Question about Alcatel OmniStack Software Advanced Routing (OSTK-SW-AR) for PC
Omnistack 6148 data switch firmware
Main board firmware failure on system switch on.
Recover password reset
You may have to update the firmware using a com port cable - check here for information about your product and to get firmware
https://service.esd.alcatel-lucent.com/portal/page/portal/EService/product_specific_support_media?p=OmniStack_6x24_6148
Apr 13, 2014 | Alcatel OmniStack 6148 (OS-6148)...
How do I program zonig for my Ademco 6148 pad
The 6148 keypad is a fixed english keypad. It is possible to program your system from a fixed english keypad, but it is very difficult. an alpha keypad shows text descriptions of the programming fields. The model number is 6160. If you are doing your own programming, I would suggest replacing the 6148.
When programming, you're programming your alarm panel, not the keypad. The keypad is just an interface to the panel. If you have a tan box in your basement or a closet, that is your panel. There will be a sticker on the inside of the door of the panel that will tell you the model of the panel at the bottom. It will say Ademco Vista 10, 15, 15P, 20, or 20P.
From there you can go to the link below and find the installation and programming manual for your panel.
http://panelguides.com/panel-guides?task=viewcategory&catid=521
Hope this helps.
Mar 18, 2011 | Ademco 10) Ademco 6148 Keypad Fixed...
I am unable to access my omnistack 4024c using telnet or through Hyperteminal, how i can reset the switch to its factory settings
  1. You need to connect via a console serial cable with suitable terminal software running.
  2. Power on the switch.
  3. Hit any key when prompted by boot process about 10 seconds after power-up to get to boot/diagnostic menu.
  4. Enter c
  5. Press enter (which accepts the defaults) until line displays: "Boot Flags :0xb"
  6. Enter 0x1000
  7. Press enter until back at the "[Boot]:" prompt
  8. Enter S to save settings (thats a capital S)
  9. Enter @ to boot
The switch should now be back to factory defaults.
Mar 14, 2011 | Alcatel OmniStack 4024C Networking Switch
Invalid header
You are seeing the "Invalid Header" message on the LCD display on the T2250 because the pritner is in "boot" mode, which is the firmware download mode and is detecting data being recived is not a correct firmware file.
The most likely cause for this problem is the pritner has defaulted to 'Firmware Download Mode" due to a problem with either corruption to the firmware or damaged / faulty EEPROMS. When print jobs are sent to the pritner the pritner is expecting firmware and recognises the data it is reciving is not correct for a firmware file.
The solutions to this problem are;
  1. Power the printer OFF, disconnect the printer from the computer system, and any external print server (eg JetDirect etc). Power the printer back on, if the error is resolved check the method of connecting the printer to the computer system to ensure there is no damage to cables etc.
    If the printer displays "BOOT" on the display this indicates the printer is in firmware download mode.
  2. If the display reads BOOT first try reloading the firmware you may find details and firmware on the following web site,
    http://support.dascomeurope.com/index.php?option=com_docman&task=cat_view&gid=123&Itemid=48&lang=en
  3. If loading the firmware fails this indicates a logic board fault, the main logic board would need to be replaced to resolve the issue
Feb 18, 2011 | Tally T2250 Matrix Printer
To setup multiple default gateway in a switch
Details here
http://www.compucanjes.com/manuales/omnistack_5024.pdf
Jun 22, 2010 | Alcatel OmniStack Software Advanced...
I get a blank screen and 4 beeps what's the problem?
This could happen when the RAM contact is not proper, may be due to dust. Remove the memory modules from DIMM slot, clean it (no moisture please) and reinsert it. This could mostly solve your issue.
Please come back and rate my solution if it turns helpful for you or also if you need more clarifications. Thnx
Apr 01, 2010 | Fujitsu LifeBook A6110 PC Notebook
Dell Optiplex 725 Beeps at me at me at start up w/o complete start up. Screen Black. As if something is loose? Battery in Motherboard? Did something short out?
POST Beep Codes: OptiPlex GXi If the monitor cannot display error messages during the POST, the system may emit a series of beeps that identifies the problem or that can help you identify a faulty component or assembly. The following table lists the beep codes that may be generated during the POST. Most beep codes indicate a fatal error that prevents the system from completing the boot routine until the indicated condition is corrected.
Beep Code Error Probable Causes 1-3 Monitor not detected Disconnected or faulty monitor 1-1-3 NVRAM write/read failure Defective system board 1-1-4 BIOS checksum failure Faulty BIOS or defective system board 1-2-1 Programmable interval-timer failure Defective system board 1-2-2 DMA initialization failure Defective system board 1-2-3 DMA page register write/read failure Defective system board 1-3-1 Main-memory refresh verification failure Faulty or improperly seated DIMM or defective system board 1-3-2 No memory installed No memory installed or faulty or improperly seated DIMM 1-3-3 Chip or data line failure in the first 64 KB of main memory Faulty or improperly seated DIMM 1-3-4 Odd/even logic failure in the first 64 KB of main memory Faulty or improperly seated DIMM 1-4-1 Address line failure in the first 64 KB of main memory Faulty or improperly seated DIMM 1-4-2 Parity failure in the first 64 KB of main memory Faulty or improperly seated DIMM 2-1-1 through 2-4-4 Bit failure in the first 64 KB of main memory Faulty or improperly seated DIMM 3-1-1 Slave DMA-register failure Defective system board 3-1-2 Master DMA-register failure Defective system board 3-1-3 Master interrupt-mask register failure Defective system board 3-1-4 Slave interrupt-mask register failure Defective system board 3-2-4 Keyboard-controller test failure Faulty keyboard controller (defective system board) 3-3-4 Screen initialization failure Faulty video subsystem (defective system board) 3-4-1 Screen-retrace test failure Faulty video subsystem (defective system board) 3-4-2 Search for video ROM failed Faulty video subsystem (defective system board) 4-2-1 No timer tick Defective system board 4-2-2 Shutdown failure Defective system board 4-2-3 Gate A20 failure Defective system board 4-2-4 Unexpected interrupt in protected mode Defective system board 4-3-1 Memory failure above address 0FFFFh Faulty or improperly seated DIMM 4-3-3 Timer-chip counter 2 failure Defective system board 4-3-4 Time-of-day clock stopped Bad battery or defective system board 4-4-1 Serial-port test failure Faulty I/O chip (defective system board) 4-4-2 Parallel-port test failure Faulty I/O chip (defective system board) 4-4-3 Math coprocessor failure Faulty microprocessor chip or system board 4-4-4 Cache test failure Defective microprocessor or system board
Mar 30, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
It says that it has faild to load main image switch to recovery moad
try resetting the device first you should slide the Power switch up and hold it for approximately 20 seconds.
then. release the Power switch once the device is powered down.
Turn the device back on.
if that does not work then download and install sansa firmware updater from this link
http://kb.sandisk.com/app/answers/detail/a_id/156/kw/firmware/r_id/101834
if your problem is not solved after this then format your device.FORMATTING WILL ERASE ALL YOUR DATA SO ITS ADVICED TO BACK UP YOUR DATA BEFORE FORMATTING
From the Main Menu, select More > Settings/Options > System Settings > Format.
Mar 07, 2010 | SanDisk Sansa e260 MP3 Player
It is having a problem with the loading the main
Need firmware for OS-4024c
Firmware, if available, will be found on the manufacturers web site only.
Jun 09, 2017 | Alcatel Computers & Internet
Computers & Internet Logo
112 people viewed this question
Top Alcatel Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you an Alcatel Computer and Internet Expert? Answer questions, earn points and help others
