Maytag PAV2300 Top Load Washer Logo
nathan almond Posted on Jul 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dropped steel wool pad between tub and front panel
How to take off the front panel?
Anonymous
Level 3:
  • Master 5,911 Answers
  • Posted on Jul 25, 2010
Anonymous
Master
Level 3:
Answers
5911
Questions
6
Helped
2734236
Points
22413
If the model number is correct, take a putty knife and insert it along the front seam where the top panel meets the front panel. There is a retaining clip about two inches in from each side. Push in with the putty knife while lifting on the top panel to release each side. Once released, the top panel will lift up exposing the screws that hold the front panel in place. If you have questions about any of these procedures, or require additional assistance, please post back and let me know. I hope this helps you.
1helpful
How can i remove tarnx from stainless steel
You can try CRC stainless steel cleaner
and if you have to following the pattern on the panel you can use a steel wool pad.
GE does have a refrigerator stainless steel cleaner kit available also.
What is the best way to sanitize my dogs bowl?
Sanitizing a dog bowl is quite simple. I recommend following these easy instructions:
Scrape off any excess food and rinse the bowl with dish soap and a sponge.
2. Rinse off and repeat step 1 if there are any leftover food particles.
3. Scrub the bowl with a fine steel wool pad and a mild cleanser.
4. Using a heavy steel wool pad you should apply more cleanser and scrub thoroughly.
5. Lastly, give the bowl one last scrubbing with a fine steel wool pad and then dry the bowl with some paper towel.
How to repair stainless steel on a dryer drum
For my Frigidaire manufactured Kenmore dryer, the stainless steel drum is part ordinary painted steel (front flange). That flange is part of the suspension for the drum. The flange rides on a nylon wear pad above the door. On both sides of the pad, there is a felt that is glued to the dryer front panel to act as a seal. What happens is that the paint on the ordinary steel flange rubs through and rusts, staining clothes during the drying cycle. I have to replace the nylon pad and felts every few years to combat the rusting issue. The felt and nylong pad assembly is glued to the cabinet flange using heat resistant adhesive.
Feb 25, 2012 • Dryers
Replaced front brakes and I still hear grinding, vechile is a 2004 4wheel drive chevrolet pickup
Rear disc brakes? My '04 KT2500 HD used similar "floating" rotors. Also, be sure to clean up or replace the metal guides the new pads ride on, mine have stuck and caused severe wear on the inside of the rotor, while the outside pad had minimal wear. I used a file to smooth up the notches on the pads and some steel wool to clean up the salvageable clip-on guides. Check the steel brake lines while you are down there for rust/corrosion, this is an issue for these trucks.
That is if you have the same braking system as the 2500, if not these guys have a series of great videos pertaining to your specific model.
http://www.youtube.com/watch?v=WH6wnmNkC0o
Ok key and bottom row keys on front pad dont work
the problem is as a result of accumulation of dusts underneath these buttons,
However,the solution is to take apart the buttons and apply spirit with the help of a cotton wool.to clean out the button pads,please avoid the use of excess spirit on the cotton wool which may have adverse effect on the panel below the button.
Take care
The front wipers on my 2005 focus are juddering and not clearing the front screen, a few months back I purchased new wiper blades from ford but this has not helped
clean very well and apply a rainx type solution.....
detailers use very fine steel wool and very light pressure to remove grimewith good window cleaner, the apply the solution...
just remember light pressure on the steel wool
Is posible to clean iron sole plate by steel
use the green no scratch pads,they are not so abrasive.
Sep 09, 2009 • Braun Irons
Scratch on stainless steel Kenmore fridge
brillo a little harsh, finer steel wool would be better ive even used the scour side of the sponge, using wd40 as a "cutting oil" lightly go over scratched area. look close and follow the grain of the S/S. just likje wood S/S has a grain direction
3answers
SCRATCHED STAINLESS STEEL SINK
Have you tried a really fine steel wool? I don't know if this would work. I have stainless steel farmhouse sink, front exposed all stainless steel. My contractor scratched it up horribly when he was putting it into the kichen. he fixed it amazingly with a fine steel wool pad. I don't know if your scratch is too deep for that but it couldn't hurt. The scratches on our sink were surface but very noticeable. Hope this helps.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
