Question about Zenith Data Systems Zenith (OP-260-74501) Plug-In Module 24x CD-ROM Drive
CD Drive problem(s) - (AutoPlay and showing content on E Drive in My computer)
Greetings to all
I am having a bit of a problem with CD Rom on my laptop. When I insert some CD (VCD or DVD), it is not showing the content in My Computer>E Drive (Properties shows 0 kB occupied) nor it starts AutoPlay but it can be played by VLC Player manually (or some other media player). Installation CD's like Windows recovery cannot be opened due to this problem. I've tried to change the registry - useless.
And it all started when I deleted WinZip manually from all its contents since I was unable to remove it from Add/Remove Programs. (Having some problems there too, Norton AV cannot be deleted also, don't really know why).
So, if anyone can tell me what to do in this case to fix these problems I'd appreciate it a lot.
Thanks in advance
I install the windowxp but my problem is still.
the all drive open commonly on clik but c drive is not it show the autoplay option on rigth clik
Posted on Jul 09, 2009
    Genius:
  • 3,587 Answers
Get some fresh drivers for that dvd
Posted on Apr 23, 2008
I have a laptop hp pavillion 15 and I cant put cd in it?
What operating system OS? XP><? WHAT OS?
what is full model number or this 15- "????
the HP suport page shows 63 different model 15s , hark.
ok, did you try a store bought CD firs. CD-CA?
not copies or burned CD-r.
CD's come in 2 size, normal 800MB sizes and 200MB tiny.
many CD players not do the tiny ones, lacking spot there to hold it in place. (do find a pC that can copy this tiny CD to USB stick)
first try a real CD, say an install disk full size, CD (not dvd)
or a store bought CD-DA,compact disk digital Audio, say with
songs from say, Johnny Cash. (#1) then click the disk. in explorer.
the PC to AUTOplay a disks takes 3 things
1: autoplay turned on,
2: CD drive must work and be GOOD.
3: and real CD in the tray , closed. (real means with valid content)
#3 is easy no, use a real CD to test the CD, from store in the music department. (reading CD-r can fail on many older CD drives)
tests , many; , ill do some. now. (for sure a year 2000 PC)
then if say its a program disk, say you put in the HP install disk.
called the media kit, disk from HP, or from microsoft. (a real CD)
real means not CD-R , (recordables)
go to explorer, in windows 10 its now called, "THIS PC"
does the the CD show up in this true name Explorer.?
does the CD drive show up in Disk manager, in CP?>control panel..
does the CD drive show up in device manager>?
all those are a YES,
if all shows up, then look for program files on the disk using explorer.
do you see files, thre, (install disks)
one FILE might be setup.exe, can you run that.? double click it?
if yes, then autoplay is turned off in your unstated OS.
if not the CD drive is bad or the CD is not any good.
I have My Autoplay off since it was invented so viruses on said disks
can not autolaunch, a not so good thing.-
now 1 example (not XP,vista , w7,w8,w8.1 )
in windows 10, to turn on this autorun ( horror)
click settings in the run menu. w10
click devices
click autoplay on left side.
behold. turn it on or off, and blow the on button, pick a rule.
or turn it on and pick "ask me every time.".. for safety.
under removable drive.
tell OS , tell what PC this is, 15 does not answer that question
please. for 10x better help.
PS; click HP15 here and see all 63 models.
https://support.hp.com/us-en/products/laptops/hp-notebooks/
Jun 04, 2017 | HP Pavilion Computers & Internet
When disc is inserted it will not play
Enabling AutoPlay in Windows XP Enable through Windows Explorer
  1. Open My Computer
  2. Right-click the CD-ROM drive or other drive and click Properties.
  3. Click the AutoPlay tab. Within this section you will be able to specify all Windows AutoPlay features.
May 04, 2011 | Computers & Internet
My cd/dvd rom do not play when i i insert cd.what can i do?
Try navigating to Start Button/ My Computer/, then Double-click the CD or DVD drive. If no CD or DVD drive shows up in My Computer, there is a problem with the drive. if no disc shows up in the Drive, it is a problem with reading the media.
Mar 27, 2011 | Computers & Internet
I put in cd and it does not recognize it-i have a toshiba tecra 9000-do i have to press a key or something
The autoplay feature on some refurbished (and sometimes new) computers is at best unpredictable.
