridge area via a square plastic tube.
Basically what happens in my fridge is the family loads the freezer to high especially at the top/back. This restricts or closes off the opening for the cold air to the fridge portion of the appliance ....resulting in a warm fridge, but cold freezer. Just remove the articles at the back of the freezer to correct problem. (It will take a few hours for the cold air to cool the fridge down)
Note: the temperature control unit in the fridge area controls the little door at the top of the freezer compartment, so if you haven't blocked off the opening, the next place to look would be either at the mechanical parts of the little door or the temperature control unit itself in the fridge
Mar 22, 2008 | Kenmore 73503 Stainless Steel Bottom...
Samsung fridge freezer rsh1dtmh1/xeu
the only way is to remove the middle wheel right at the front this allows adjustment with the 2 feet at the front
Mar 20, 2008 | Refrigerators
Fridge freezer
fully defrost it 48 hrs with the doors open and that can often cure it.
Feb 11, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Refrigerators Logo
305 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
