Question about Motorola Mobility RAZR V3i Cellular Phone
Motorola V3i, has just stopped working without explanation. Will not come on, will not charge battery. No visible signs of damage. Have swapped with charged battery from another phone of same make and model (wife and children all have same model purchased at same time) but this has no effect. This has suddenly happened to 2 out of the 5 phones in the house.
3 Suggested Answers
vqcb43
  • 1623 Answers
Mobile Phones and Acessories
    Verified Fixya Pro
    SOURCE: Flashing my Motorola Dafy Plus failed... made a factory reset... battery doesn't charge/charges very slowly... How can I make it work again???
    Nico
    This site doesn't help with this sort of thing but others have found solutions on XDA developers for this sort of thing. I don't endorse it but it may work.
    Motorola Support
    Posted on Dec 27, 2014
    vqcb43
    • 1623 Answers
      Verified Fixya Pro
      SOURCE: my phone stopped working and won't charge........
      Charlene
      Have you tried another charger? Try also to take your battery out. Then hold power button for 15 seconds. Then put the battery back in and charge for 2 hours then check the phone again.
      Do you see any lights when you plug the phone In? Does the screen light up when it is plugged in? Does the battery look normal or is it puffy?
      Mark
      Motorola Support
      Posted on Jan 04, 2015
      Motorola Razr v3i does not charge. When you put
      the only things i can think to tell you are
      send it in for repairs,
      or get an external charger.
      the charger would probably be less expensive
      Oct 26, 2009 | Motorola Mobility RAZR V3
      V3i Phone Boot Loader
      Stuck in a bootloader mode ,the V3i won't charge. Get hold of another v3i nad replace to charge own battery . after that place this charged bty in your stuck v3i and reflash with a MP that works (the last one u tried probably won't get loaded so get a fresh one)
      Jul 09, 2009 | Motorola Mobility RAZR V3x Cellular Phone
      Invalid battery
      Pull out the battery *while the phone is on*. Wait 15 secs then put battery back in and turn phone on. That should fix it.
      Nov 13, 2008 | Motorola Mobility RAZR V3i Cellular Phone
      Won't charge
      You have taken the appropriate steps. Now you have determined that the problem is not battery, it is the phone.
      Most likely causes are:
      • Bad connection between battery and phone due to damage
      • water damage to the phone or corrosion
      • leads from the battery to the phone are broken.
      Either way the phone will require warranty work or replacement.
      Jun 23, 2008 | Motorola Mobility RAZR V3i Cellular Phone
      NTO ABLE TO CHARGE BATTERY
      Try charging the battery for a long time.
      Feb 29, 2008 | Motorola Mobility RAZR V3i Cellular Phone
      New phone razr v3i charging issue
      Have to phone sent in for warranty and request a "loaner phone"... sounds like the power drain is too high on the device and it needs service or replacement... another sign would be the unit heating up hotter than normal - is that happeneing?
      Feb 08, 2008 | Motorola Mobility RAZR V3
      Charge by usb cable
      When we connect the phone to PC it automatically start charging but after 5 mins it stops its because we do not take any kind of action i.e. if you will send some files to phone or will operate phone from PC it will keep charging otherwise as you have said it will stop.
      Jan 17, 2008 | Motorola Mobility RAZR V3i Cellular Phone
      Motorola v3i
      Keeps entering 6's, tries to go online, tries to increase ring volume, keypad flashes....resetting by switching on/off or removing battery does not work. It's not water damaged. Help !!!
      my v3i keeps connecting to the internet by its self and flashes error GPRS or somthing like that,across the screen and no buttons work at all, removing the battery is the only way to stop it. please help.
      Have the same problem? Click Here
      Nov 15, 2007 | Motorola Mobility RAZR V3i Cellular Phone
      Razr V3i charging problem
      Hi V3 is very fragile and if you use the incompatible accessories, you can ruin their ports easily. One weak point of V3 Phone is the SIM card Port is not an opening flap like other GSM phone but using pin and spring Port style which is mean you have to push your SIM card in and use the SIM Card edge to push the pin down in order to contact with SIM metal area interface. But by pushing force is varied from users so too strong and too hurry will damage the pin. If one of the pins is damaged, when you slide the SIM card in, the contact is missing of one or two pins due to damaging of the pin cause the error message "Insert SIM". In this case, only way is needed to replace the SIM Board underneath. If you can do it yourself, please follow the instruction pictures below. If you are not sure and never do this before, I suggest you send the unit to Motorola Repair Center. Your SIM Card Board and charging port will need to be replaced. http://www.itsjustmerob.com/files/V3_Razr-repair.pdf This is a Full Motorola V3 Officially Service Manual and even the Motorola Repair Center also has this one. so copy this link and print it out. Around hundreds plus pages but can be your Guide which you cannot find anywhere else. I gave it to you free but I have purchased it before. Hope that you can get it fix. Other solution is looking V3 parts on sale a lot on Ebay and use them to replace part to your phone will be cheaper if your phone is no longer under warranty. If it is still under cover then send the unit to them and don't spend time and money to do it yourself. But if it is out of warranty and want to avoid costly repair then use the method in the manual I provided you and you will be able to get your phone fix. Good Luck
      May 13, 2007 | Motorola Mobility RAZR V3
      Motorola Mobility RAZR V3i Cellular Phone Logo
      43 people viewed this question
      Top Motorola Mobility Cell Phones Experts
      Virgil Wolter
      Level 1 Expert
      vince
      Rami Obeid
      Level 1 Expert
      Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
