The maximum is 500 GB (for the older-generation of IDE-interface disk-drives), since nobody makes IDE drives larger than 500 GB, or 2000 GB for the new generation of SATA disk-drives.
During the boot at the THINKPAD SCREEN press the Thinkvantage key ( Blue button ) it will launch rescue and recovery and allow you to reboot factory. This only works if you did not corrupted/deleted the rescue and recovery hidden partition on the HDD.
Otherwise you will need the rescue and recovery CD to proceed. IBM/Lenovo support should be able to provide you the CD.
Might be a defective hdd aswell, in this case to make sure you can run a DFT test, www.google.com -> Look up for " Test DFT " ( Drive fitness tool from hitachi, will make an hardware diag if hdd failure - error code 0x00 = everything fine, other code = Issue - You can look up for accurate code explanation on hitachi website )
thanks and have a nice day
J-
Hi there here is the instructions for replacing the keyboard of your laptop.Please note: dont forget to take the saftey precautions before opening your laptop.Like disconnect the powercord then remove the battery.
The ThinkPad T21 is a laptop with a single drive bay.
You cannot setup this laptop with two hard drives in any RAID configuration.
You can add an external USB hard drive and copy/backup data to this hard drive.
OR
You can connect this laptop to a network and copy/backup data to another computer/server on the network.
