Question about Toshiba 65H81 65" Rear Projection Television
PD 0074 Dear people, Where in the world can I buy a (Main Power Regulator) PD 0074 for my Toshiba 65H81. Thanks in advance
  • laucalin Apr 24, 2008
    Thanks a lot Slinteriors, I think I'll consider that.
    Although I found a site that sells a PCB DEF PD0074A .........with letters like "A', "F", "P", at the end and really don't know if they would be compatible, mine not having any letter there.
    Thanks for the help
  • Toshiba Master
  • 8,617 Answers
That is the deflection board which is no longer available. I have a source that rebuilds circuit boards but that item would be around 350.00 to rebuild the entire deflection board. Heres the link if youd like to contact them.
http://servicemanuals.vstore.ca/
Posted on Apr 23, 2008
My Toshiba CT 8002 won't turn off standby. When I press the power button on the remote, it clicks as though it will turn on, and then clicks straight back to standby. Any suggestions? Thanks in advance! :)
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
May 10, 2014 | Televison & Video
No Sound
There may be a button on the back of the set
to turn interan speaker on and off
if not then in the sound menu
check that out if that dont do it
get back to me
Nov 27, 2007 | Toshiba 65H81 65" Rear Projection...
My Toshiba 65H81 65" rear projection TV's picture
You do not have individual lamps in that model. You have 3 individual picture tubes of which I don't believe they are bad. They have fluid in a reservoir that becomes cloudy after time and needs to be replaced, however this is something you cannot do yourself. I recommend you call a qualified technician to take care of it for you.
Nov 26, 2010 | Toshiba 65H81 65" Rear Projection...
RED POWER LIGHT BLINKS
Red power light blinks and tv will not turn on it is a 65h81 Toshiba HD
Jun 19, 2009 | Toshiba 65H81 65" Rear Projection...
Toshiba 65h81
Somewhere along the line you may have missed a cable connection. Recheck to be sure that all of the wires are reconnected. Also, check the +5V line. In the area of the convergence Ics there should be a number of pico fuses. One of those may have opened up.
Keep us posted.
Dan
Jun 09, 2008 | Toshiba 65H81 65" Rear Projection...
Power led blinking
possible.. convergence ic can cause this problem if they become shorted
Apr 16, 2008 | Toshiba 65H81 65" Rear Projection...
Toshiba 65H81 Step By Step
Could I get a copy of that manual please? Sometimes my remote works / and sometimes it doesn't. I use other remotes which are programmed for the TV, but it's the receiver eye on the TV which is intermittent. Does anyone know of a fix??
Mar 25, 2008 | Toshiba 65H81 65" Rear Projection...
Toshiba 65H81 blinking power light
Hello
I have the same thing going on with mine. What it is the SLR main Reg. is bad. The only way you can fix it is you can't put just one part in it you have to replace one of the boards. When you open the back panel up you will see three boards in a roll the one that needs replacing is the power board you have to get the model number. My Tv is a 65 HD model 65h81 the board on mine has a part number of PD 7400 yours will have something like that. Well let me know how it's goes my E-Mail is kenjr1@iwon.com
Feb 14, 2008 | Toshiba 65H81 65" Rear Projection...
Toshiba 65H81 blank screen and red blinking light....help
I don't think is any lamps.
If you are handy try to open the back of your tv, (unplug it first) don't touch anything just yet, you need to make sure you discharge any static left on the power board (the first from your left )Unplug power cord from the board. Take a heavy long screwdriver (Isolated) and lightly, touch a few parts on the board including the thick red wires that go to the lamps. Once that's done its time to put your dexterity at work. You need to lift that board (PD 0074) so that you can check some fuses like F850, F852, etc. for continuity. Mine were out. I had replaced those two and I had tv for another year. Remove the screws that hold the board. Now, this board PD0074 is connected to the next board by two white connectors and one blue. ....lift them up from one side with your finger nail. Don't unplug anything from the power board, just loose some wires so that you can lift the whole board on one edge. Get a voltmeter and set it to check continuity. Mine has a buzz. Look for them fuses if they are bad , ....replace them. (You can buy them at Partstore.com.....punch in "fuses"or "125V 2A")
In my case that was the only problem a year ago. Now I also have the same problem but this trick didn't work for me anymore. The Power Co,. messed me up big this time. In fact the problem with these Toshiba rear proj. is that when the power in your house goes out and comes back right a way in a split second and you don't have a power regulator, guess what : 'red led blinking'
In my case this time the whole power went on and off a few times within 10 sec. and by the time I got to the TV to unplug, it was to late. I think I have to replace the whole PD0074 board....and that's expensive.
Good luck
Jan 12, 2008 | Toshiba 65H81 65" Rear Projection...
Str reg.
No need to take the front screen out. The power deflection board is messing up with that red light.
Nic
Aug 19, 2007 | Toshiba 65H81 65" Rear Projection...
Toshiba 65H81 65" Rear Projection Television Logo
178 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
