Question about Mitsubishi VS-55601 55" Rear Projection Television
Mitsubishi tv will not turn on
I had a mit. vs-55601 given to me and my family. when i push the power butten a green light will come on for about 3 seconds and then goes off. i pulled the circut board and looked underneth it and it looked as if though it had been a little warm at one time or another. iwould like to know if it would be something i could fix or how much it will cost to repair ?. thank you
  • 1 more comment
  • Anonymous Nov 05, 2008
    GREEN
  • GGAUDET461 Nov 05, 2008
    GREEN LIGHT COMES ON FOR 3 SECONDS THEN POWERS DOWN
  • hungthrottle Nov 23, 2008
    Same problem, green light turns on, then goes out. The screen never lights.
I was trying to hook up a converter box to my 65" Integrated HDTV widescreen Model #WS65613 to see if I could get better reception on it. I live out in the country and have to have satellite, so I wanted to see If it worked, it did not. Well in the process the screen is blue and cannot get a channel at all, the antennia says channel 3 and I cannot get my satellite to come back on DBS to hook my satellite back up, it's not the Dish or reciever because the other tv works. Please help?
Posted on Aug 26, 2008
50 in mits tv wont power on. green reset light
Hi, It's either the lamp or the power supply capasitors. Thanks.
Sep 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi VS-50609 won't turn on
What a great tv this is Mitsubishi did a fine job making this one, but......only an authorized mitsubishi servicer should repair it. This set records diagnostic led codes that the technician receives to help determine where the problem might be, not the problem, but in which circuit it might be. The one thing to try is, unplug the tv , let it set for a minute, plug it back in , turn it on and hope it reset the micro. Next , call for mits. service.
Jun 11, 2009 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi vs-55601 55 inch tv
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 10, 2017 | Mitsubishi VS-55601 55" Rear Projection...
How do I deguassa VS-55601
Many manufacturers put a software degause feature in the main menu. There should be an option for deguassing, I am not a hundred percent on this model but if you look in your operations manual it will tell you if this option is available. If not you can purchase a deguaser at a local electronics supplier. It is basically a round donut shaped electro magnet use caution and follow the instructions. Remember in the future to always keep external speakers away from your TV sets..
Jan 27, 2009 | Mitsubishi VS-55601 55" Rear Projection...
Bows on sides
Try degausing the set with the system software. if this doesnt fix it you will have to degause the set with a professional tool.
Mitsubishi ws-55613 55in.
Four bad capacitors in DM module = common repair for
qualified Mits tech.......................T.
Nov 15, 2007 | Mitsubishi WS-55613 55" Rear Projection...
Have a problem with mits. vs-55601
The cancel button on the Base unit doesn't seem to work for this, you have to use the "Cancel" Button on the remote. Once you hit "Cancel" on the remote, the scan should exit, and then the buttons on the base unit should work again (barring any other issues). You should also be able to allow the scan to finish (takes a while especially if no signal on the channels), and when it's done it will exit. Hope that helps. Buzz
Aug 20, 2006 | Mitsubishi VS-55601 55" Rear Projection...
Televison & Video Logo
181 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
