Hi, I have an Acer 3500 that used to work on wireless. The settings were changed and now the wireless does not work any longer. How can I change the settings back so the wireless functions again?
    Genius:
  • 3,587 Answers
Go to control panel, under start/settings, and access the wireless setup icon
btw, you are my 2600th solution
Posted on Apr 23, 2008
On my acer aspire 5735 I have always been able to easily use my wireless at home now it will not connect to a network or even search for one to connect to. All the wireless settings are on and correct and...
does your dhcp on network setting in manual or automatic mode?
if in manual, you have to change it to automatic. it will reconfigured automatically when connect to new network.
Mar 12, 2011 | Acer (BCM94318MPG) Wireless Adapter
How do I turn my wirelss adapter on / on my acer z290g
HI
This is neo , check the acer wireless utility . OR
Go to control panel -> network sharing -> on the left side click on Change adapter settings -> enable the wireless network connections .
Nov 02, 2010 | Acer Computers & Internet
My wireless facility no longer works since i tried to install a wireless printer. It tells me that the Ip address is invalid and Windows repairs it but it still doesn't work and I get a message that i have...
Seems like the IP address being used by the wireless printer is the same as your wireless facility.
Usually you have to change the last number on your IP address to solve this issue.
Please don't forget to rate this answer if it helps.
Aug 26, 2009 | Acer Aspire One Netbook 8.9" Notebook
Where is the wireless radio key on travelmate 2314 ? lost my wireless connection and they ask me to turn on my wireless radio to add back my wireless settings. thanks
Try going through your eNet Management to turn your wireless radio on.
Start>All Programs>Acer Empowering Technology>Acer eNet Mangement
Once in, you can your status and settings. Make any needed change and close program. The tool is easy to use and fairly straight forward. This should correct your problem.
Good Luck,
C2Solutions
Aug 06, 2009 | Acer TravelMate 2300 Notebook
Acer 6930 wireless won't connect anymore.
Hi acording your describle, you need do
1) please check the bios first, to set wireless to enable
2) check windows right buttom bar is there a wireless icon show there and click to see any detect wireless signal, if nothing to detect
3) check or compare to other laptop wireless configuration, check any incorrect setting.
4) if all sense ok, you need check the wireless card and wireless antenna wire connection, open a samll cover at back of laptop, there is a MINI PCI slot with a wireless card, take out and clean the card pins then put back.
5) still trouble please change another wireless card (same model)
it should be fix.
hope help you to fix it, please take a rating le me know how much helped you, thanks. for any question in any time please !
May 17, 2009 | Acer Aspire 6930-6455 Notebook PC
Wireless
Have you configured the Belkin wireless router?
You need to configure the Belkin using a 10baseT network cable first before you configure the wireless card.
To make your wireless router secure you need to use your browser and type in the Belkin IP configuration address.
Then you need to change the Admin password, change SSID and turn off SSID broadcast, setup the encryption (use WAP or WAP2 if your wireless card supports WAP) and for added protection use MAC address filtering.
Apr 12, 2009 | Acer Computers & Internet
Can not find Acer model s88m driver.
ftp://ftp.work.acer-euro.com/utilities/intel/infinst_enu.exe
This is for Acer veriton 3500 which uses the s88m motherboard, but your laptop model may be different (they use the same laptop in different models) this is also fo windows XP, you did not say which version you were using.
http://support.acer-euro.com/drivers/desktop/veriton_3500.html
this is the driver page all of them for the 3500, if you have a different model, you can go there and change it to the right one,.
Please rate my help. Thanks
Mar 30, 2009 | Acer Aspire 4720 Notebook
Keyboard stops responding after a powersave on laptop ACER 5715Z
The issue is that several of the Acer software products don't support Vista. You need to remove these programs.
Follow the instructions in this link
http://global.acer.com/support/winvista/t-faq.htm
Due to architectural changes to Windows Vista®,some Acer applications are not supported anymore. Below is a summary ofthese applications. Uninstall these applications before the upgrade.
Acer eRecovery Management The new version of Acer eRecovery Management, which is compatible with Windows Vista®,requires repartitioning your hard disk drive, causing data loss. As aresult, the Wizard will not reinstall the new version of eRecovery onyour computer under Windows Vista®. However, you will be able to find similar features in the built-in Backup Utility of Windows Vista®, including full system volume backup to a HDD or CD/DVD. Acer eAcoustics Management Windows Vista® supports similar functions of eAcoustics so Acer will no longer provide this utility for Windows Vista®. Acer ePresentation Management You can easily manage your external monitor settings via Windows Vista® Mobility Center. As a result, we do not support an upgrade to Acer ePresentation Management. Acer ePower Management Due to architectural changes to Windows Vista®,Acer ePower Management cannot be upgraded for some models. However, youcan easily manage your power settings via Windows Vista® Mobility Center instead. Acer ePerformance Management For notebooks only. Since Windows Vista® provides similar resource management functionalities, we will no longer provide this for notebook models with Windows Vista®. Acer Arcade™ Deluxe 3.x
Acer eNet Management 1.x
Acer eDataSecurity Management 1.x Due to architectural changes to Windows Vista®, these applications cannot be upgraded.
Alternately (not recommended) you can change your settings with the following method. I would recommend removing all the Acer software though as keeping them might cause problems.
Check under Advanced Power Options-> Multimedia Setting -> When Sharing Media. By default onBattery and Plugged is set to "Allow the computer to enter AwayMode" Changing this setting to "Allow Computer to sleep" should solve theproblem. On Battery the Away Mode "does" allow the computer to sleepproperly.
Jan 27, 2009 | Computers & Internet
Hi, I have an old acer laptop and my wife communicates with me on it using broadband and a router with a usb pick up. I have returned home and have a new acer laptop with wireless LAN already installed. It...
Youe broadband router is working ok with the broadband cable.So it is configured with the broadband cable.Now,to work with the wireless internet,you have to configured the wi-fi router to work internet.You can see the wi-fi connection but unless & untill you will configure wi-fi router it must not work or if before it was working with the wi-fi then you can check the wi-fi router setting because it might change by mistake.Surely it will work after configurating wi-fi router.
Jan 03, 2009 | Computers & Internet
Wireless connectivity
hi,
connect to rourter wired
open ur router page
and run the set up
Jan 05, 2008 | NetGear WGR614 Wireless Router
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
