Question about Acer AL1916W 19" LCD Monitor
Brightness/contrast Monitor is too bright. How do I adjust the contrast? step by step please
    Scholar:
  • 186 Answers
Sometimes all you have to do is press the left or right adjustment buttons, one will bring up contrast adjustment, the other brightness.
 Otherwise simply browse through the menu settings.
Posted on Apr 23, 2008
How can I decrease brightness and contrast?
To help you change the brightness and contrast settings from the LCD monitor, please follow the instructions mentioned below,
The control buttons are located at front panel of the monitor. The Brightness Button is used to select the Brightness/Contrast adjust functions. Press to switch functions or adjust settings.
To decrease the brightness or contrast press (-) button & to increase (+) as per your adjustment.
GuruAid.com
Mar 29, 2016 | Dell E173FP 17" LCD Monitor
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
Can not access PC Brightness or PC Contrast - only X Contrast
From p.29 of the manual
"Brightness, Contrast, Sharpness, Color, and Tint are only available for adjustments
if you select User in Picture Mode.
Press / on the remote control or VOL+/ VOL- on the control panel to adjust these settings."
Apr 12, 2010 | Hannspree 28" Widescreen Flat-Panel LCD HD...
HOW DO I BRIGHTEN UP MY MONITOR SCREEN?
hi,
you can adjust the contrast and brightness of the screen accordingly using the following instructions. Please select the right combination of brightness and contrast according to your desire.
  • Please check out controls in the bottom of your monitor, below the scree. I have provided the image below for your reference.
  • In this the fourth option is OSD menu. Please click on it and you will scoll down to options .
  • you can see options called "brightness and contrast". I have added picture for this too!
9b04c60.jpgOnce you go that page,use the menu to enter! then use the 2nd and 3rd button to adjust the brightness. Now your job is done.Please click on 1st button to exit. If you need more assistance in this, please write back to us. Please rate my solution as helpful!
Apr 02, 2010 | Acer AL1715 17" LCD Monitor
How do I adjust the brightness? It's too much?
By following these steps u can adjust the brightness
Step 1
Press "Menu" on your LCD's display panel (usually below the screen). Various display options will be shown on the screen.
Step 2
Select brightness from the options. This is usually indicated by a sun. Use the "+" and "-" buttons on your display panel to increase or decrease brightness.
Step 3
Select contrast from the options. This is usually indicated by an oval half black and half white. Use the "+" and "-" buttons on your display panel to increase or decrease contrast.
Thank you
Mar 28, 2010 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
Monitor brightness contrast problem
Turn Off auto-adjustment screen
Jul 29, 2009 | Proview PL19Wb Monitor
VA721/Windows 2000 - contrast/brightness settings grayed out
The monitor is probably set to sRGB under "color adjust".
Change it to 6500K, which is default, and you should be able to adjust brightness and contrast.
Jan 01, 2009 | ViewSonic VA721 17" LCD Monitor
Need help with Compaq MV5500 CRT 15 inch monitor
hi there, your switch botton is failling, manual buttons on the front to adjust controls, do some switch test, replace micro botton switch. ty
Dec 26, 2007 | Gateway FPD2275W LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
762 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
