Question about Nvidia Quadro NVS 280 (64 MB) Graphic Card
How to configure modem in fedora 7,8 and Linex? tell me step by step
  • Anonymous Aug 11, 2008
    on Dell inspiron 4150
    Scholar:
  • 94 Answers
try this guide ->LINK<-
Regards
Philip
Stick with Linux, it's not Micro$oft ;-)
Posted on Nov 03, 2008
I need the sizes & quantity of the nuts & bolts
Linex probably can tell you what ships with your tower.
Apr 16, 2014 | Linex International Linex X 615 Power...
Want to change Linux Fedora 17 ip from 10.42.x.x to other range
Yes, the router dictates the IP and range. So if you have modem for your ISP connection. Just attach a router.
Example of my Belkin.
Dec 07, 2012 | Computers & Internet
I need Fedora 15 drivers for a MultiTech MT5634ZBA modem... ugg.
You must have the most recent kernel, 2.4.2 or higher. You will also need specific modules for installation, they are explained below. The MT5634ZBA-USB has been tested successfully in Mandrake 8.1 and RedHat 7.2. Please read the whole document, as some steps depend on how the Linux system was built. You need to select the USB Modem (CDC ACM) support kernel option. If you build as modules, you need to install the acm.o option. You need to set up the device node entries for the various modems. You can use up to 32 modems with this driver. Use the following commands to set up the first four: mknod /dev/usb/ttyACM0 c 166 0 mknod /dev/usb/ttyACM1 c 166 1 mknod /dev/usb/ttyACM2 c 166 2 mknod /dev/usb/ttyACM3 c 166 3 You should now be able to use a terminal emulator program to attach to this device and connect to your modem or other terminal device. If your current version of Linux has the ACM driver compiled into it, then you're ready to roll. If it has the driver built as a module, then you'll have to enable the driver with the following command: modprobe acm At this point, you may have to unplug the modem's USB cable and then plug it back in (this isn't necessary if you're using kernel 2.4.X). You should see the modem's lights come on. If you see some activity lights on the modem, type the following: lsmod This command will display a list of loaded modules. The ACM module should be displayed as loaded. Now that you've got the driver loaded, you need to set up the device node (in /dev) for the modem. You can use up to 32 modems with this driver, but most people will only need to configure one. To set up a modem, use the following command: mknod /dev/usb/ttyACM0 c 166 0 You should now be able to use a terminal emulator program to attach to this device and connect to your modem or other terminal device. Going one step further, you can set up a symbolic link from /dev/modem to the ACM modem device. This is accomplished by using the following command: ln -s /dev/usb/ttyACM0 /dev/modem That way, KPPP and related applications can all refer to the modem as /dev/modem without caring what type of modem it is. Models: MT5634ZBA-USB If the above document doesn't get you going, send me a private email & I'll have a Multi-Tech Systems, Inc. Technical Support Rep. get in touch with you ;-)
Aug 27, 2012 | fedora Linux Operating System
How to install linux fedora 7, already i am using windows 7, now i want to use dual os's , please tell me how to install linux.
WARNING: I will not be responsible for any data loss that occurs. It is recommended to backup your hard disk to external media before commencing any of these operations. 1. Download and burn the Fedora LiveCD. It is recommended that you use the latest version, Fedora 14, instead of 7, but you can use Version 7 anyways. 2. Boot up with the Fedora LiveCD. Select Install. 3. Follow the instructions displayed onscreen. When you reach the partitioning screen, you will need to resize your Windows partition. Resize it to a reasonable size (1024MB =1GB). Leave at least 5GB for Fedora to install. 4. After resizing, select the "Use Free Disk Space" option, and continue installing. 5. Your system will be installed with Fedora and the GRUB bootloader. The GRUB bootloader will allow you to boot into both Windows and Fedora.
I hope this post helps you. I appreciate your vote very much!
Mar 03, 2011 | fedora Linux Operating System
Problem while installing Windows 7 and Fedora Core 10
OK, FIRST, take off the fedora drive, and get that working first, Now, ADD the other drive, and configure that. You may have to pop your Windows,DVD in and do a Startup repair, after that then you can can select either one. Check this link out below it is a tutorial, of how to do what you want.
http://www.thpc.info/dual/win7/dualboot_win7+fedora11_grub_on_win7.html
Apr 15, 2010 | Compaq Presario 700 470024-192 Notebook
How to install hantel htp800a modem in fedora operating system i want steps
i have hantel htp800a how to get modem driver to connetct to pc
Mar 31, 2009 | Computers & Internet
Configuring
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router and repeat the same steps.
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username (email address format) and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, try to call supportrix
Jul 10, 2008 | Edimax BR-6104K Router (br6104k)
I lost my belkin install cd
hello!
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, call supportrix and use supportcall as your promo code for 1 free technical support.
Jun 02, 2008 | Belkin (F5D7633UK4A) Wireless Router
Can't seem to hook up D-link router to my Arris cable properly
hello!
note:
May 29, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
HOW TO CONFIGURE THE ROUTER
hello!
May 08, 2008 | SMC Barricade g SMCWBR14-G (662698582192)...
Nvidia Quadro NVS 280 (64 MB) Graphic Card Logo
62 people viewed this question
Top Nvidia Computers & Internet Experts
David
David
Alun Cox
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
