Question about Kenmore 54501 Dehumidifier
Problem with fan
I've had this humidifier for a few years. Has always run well but towards the end of last year it ran extremely loud all of a sudden. From doing some reading it seemed this was due to the fan malfunctioning. I was able to remove the back of the unit and took a look at how it was running without the back cover. The fan is in fact not working properly. It does move, but after going around one orbit it seems to catch, stop for a few seconds, go around for another orbit, but never starts operating fully. I've already taken enough of it apart where I don't want to proceed without some clue of what I'm doing. So can anybody tell me if the unit is completely shot, and if not is there anything I can do that would be an easy fix? Thanks.
    Genius:
  • 1,073 Answers
Just replace the fan motor is the proper fix. you may dissasemble the fan motor and it may run for a while but the cost of a compressor is not worth the cost of the fan motor
Posted on Apr 23, 2008
Frigidaire dehumidifier model # FDL50S1 clicking very loudly.
If the unit is not running fully, but you have this noise, sounds like the internal fan might be the culprit. Contact your manufacturer for further options.
Aug 24, 2012 | Frigidaire Fdl50s1 Air Purifier &...
Our daewoo humidifier model dhc-250 date made 02/04 runs but seems like voltage goes up and down if on low or high fan and cont. cleaned all out ran great last year but now runs can hear power click up and...
Quite frankly, from what you described, you may need to have the refrigerant gas in the compressor drained and recharged. As. it sounds like the compressor wants to turn on, but lacks the ability due to low refrigerant or a faulty condenser switch. Either one can be repaired. But, if you don't have the experience to deal with it, it's best left to the pros.
Hope this helped you to troubleshoot and solve the problem.
Jun 21, 2011 | Daewoo DHC250 Dehumidifier
MY unit has become increasing noisy and the fan is the mane cause. The fan is now making different noises at differing levels high and low of loudness, and it often quits running all togetger. It is also...
It sounds like the bearings in the motor are worn out, especially as you said it quits running at times. You should be safe in just replacing the fan motor, but check the fan blade to make sure it isn't out of balance for any reason(dirty, missing a balance weight, or bent). Hope I was of assistence!
Nov 14, 2009 | Kenmore 53701 Dehumidifier
De Longhi DE220 De-Humidifier not collecting water
Hi there - you have to vacuum the filter several times. You can pull it out of the back left hand side of the unit. Vacuum it several times, and then start the unit on the lower fan setting, at a humidity level of around 60%. It will kick in after a bit, and then you can start adjusting the humidity level to where you would normally use it.
Sometimes - after you have vacuumed the filter, it still doesn't work. I used my fingers to pick lint off the filter, and ran a BIC safety razor over it as well, to try and get more out of the filter. You can also wash the filter in warm water, and leave it to dry over night. Don't put it back in until it's completely dry.
This will work! Cheers... E
Sep 12, 2008 | DeLonghi DE500 Dehumidifier
Unbearable noise
Mine does the same thing, for the third time. Seems the plastic fan on mine, lasts a little over a year. Not hard to change, just a bad design on the part. I'm ordering an extra tis time, to save on freight.
Sep 05, 2008 | Fedders A7DH65B2A Dehumidifier
Clean the hose (it's full of black gunk)
Jun 30, 2008 | Kenmore 54501 Dehumidifier
Does not collect water
ok Carmo
first remove the back of the unit and turn it on. it sounds like the fan motor may not be working.there by making the dehum get hot. make sure your filter and coils are cleaned. you may need a new motor. if so buy a new motor and fan blade.be careful with the 5/16th nut holding the fan blade. the blade might look good but you have to check the hole where it rides on the motor shaft. if you into the hole it should look like the letter "D" because the motor shat is shaped that way.---good luck
Nov 11, 2007 | Kenmore 54501 Dehumidifier
Goldstar dehumidifier won't stay on
Check the relative humidity in the room or space where you are operating the dehumidifier. Damp feeling and actual humidity level are two separated items. Humidifiers will run for a few minutes until it is signaled that the humidity is already low enough and then shut down.
Oct 27, 2007 | Goldstar DH504EL Dehumidifier
No water collection
compressor may be starved for freon or blockage in freon line...tech must troubleshoot.
Jun 08, 2007 | LG LD65EL Dehumidifier
Kenmore 54501 Dehumidifier Logo
170 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
