Question about Toshiba MK8034GSX 80 GB SATA Hard Drive
Toshiba MK8034GSX Hard disk Drive Problem
My Self Amin From India I have Toshiba MK8034GSX Hard disk Drive. But from some last some days it cant work properly. It is not access by me from my pc and laptop.I can see my hard disk volume in my computer folder but i m not able to access it.It shows error or some time my PC also Hang. So pls send me a Sollution on amin_khatri2001@yahoo,com I request u pls solve my problem
  • LINUX84H Nov 05, 2008
    HELOO DRAIVER USB TOSHIBA MK803GSX HDD2D38 R ZK01 S
    Genius:
  • 3,587 Answers
Sounds like you'll need to reinstall the operating system, from the recovery cd...or use F8 for safe mode, and see if it's a virus issue
Posted on Apr 23, 2008
Dear sir I have laptop..hp 2530p. 12" inch
You can choose any brand of replacement disk (Western Digital, Hitachi, Seagate, or Toshiba), provided it conforms to these specifications :
- form factor : 2''5
- interface : SATA
- size : at least 120 Gb, if your disc was nearly full, or less, depending on your storage needs.
Any computer shop can provide you with that kind of spare part.
They can also install the OS on the disk, with the drivers for your specific HP model.
Aug 31, 2014 | Computers & Internet
Smart failure predicted on my hard disk
Hopefully the warning was overly cautious, and you are still interested in an answer.
When SMART warns of failure, it is time to stop trusting that drive and get a new one. Even though you might be owed another under warrantee, it is a Good Idea™ to have a spare. You need to get as much as you can off of the failing drive and transfer it. A disk cloning utility like Norton Ghost or Partition Magic will give you a perfect copy of what you currently have, but many people prefer to back up only the documents and settings and then install the system and application software fresh.
May 29, 2014 | Toshiba MK8034GSX 80 GB SATA Hard Drive
I have the aspire 3680 but it hasa mk8034gsx-si hard disk that has gone bad what do i do?
Hello
You may need to re-place the hard disk if it gone bad, the picture shows it procedure of replacement.
The hard drive can be easily accessed from the bottom of the laptop. Simply remove the hard drive door, remove four screws securing the hard drive caddy, disconnect the hard drive from the connector on the motherboard and remove it from the laptop.
After that remove all screws securing the hard drive to the caddy and transfer the caddy to the new hard drive.
Hope this helps, if so rate the solution
Jan 20, 2011 | Acer Aspire 3680 Laptop
Smart failure predicted on my hard disk said it could be from a recent added item what do i do?
Unfortunately this means that the drive is about to fail. Fail means it will eventually stop working and be inaccessible. So you need to back up any important data from the drive now. Get whatever you have on the drive to a back up location (ie another drive/image/burn to dvd/etc).
Its my first post, so I'll explain a bit more. SMART is Self-Monitoring, Analysis and Reporting Technology. So Ill put this in easy good terms, Smart is predicting a hard disk is going to go bad (stop working completely, and eventually fail), SMART knows this because it will take stats from how the hard drive is at various times over the years you have it.
Over time such as spin up time, read errors, power on cycles, etc. to determine how much wear and tear the drive has on it and assigns each a value. It then compares your drive's values to a database of failure rates to predict when it will wear out. So it doesn't actually test the drive in the true sense of the word. Based on that, the error message implies that there isn't necessarily anything wrong with your drive at this moment but statistics show most drives in this condition fail soon-replace it.
(Hey at least now you know all this)
Many times people do not get the opportunity to receive a SMART warning, as catastrophic spontaneous failures occur. If you are getting SMART warnings you should definitely take heed of them, as you are fortunate enough to have some time before catastrophic failure to back up data. (Whatevers important, like docs, resumes, pictures.)
Also thats a LAPTOP hard drive, so from experience, back that up right away. Those small hard drives (2.5") are prone to dying in the half the lifespan as the normal hard drives. You also may find that some data may not be accessible, so if you know some moderate skills. Use HDD regenerator. May save you.
Thanks
Rhos Barnes, MCSE, CCNA Squamish, BC rhos_2k@yahoo.com
Jan 20, 2011 | Toshiba MK8034GSX 80 GB SATA Hard Drive
Warning Message that windows Dectected Hard Disk Problem
Go and see a technician immediately. Your HDD seems to be on the verge of failure.
Apr 01, 2010 | Toshiba (MK8034GSX) 80 GB IDE Hard Drive
How do i get a bigger hard drive for my laptop
go to staples and ask them in person what they have that can work . we on fixya have no idea .
Aug 10, 2017 | Toshiba MK8034GSX 80 GB SATA Hard Drive
Drive is not switched on
check the input power switch on the rear of the unit...
It should be on 240V. Turn off the computer, then move the switch back and forth a couple of times... set to 240V. this assures the coorect input power to the external drive.
Secondly, move the USB port to another USB port on your computer. If it works fine, then it is a bad USB port.
Third, check the device driver in device manager on your software. try updating the driver... This solves a potential driver issue.
Good Luck,
Jeff
Sep 13, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
How to set a Toshiba MK8064GSX hard drive as a slave? The web site shows a group of 4 pins (2 over 2) This drive has 4 pins in a row.
u have to set the jumper to the set of 2 pins that are after the power cable socket
suppose this is the powercable socket 0000 then the jumper will be set to the 2nd row of the folling pins assembly that will be 0000 :[:]:: jumper position -> [ ] look in to the pic and u need to set the jumper on the pins that says slave
Jul 08, 2009 | Toshiba MK8034GSX 80 GB SATA Hard Drive
Hard Disk Got crrupted
If it is corrupted repair the operating system or reinstall it.
It HDD is not working you may appraoch Segate service in Ernakulam for Replacement of it. They may take 15 to 30 days for the procedure. Your warranty is vaild across India.
May 30, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
No hard drive fond on windows installation process
Make sure your IDE CABLE was properly connected to your hardrive, you can check your hard drive if it is already connected to your CMOS..
April Jay Valdez
Dagatan Dolores Quezon
Feb 17, 2008 | Toshiba MK8034GSX 80 GB SATA Hard Drive
Toshiba MK8034GSX 80 GB SATA Hard Drive Logo
986 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
