I use my LG DR787T DVD Recorder to record episodes of TV programs, so that I can watch them when I have time, and not take up space on my DVR. After recording a one hour episode, it usually lets me record another, and another, after shutting off after each recording. When I had 4 tv shows recorded, I would then finalize the dvd, and take it to my computer to convert it so that I could watch it on my ZUNE. Now, after recording one episode and shutting off, I try to record another program, and it says that I have "NO DISK." Is there any solutions to this problem. I'm using the same brand of dvds that I've always used, but nothing seems to work.
Try inserting your DVD media into the PC and doing a 'quick format'. The LG is not seeing what it considers to be media that it can use. It is not seeing that you have inserted recordable media. Sometimes you can reformat the DVD or do a quick media erase, and the LG can then put on its blank "squares" that is uses for its menu selection. I think that it what it does when it 'initializes' a new media. tom
Iam having LG RH 277 H HDD/DVD recorders
After dubbing from Hard disk to DVD-R disk , Iam able to play the disk on the same DVD recorder but after finalization Iam not able to play on same DVD recorder and also any other DVD players. Pl. note disks used are SONY DVD-R16 x 4.7 GB and I tried with different make disks also. Some times it works normal. Kindly advice. Date of purchase Jan 2008 from Australia and being used in India. Above problem started from jun2009.
where to find a region code hack for lg lra 850. If in setup menu, what letters (2) do I need to...
(More)
where to find a region code hack for lg lra 850. If in setup menu, what letters (2) do I need to enter to be able to play both American and European DVDs?
LGDR787T won't read DVD's. Took it apart and cleaned laser pickup but still sam eproblem. Says...
(More)
LGDR787T won't read DVD's. Took it apart and cleaned laser pickup but still sam eproblem. Says unrecognized disc. Needs a new drive. Is there a good place to pick up a drive for unit.
