Guess u were trying to install Win7 over Vista...it does not work that way....Win7 need to be a clean install...that is...it must be installed in a new partition after doing a full low level format....so you will have dual boot at start up...and u chose what u want vista or Win7 to work with for that specific session....
Dual boot helps in many ways...
1 - it helps file management better
2 - it helps to boot from one OS in case the other gives trouble
3 - virus attack are removed from either OS
etc etc
the best way to getback you system is to
1 download KILLDISK (DOS) utility program, get the DOS version
2 copy it on to a CD
3 get hold of a Win98 CD (bootable)
4 boot from Win98 cd, dont chose to install Win98,
5 press ESC and let Win98 quit installing, it will lead to a drive letter of you CDROM (say D or E as the case may be)
6 insert the CD that has the KILLDISK DOS utility
7 Run the program by typing KILLDISK at the CD drive letter prompt.
8 Read all the options available there...and kill the drive in which you had VistaOS/Win7 (C)...this will make all you C: drive sectors to "0"
i.e. it will wipe your C: drive clean and u can start with a clean slate....
if u r not concerned with the data in you disk...wipe all drives and disks in the PC....a 20GB disk will take aprox 1 hr to finish
for all this u must have the BIOS enabled to boot from CDROM drive...
once killdisk has finished doing the wiping process....
insert the Vista or Xp cd and install either...in the partition option make 3 or more partitions....C, D, E of at least 30 GB min for each...as Win7 will take aprox 18 GB....
in C: drive install Vista or XP as the case may be.....
once done....let the system boot and let it load Vista or XP
once in Desktop you can insert the Win7 cd and install it on the D or E: drive....the CDROM drive letter will change accordingly....when you make the partition....so be carefull to
let me know....
reg
