Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
My hoover steamvac 5914-900 clean surge is not sucking up water
My hoover steamvac 5914-900 clean surge, is brand new. It worked earlier today but now it won't **** up the water. I've done all the basic checks...lid is on secure and latches are closed. I made sure that the automatic shut-off was down. There is no water in the dirty water tank. It seems that it is blowing out instead of sucking up.
reddevil6
  • 1673 Answers
SOURCE: Hoover SteamVac 5863-900
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter, or the lid for the dirty water tank is not locked down on th e tank.
Posted on Jan 10, 2008
reddevil6
  • 1673 Answers
SOURCE: Hoover widepath steamvac
One cause is the filter in the dirty water tank lid is pushed up too high, it needs to have a gap of 1/4 in or so. So check it, if it is up all the way, pull it down some.
Posted on Jan 15, 2008
  • 126 Answers
SOURCE: not sucking up dirty water
The F5914 has a lid that must be engaged with the tank in order for the suction to reach the floor. Gently lift the front of the lid on the tank and if it lifts up, you haven't engaged the two tabs on the tank into the lid. Remove the lid and make sure the tabs on the tank fit into the grooves on the lid and snap it closed. This should solve your problem. Also, make sure that the removable duct in the front of the tank is in place. It is removed when the hose is used, but must be replaced when the machine is used on the carpet.
Posted on Feb 02, 2008
jyackle5
  • 8197 Answers
SOURCE: All I need is to print out the Instructions, for
Here you go.
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Good luck and please Rate FixYa!
Posted on Mar 05, 2009
SOURCE: recovery tank not working
recovery tank empty where do you look to see where the hair ball is so i can clean it
Posted on Apr 04, 2009
My hoover spin scrub has no suction wont pick up water why?
No suction means somewhere in the intake side of the system you have either a blockage or an air leak.
Jan 21, 2015 | Hoover Brand New SteamVac Spin Scrub...
Hoover carpet cleaner blowing not sucking
While the blower has different source that the sucking of water, the passage for the sucking of water needs to be cleaned to eliminate any blockage within the passage.
Apr 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Need to clean lint out of the front cover.
You need to use a Hoover Nozzle Cleanout Tool for the SteamVac
You can find the part by clicking the link. Please give positive feedback.
Cleanout tool Link
http://www.usavacuum.com/Hoover-Nozzle-Cleanout-Tool-SteamVac-p/39514001.htm
Jan 18, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Steam vac won't **** water
check to see if the recovery tank lid is on correctly. if this is not on, the machine will not **** up the dirty water from the carpet. all you will get is suction that is chopy when it comes up instead of more like a flow.
Jul 31, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Every time i push the steam vac forward it dispenses water
you are having the same problem i am and so far the best solution i have found is i need a new clean tank just got my steamvac today bought it cheap so not complaining much the other solution i found was to only have the cleaning solution tank in for as long as i need it if i put the cleaning solution on the floor then take out the clean tank the dirt tank still sucks up the water
Godbless and Goodluck ...by the way just in case you dont have it here is the manual for your model
Jun 08, 2009 | Hoover SteamVac F5914-900 SpinScrub...
The spin brush wont spin but the water is spraying out and sucking up
possibly the brushes need cleaning http://www.hoover.com/pdfs/manuals/F5914900.pdf manual for your steamvac
Press all four latches (B) and pull brush
block out. The brushes can be cleaned
under running water
Godbless
Jun 07, 2009 | Hoover SteamVac F5914-900 SpinScrub...
No suction in new Hoover Steam Vacs
http://www.hoover.com/pdfs/manuals/F5914900.pdf hopefully this helps
May 31, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My hoover steamvac spot doesn't spray
the pump has to prime first ,put water in the solution tank an yurn on and keep the trigger pulled till it sprays.if that don't work take it back
Apr 28, 2009 | Hoover F5505 SteamVac Spot Vacuum
Problem suckin up water
http://geeksquad.fixya.com/ThreadView.aspx?prdid=41079&thid=729141
Problem sucking up water
Pos Problem sucking up water
Ted by raybrower on Jul 01, 2008
Have a Hoover SteamVac with 5 brushes and it will not suck up any water and I have cleaned all the brushes but it still wont pick up any water
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Part of the problem is with your holding tank, there is a rubber gasket that seals the unit to pup the water and if that gasket is cracked or missing it will not pup. Also there could be something wrong with the suction motor or the Hoover SteamVac may be clogged and will not pup the water, if there is a way to say back track the suction then follow the suction back to the suction motor and if you see a clog – remove it. Otherwise you may have a bad suction motor and it would need replacing as a last resort. If the Hoover SteamVac is less than one year factory warranty it would be covered under the Hoover factory warranty and then feel free to contact the local Hoover Factory Authorized Dealer in your area, so call the cust serv @ Hoover and they can direct you to a dealer that would cover this under warranty. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover F7431-900 SteamVac Vacuum
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
216 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