To find out if your disk is recognized, go to MY computer: It will display the drives and if they contain anything, it will show there. In the event the disk is not Labeled, double click on the CD rom icon, if the contents for the drive come up, your drive is ok, and the disk is too.
If the contents of the disk do not show up, but the drive is displayed, recycle the drive mechanism.
(open/close)
If that still does not do the trick, reboot your computer, and try again.
As a last resort, an external drive via a USB connection will give you the drive contents.
Good luck and don't forget to vote.
Oct 12, 2010 | Toshiba Tecra 9000 Notebook
My CD ROM's Auto-load/Auto-exe is not working. I put in CD software and it doesn't load it. I put in a DVD movie and it doesn't auto-play.
Enabling AutoPlay in Windows XPEnable through Windows Explorer
  1. Open My Computer or Explorer
Enabling AutoPlay in Windows7 and Vista
http://www.techtalkz.com/windows-7/516004-how-configure-autoplay-settings-windows-7-a.html
Aug 23, 2010 | HP Pavilion dv6000z Notebook
My dell studio 1535 will not open a cd, when I insert the cd nothing happens. I just had a new hard drive installed..
If the CD-ROM will boot from a recovery CD, then this would indicate a Windows software problem instead of a CD-ROM issue. It can usually be attributed to a corrupt driver. To reinstall the drivers:
1. Go to Start>> Right click My Computer>> Properties>> Hardware>> Device Manager.
2. Expand DVD/CD-ROM Drives line item.
3. Right click on the items below and select Uninstall drive on the resulting menu.
4. Re-boot the system and Windows will automatically detect the CD-ROM drive and re-install the drivers for you.
Try a different media - some brands will just not work correctly with a given CD-ROM drive. Watch out for compatibility problems with Maxell, Memorex and Macromedia CDs.
Check for unusual noises, maybe a ticking type noise. This could indicate a cracked disk. Or, the media may not be seated correctly on the spindle.
Is the access light on?
Is the CD Clean?
Check error messages in Event Viewer. Here's how:
Go to Start>> Settings>> Control Panel>> Administrative Tools>> Computer Management (or Event Viewer)
Check your manufacturer's web site for software updates and drive updates. Check for QSI firmware updates.
For DVD - Are you trying to write to a DVD that is READ ONLY?
If all has failed, you may be faced with performing a complete Operating System Recovery or Repair (preferred).
If nothing above has worked for you, then you may need to take the drive in to a service facility for repair or replace the drive.
Jan 01, 2010 | Dell Studio 1535 Notebook
My computer does not have a AutoPlay feature in it so I can insert and run my Cd-ROM PC games. It must have come with one but I can't find it.
Enabling AutoPlay on a data and audio CD (Windows XP)
  2. Highlight the CD-ROM drive, right-click the CD-ROM drive and click properties.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 26, 2008 | HP Computers & Internet
The setup wizard on the CD will not automatically run when inserted in the CD-ROM drive, what do i do?
  1. click on start
  2. My computer
  3. right click on CD/DVD Drive
  4. Left click auto run
selecting My Computer, right-clicking the drive that contained the CD-ROM, and selecting Properties. click the AutoPlay tab and select the Select an action to perform option, then double-click the program to use to run the CD-ROM. This action launched the program on the CD-ROM. Note that simply highlighting the program you want to use and clicking OK or Apply doesn't work; you must double-click the program and force it to launch on the CD-ROM or DVD in the drive. The CD-ROM then ran automatically, using the program associated with it on the AutoPlay tab.
Apr 15, 2008 | Computers & Internet
My computer opens Lite On 5236 (drive E:) yet sees nothing?
when you check the properties of the device does it recognise the drive
Nov 16, 2007 | Lite On (SOHC5236V) CD-RW/DVD-ROM Combo...
Dvd/cd rom drives
i cnt run my dvd rom drive but only cd.disk
Oct 15, 2007 | ASUS 52x (CD-S520) QUIE TRACK BEIGE RETAIL...
Computers & Internet Logo
610 people viewed this question
Top Zenith Data Systems Computers & Internet Experts
David Payne
David Payne
Are you a Zenith Data Systems Computer and Internet Expert? Answer questions, earn points and help others
