Question about Canon PIXMA iP4200 InkJet Photo Printer
Will not function on front feed
My Printer keeps showing error message. Paper Jam etc but there is no jam. When I switched to the rear feed it worked OK for a while but now it will not switch at all. Orange light flashes 3 times but cover is closed and no jams. SOS
Les Hereford
My printer will no print and will not take paper either front or rear. The orange light flashes and the error message says paper empty or paper jammed. There is no paper jam and the paper is loaded.
Posted on Nov 13, 2008
  • 3,587 Answers
Check all paper paths for little pieces of paper
Posted on Apr 23, 2008
Paper got jammed. Removed. Still says paper jam, but I can't see any. What should I do next?
Error says paper jam, but there is not. What could cause this ...,+but+there+is+not...
iFixitThere is no paper jammed anywhere! each time I would finish with the steps and ... I have to turn off and turn on the printer to get it going again. ... and the grinding sound and the paper jam message still comes up. i am going to try .... well no luck Iremoved ink and they are not dry - new- and now it says paper jam and not so ...
Fixing Brother Printer "Paper Jam" Error with No ... - YouTube
? 1:54
May 30, 2014 - Uploaded by Refresh Cartridges
Fixing Brother Printer "Paper Jam" Error with No Paper Jammed.... problem occurred again. i try this many times but the problem is still in there. ... There was paper jam front rear on my brother j450dw that wasn't going away, that was ... How to remove jammed paper HP LaserJet Professional P1102 Printer ...
How to fix a printer paper jam. - Computer Hope
Dec 03, 2015 | Office Equipment & Supplies
I have a Samsung Printer Model SCX4100. I had a paper jam and removed the paper, however, I Have a Paper jam 2 Message and don't know how to clear it. Please tell me what I need to do to clear the...
This is a sample guide;
41093dd.jpgWell I fixed it!!! Here's what I did. You see this picture of the cover opened? Where the arrow's pointing is the home position of the printer head. Under there I found a scrap piece of paper! Here's exactly what I did. When I got home I decided to plug it in to see if it would work, but it made the same noise and showed the same error message as before. I opened the cover as shown above. This resets it, and it says "close cover". I closed it, and AS it started to go through its routine I OPENED IT again, and I could see the printer head moving back and forth. At this point I used a flashlight to see where the home position of the Head was, and that's where I found the scrap of paper!
I unplugged it for safety and was able to remove the scrap with my fingers.
By your descriptions, referring to the other users, you just might have the same problem.
Hope this may help;
Aug 25, 2008 | Samsung Office Equipment & Supplies
My printer keeps showing the message, " paper jam
Hello Tessty,
The Paper Jam message may appear on the display if the Brother machine is not feeding paper correctly, paper scraps stucked or the paper is not loaded properly in the paper tray, the jam clear cover located in the back of the machine, is not installed properly or the PE Actuator is missing or damaged.
Please visit the link provided below to resolve the issue step by step :
Jun 20, 2011 | Brother Multi-Function Center MFC-240C...
I'm trying to print but it keeps coming up with an error message paper jam, remove jam paper and press start. There's no paper jam and it won't print. I have try talking out the paper from the feeding tray...
Please remove your printer from the PC and uninstall the printer software. Now reinstall the printer driver software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
If the printer shows a jamming error then check the input of the paper feed as there can be some foreign objects that is obstructing the detector opto-coupler or the detect switch. clean and check or the sensor is faulty.
Mar 18, 2011 | Canon Office Equipment & Supplies
Paper jam
Use mirror and flashlight to look down paper feeder from the rear, gently pull paper toward the rear. An index card can be fed from the front to the rear to push paper out by turning the gears you see on the left side inside the front cover. Be careful not to force anything.
Jun 19, 2009 | Canon PIXMA MX310 All-In-One Printer
Error message keeps appearing "paper jam in tray 2" although there is definitely no paper jam.
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If you don't find anything you may need to disassemble the printer to find it.
May 02, 2009 | HP LaserJet 2300dn Printer
Paper jam. we removed the major portion of it. bit of paper is inside. we can't find out that. display shows 13.20.00. we removed front and back except toner catridge. what we have to do.
Try this linke below.
Or i cut and paste text, but you should view pictures. If you cannot get to it from link. Try typing "Paper jams alternating between front and back door" It should be first link from HP about a 3550.
HP Color LaserJet 3500, 3550, and 3700 Series Printers - Paper Jams Alternating Between Front and Back Door Issue Description Customers may see paper jams error messages with no paper seen in the paper path. The message will alternate between check the front door and the back door. Workaround The release lever engagement tabs on the rear door can be bumped into the in-correct position. The purpose for this tab is to re-engage the fuser release levers as the rear door is closed. When one or both of these are left in the in-correct position the printer goes into a cycle of alternating between a "Jam in the Front Door" message and "Jam in the Rear Door" message. There is no paper present in the paper path when this happens. When a customer gets the "Jam in the Front Door" message and opens the front door, no paper is found. After the customer closes the front door, they get the "Jam in the Rear Door" message. When they open the rear door, find not paper (even pull out the fuser), and close the rear door, they get the "Jam in the Front Door" message. This cycle will continue
Placing both engagement tabs in the "Correct" position solves the problem and allows the print job to continue.for as long as the customer is willing to keep checking.
Sep 27, 2007 | HP LaserJet 3550 Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
743 people viewed this question
old marine
old marine
