Question about Cnet CN UM56-RS (CNUM56-RS) Modem
Help me plz
I have a cisco router 1841 and
  • CNet 56K V90 Data/Fax modem
    when i connect them to each other i can't configure my cisco router.i don't know how to set the commands would you please help me or if you have any sample configuration?
  • regards
  • Posted by on
    • 85 Answers
    Cisco routers make use of an IOS software for configurations.
    you have to connect the router to a computer system through an hyper terminal program in order to access the router command interface,there is no way you will be able to configure this router without having cisco configurations knowledge.
    the steps could be complex/complecated for a novice.but all the same,
    after running the hyper terminal program on your computer to connect the router(start-accessories-communication-hyper terminal) make sure you use cisco serial cable or a cat5e roll over cable.
    press the enter key once and type 'enable' then press enter,
    configure terminal,to take you to a global configuration mode.
    i will advice that you should contact a cisco person in your area for help
    Posted on Apr 24, 2008
    Connect to cisco 1841
    This is more of a business unit. It requires a serial port connection and a fair amount of CISCO networking engineering knowledge. It is command only. No GUI interface.
    Jan 30, 2013 | Cisco (1841) Router (cisco1841)
    Tip
    Cisco 1841 Router, Hot Sales Product Cisco 1800 Business Router
    The Cisco 1841 router is designed for secure data connectivity and provides significant additional value compared to prior generations of Cisco 1700 Series routers by offering more than a fivefold performance increase and integrated hardware-based encryption enabled by an optional Cisco IOS Software security image.<br /><br />The <a href="http://www.router-switch.com/cisco1841-p-97.html">Cisco 1841</a> dramatically increase interface card slot performance and density over the Cisco 1700 Series while maintaining support for more than 30 existing WAN interface cards (WICs) and multiplex trunk cards (voice/WICs [VWICs]-for data only on the Cisco 1841 router).<br /><br />The <a href="http://www.router-switch.com/cisco1841-p-97.html">Cisco 1841 router</a> offers embedded hardware-based encryption enabled by an optional Cisco IOS Software security image; further enhancement of VPN performance with an optional VPN acceleration module; an intrusion prevention system (IPS) and firewall functions; interfaces for a wide range of connectivity requirements, including support for optional integrated switch ports; plus sufficient performance and slot density for future network expansion and advanced applications as well as an integrated real-time clock.<br /><br />Cisco 1841 router Product Details<br />Product Description Cisco 1841 router<br />Device Type Router<br />Form Factor External - modular - 1U<br />Dimensions (WxDxH) 34.3 cm x 27.4 cm x 4.75 cm<br />RAM 128 MB (installed) / 384 MB (max) - SDRAM<br />Flash Memory 32 MB (installed) / 128 MB (max)<br />Data Link Protocol Ethernet, Fast Ethernet<br />Network / Transport Protocol IPSec<br />Remote Management Protocol SNMP<br />Digital Signaling Protocol ADSL over ISDN<br />Features Cisco IOS IP Broadband , firewall protection, 128-bit encryption, hardware encryption, VPN support, VLAN support, Intrusion Prevention System (IPS), 256-bit encryption<br />Power AC 120/230 V ( 50/60 Hz )<br />System Requirements Microsoft Windows 98 Second Edition<br /><br />P.S. If you would like a new sealed Cisco 1841, the competitive price offered at RouterSwitch.com is US$586.00 per. Visit Cisco 1841 to see more...<br /><br />Notes: Router-switch.com is a World's Leading <a href="http://www.router-switch.com/">Cisco Supplier</a>, founded in 2002. It sells new, used and refurbished Cisco network equipment including Cisco routers 800/1800/1900/2800/2900/3800/3900 series, Cisco switches, Cisco Firewalls Security, Cisco IP Phones VOIP, etc.<br /><br />
    on Jul 07, 2011 | Computers & Internet
    HP USB Modem does not break dial tone
    If the information connected to your post is all correct (56k V90 usb), and you are using one line for both the internet and the fax, you should hang up from the internet before you try to dial out the fax.
    You have not indicated your PC model, so I don't know what operating system you are using. For XP and newer versions, you have to set up and configure the fax using the wizard or configuration software. If you have not done that yet, you need to.
    In xp, go to start, Programs , Accessories , Communication , Fax , and then click Fax Console.
    You said your computer is new. Win 7 and Vista are much the same:
    1.Click the Start button , click All Programs, and then click Windows Fax and Scan.
    2.At the bottom of the left pane, click Fax, and then click New Fax on the toolbar to launch the Fax Setup wizard.
    3.Click Connect to a fax modem and follow the instructions.
    You also need to make sure that your fax/modem is correctly listed in the control panel. In XP, start, control panel, printers and devices. If you do not have a fax printer listed, you need to "install a local fax printer."
    The installation wizard should work in both OS without much trouble. If you do have difficulty, Microsoft and adobe both have "virtual printers" you can use. Look in Microsoft office or online.
    Also check control panel of 7 to make sure that your modem and fax are listed correctly. Thanks for using Fixya.
    Jan 01, 2010 | HP (56K V90 USB) Modem
    G'day, I have a Cisco 1841 router which I would like to get the cable or pinouts to connect a PSTN modem. The aux port is RJ45 and the modem db25
    Here is the pin out:
    RJ45 DB25
    1 -------- 4
    2 -------- 20
    3 -------- 2
    4 -------- 7
    5 -------- 7
    6 -------- 3
    7 -------- 6
    8 -------- 5
    Jun 30, 2009 | Cisco (1841) Router (cisco1841)
    Cisco 1841 Freezing at System Configuration Dialog
    Try resetting its firmware or try booting it in another location.
    May 08, 2009 | Cisco (1841) Router (cisco1841)
    Ethrnet problem for cisco 1841 router?
    Hi
    You must enter the interface configuration mode and issue the command:
    no shutdown
    Mar 19, 2009 | Cisco (1841) Router (cisco1841)
    Cicso router 1841 not connecting to the internet
    When using Public IP addresses on one interface, usually facing your ISP, and using Private IP addresses (AKA RFC 1918) on another interface, usually facing your LAN, one needs to utilize network address translation (NAT) in order to connect LAN computing resources to the Internet.
    Cisco has a fantastic article on how to perform the necessary procedures on their web site.
    http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080093f8e.shtml
    Sep 06, 2008 | Cisco (1841) Router (cisco1841)
    Cnet CN UM56-RS (CNUM56-RS) Modem Logo
    414 people viewed this question
    Top Cnet Computers & Internet Experts
    Prashant M
    Prashant M
    Marcin
    Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
