Steering rod / pinion - front L brake, 1996 Toyota Granvia 3L 4wd auto
Shuddering when pressure on brakes applied. Squeeky brakes
Your e-mail was way out. Toyota Granvia is a motor vehicle. Problem has been resolved, No need to add my mystery to your list.
Posted on Apr 24, 2008
Brakes shuddering going down hill on a 2011 Toyota RAV4, what can I do?
Warped front rotors,replace or machine flat if they aren't worn below spec.Most parts shops can give you the specs for the rotors.
Mar 10, 2015 | 2011 Toyota RAV4
My brakes keep locking up
This sounds like the master cylinder has a problem with the check valves these are internal in the master cylinder. After removal of the master cylinder check to see if the rod coming out of power brake unit is threaded it may be to long and holding residual pressure in the lines keeping the front brakes applied. Testing for residual pressure is easy drive until locks up just turn bleeder screw without touching brake pedal if fluid sprays out fluid is not returning to master cylinder. good luck.
Apr 17, 2014 | 1996 Toyota Camry
My stearing oil leak away from my stearing system
Inspect the source of leakage. (Power steering pump,
clamps, discharge or high pressure pipe, suction or low side pipe, rack and pinion assembly).
- Vibrating while braking means the front wheel brake rotors are warped or rear brake drums are eccentric. (Tooling is required)
Mar 06, 2014 | 1996 Toyota Corolla
Front brakes piston
what the whole car, and/or the brake pedal. shudders?
my guess you are moving and braking?
forward or reverses
2wd or 4wd?
i say take it in, as brakes are very serious business.
Jan 08, 2014 | 1998 Toyota Land Cruiser
1996 camery station wagon , 4 wheel disc brakes. need to replace brake lines in the rear. what is the name of the junction block , with the actuator in the rear? All 4 rear lines go to and leave this...
Hello, first you Toyota has dual braking system. It goes like this: Left front brake with right rear brake, the right front brake with left rear brake. This a braking safety system that has been incorporated in auto/trucks for a few years now. If brake line is broken. loose wheel caliper, blow caliper piston, any thing that happens to the brake system. You will still have two wheels that have their hydraulic system. Also, the emergency brake will a manual system for the rear wheels.
Why do you need to change your auto brake lines? That valve you are talking about is a load stabilizer valve. It used to limit the amount of hydraulic fluid as more load is place in the rear of your Toyota. Example. by press on the brake pedal, it activates hydraulic pressure to the four wheel disk braking system. The braking system needs to stabilize the hydraulic pressure to the wheel to keep the vehicle moving in a forward motions. Now, by loading the rear of the vehicle this transfer the load disposition of the vehicle by making it heaver in the rear. Therefore, the load compensator valve limit the amount of hydraulic pressure to the rear brakes.
Another thing to remember about this rear load valve, they will get plugged. and the vehicle will not have enough braking pressure for the rear wheels. I hope I answer you question about this load portion valve in the rear of Toyota. GB...stewbison
Sep 21, 2011 | 1996 Toyota Camry
The front end shakes really bad when brakes are applied
This means that your rotors are worn or most probably warped, they can be skimmed by an engineering works/workshop or replaced.
It is important not to leave them too long, because in the long term the "brake shudder" can cause wear on the suspension and steering components.
Hope this was helpfull to you.
Feb 16, 2011 | 1991 Toyota Camry
Squeeky brakes
how bad do they squeak, is this after a recent brake job? minor squeak is normal and doesn't affect the performance of the brakes, u can apply a product call "brake quiet" to the back of the disk brake pads, it really works, contact Napa auto parts to buy this.
Sep 22, 2010 | 1996 Isuzu Oasis
Brake-shudder(extremely)
Reserface rotors on car and spin balance tires and wheels.
Nov 26, 2008 | 1998 Toyota Corolla
Televison & Video Logo
119 people viewed this question
Top Televison & Video Experts
