How to Install mitsumi dvd r rw cd r rw in desktop case
I am unsure which way to jumper a mitsumi dvd+r/+rw & cd r rw drive and a Toshiba cd-rw/dvd-rom drive model #SD-r1202 mother board is running Pentium 3.
    Genius:
  • 3,587 Answers
Check both documentation packages for dvd and m/b...that will tell you, no doubt....without the m/b part number or maker, we can't do much for you here
Posted on Apr 23, 2008
I Firmware problem!!
check the jumpers are on master slave or both on CS Cable Select
Jul 15, 2010 | Dell Dimension 1100 PC Desktop
Won't burn DVD's after reinstalling Windows
Did you install the right drivers for the drive? It happened to me in the past where my DVD burner would only burns regular CDR's.
Jan 05, 2008 | Mitsumi DW 7801 TE (DW7081TE) DVD+RW...
My Toshiba ts-h653 cd/dvd RW drive failed. the
If the drive is trashed, just force the drawer open. If you don't want to do that, you should be able to disassemble the drive enough to get the disk out by removing screws... Sometimes the screws are underneath stickers, or warranty stickers, etc etc.
May 09, 2010 | HP Computers & Internet
I recently bought a lite on sohc 5236k, unfortunately it didnt come with a manual so i am unsure of the installation and set up can you help dave
If its an internal burner, you have to open your computer case, remove your old drive and note the setting ont he back, the "jumper" will be on either M, S or CS. Select the same setting on your new drive and replace it inside the case. For step by step
http://www.pcguide.com/proc/physinst/cd-c.html
Oct 04, 2009 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
Why wont my mitsumi cr-48x9te cd burner not work
Install a the appropriate cd burner driver software in your
laptop so that it will function properly. A CD disc installer normally goes with the unit you purchase. You
may ask assistance from the store where you buy your
CD burner. Or you can download it from the internet.
Just send in your comments through the e-mail.
Oct 04, 2009 | Mitsumi (CR-4804TE) CD-RW Burner
Installed Toshiba Samsung CD-RW/DVD Drive does not work
You will have to install the drivers that came with the drive. If you don't have the CD that came with it to install the drivers, you will have to search the Toshiba site for the specific model number of the drive. You should be able to download and install the drivers from their website. Hope this helps.
Apr 22, 2009 | Computers & Internet
Cd rom drive
Hi
Please use the Cd/Dvd Drive with the following specification:
CD-ROM/DVD-ROM/Disk drive
8X max DVD+/-RW Drive with DVD+R double layer write capability
Or
16X DVD-ROM drive, 16X/10X/40X CD-RW drive
Regards
ELLIN
Sep 20, 2008 | Dell Dimension 8200 PC Desktop
Install to computer problem
Sounds like a case of jumper settings. If the CD-RW was installed as secondary IDE to an existing hard drive which is the Master, pls set jumper to SL. They are located at the rear of the CD unit between the IDE connector and the audio out.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 19, 2008 | LG CED 8120B CD-RW Burner
I need help for this one
Hi Maja, When you wrote "CD-RW is recognized, but not opening" are you referring to the tray not sliding? If you are, then it is possible that it is a hardware problem with your CDRW, specifically the tray loading mechanism. Pls refer to http://www.fixya.com/support/t144167-cw088d_cd_rw_drive. Should this be not the case, pls post again. Cheers
Jul 18, 2007 | Mitsumi 's CR-485GTE 54x32x54 CDRW...
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
