I have a Kleenmaid LWK74AW-3050 washing machine and the rubber drive belt is screaming and the electric motor is cutting out on startup. Also there is a drip of water coming from the bottom of the tub on the wash cycle. Its as if the bearing in the bottom of the tub is seizing up.
3 Suggested Answers
SOURCE: KleenMaid Washing Machine shop manuals/repair instructions
There are manuals available but these only tell you about the parts of the machine and the different cycles etc. Its a workshop manual that you need and these are not discussed anywhere on the net, Im not sure these were ever produced.
Posted on Sep 12, 2010
dcramer531
  • 1654 Answers
SOURCE: Our Washing machine will not
Check the lid switch, if the switch does not make or is bad the unit will not spin.
Worst case scenario is the motor coupling went bad, does it was and agitate ok, but not spin? If everthing else works then It probably is the lid switch
Posted on Nov 18, 2010
Kleenmaid LWK74AW-3050. How do I clean the pipe/hose from the back of the washing machine to the tub??
Inlet hoses connected To washer have a screen trap in them disconnect and clean.
Oct 22, 2015 | Washing Machines
Kleenmaid
You should be able to download the instructions from this site.
http://www.kleenmaid-appliances.com.au/assets/pre2011_manuals/Use&Care/WM/kleenmaid/39237R4_LWK23_24_Op_Inst.pdf
In case you have a specific problem with the washer please describe in the comment section and the right expert on this site should be able to assess it.
Sep 19, 2014 | Washing Machines
Our Washing machine will not spin out on any spin cycle. Model Number is LWK74AW - 3050
Nov 18, 2010 | Washing Machines
Dryer part, smells burnt and is extremely loud
If you notice a burningsmell in your washing machine, the cause could be any number of things. Regardless, this is one smell you shouldn't ignore. It's important to quickly diagnose the problem and find the solution.
The "Burning Belt" Smell
Older, top-loading washing machines use a belt drive to transport energy from the motor to the transmission and pump. The belt can prevent costly repairs to the motor or transmission by slipping, stretching, or breaking if there is a malfunction in the machine. If the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell.
The solution is actually quite simple: you need to replace the drive belt on your washing machine. You can call a repairperson or, if your washer is under warranty, the manufacturer. If you or someone you know is handy, you can replace the belt yourself. The belt is located either from the back access panel or from the underside of the washer.
Most new washing machine models are "direct drive." This means they do not use a belt. The motor is directly connected to the transmission. If you have a direct drive machine and your washer smells like it is burning, read on.
Electrical Problems
If your washer smells and you have a direct drive machine, it may be the motor, transmission, or both. If these are shot on your washing machine, the result may be an electrical burning smell. Both are necessary to run your washing machine and can be costly to repair. The first thing to do if you notice an "electrical" smell in your washing machine and not a "rubber" burning smell, is to unplug the machine and call the manufacturer or a repairperson.
An electrical burning smell may also be caused by a water leak coming into contact with electrical wiring. Both are major concerns and should be addressed immediately. A water leak can cause structural damage in your home and can short out the electrical wiring in your washer and cause additional damage to the machine.
Other Causes
Another more likely cause of a burning smell in your washer is overloading. Adding too many clothes to your washing machine can stress the motor or transmission, causing them to overheat or malfunction and emit a burning smell. For top load washers, overloading can cause the agitator to freeze or malfunction, stressing the drive belt and causing friction, which could emit a burning rubber smell.
To prevent overloading, know the size of your washer. They are measured in cubic feet. In addition, know how many towels, pants, shirts, and other items you can safely load. When it doubt, do smaller loads. Not only will this prevent overstressing the machine, it will also ensure clothes are thoroughly cleaned and rinsed.
Nov 07, 2010 | EuroTech Washing Machines
Remove agitator washing machine
Pull off fabric softener dispenser, then there will be a screw holding agitator in middle you will need a rachet, socket, and at least a 10" extension. Lossen and remove screw and pull from bottum of agitator.
Jul 05, 2010 | Washing Machines
Oct 12, 2007 | Washing Machines
Washing Machines Logo
259 people viewed this question
Top Washing Machines Experts
