Question about Brother IntelliFax-2820 Laser Fax
Brother 2820 This brother 2820 says No cartridge open the front cover than reinstall toner cartridge so i do and nothing changes. any ideas Thankyou, Steven
  • glassm71 May 12, 2008
    I am reinserting the drum and new cartridge with out any results is there a reset anywhere.
    New Friend:
May printer is problam change drum soon
Posted on Nov 28, 2013
    New Friend:
  • 120 Answers
The toner cartridge is in the drum unit. push the blue lever and the toner pops out, make sure you have a toner cartridge in the drum unit. Lawrence
Posted on Apr 23, 2008
"toner life end" message even with new cartridge
Open the front cover
Press the OPTIONS button
Press the START button
Press the number 1 key twice
Close the front cover.
You may need to go through the steps above twice to reset the toner.
Jul 11, 2010 | Brother IntelliFax-2820 Laser Fax
I have a Brother fax and copy machine and have just replaced toner with a brother TN 350 cartridge and still getting message that toner is low
You didn't include the model, but here are instructions for the Fax-2820; it should work for any of the models that use the TN-350 toner:
  1. With the power on, open the front cover.
  2. Press the Options key. The display will read "Change Drum?"
  3. Press Start.
  4. Press 1 0.
  5. The display reads "Accepted" for about 2 seconds, then change to "Cover Open."
  6. Close cover. The "Replace toner" message should be cleared.
Normally, inserting a new cartridge (with the power on) will reset the toner counter, and you won't have to do any of this.
Dec 21, 2009 | Brother IntelliFax-2820 Laser Fax
Can't reset "change drum soon" message Brother Fax 2820
Open the front cover and press and hold -stop,reset button
Sep 14, 2009 | Brother IntelliFax-2820 Laser Fax
Brother MFC-7220 says close back cover but it's already closed
Open the front cover and remove the drum and toner(cartridge) There should be a paperjam in the machine. It reads back cover open because the piece of paper is covering the sensor for the back cover.
May 13, 2009 | Brother IntelliFax-2820 Laser Fax
Brother printers 2820 paper coming out fouled
Pull toner and drum cartridge out by folding front door down and seperate the toner from the drum by pressing the blue lever. re-insert the toner into the new drum. After installing the cartridge back into the printer, leave door open and press the clear button and on the LCD screen you will see for new drum press 1 for yes and 2 for no. Press the 1 button and close front door. Finished. Please rate my help if this fixed your issue. Thanks!
Feb 15, 2009 | Brother IntelliFax-2820 Laser Fax
Brother 2820 fax machine
THE DRUM AND THE TONER CARTRIDGE IS IN SIDE OF THE MACHINE.OPEN THE COVER AND YOU WILL SEE THE DRUM CARTRIDGE,TTAKE OUT THE DRUM UNIT. ITTELLS YOU ON THE DRUM UNIT THE NUMBER DR    IT IS SOLD IN OFFICE DEPOT OR OFFICE MAX OR STAPLES, MAKE SURE THAT YOU ONLY USE BROTHER PRODUCTS. GOOD LUCK BROTHER SR TECH
Feb 02, 2009 | Brother IntelliFax-2820 Laser Fax
Change toner error brother 2820 mach has new brother toner ctg
with machine on, open front cover, press the "options" button, you should see "replace drum?" press the "start" key then 1 then 0. display should show accepted for a couple of secs. then show cover open. close front cover and message should be gone. if not, you will have to contact Brother.
hth,
razors
Jan 23, 2009 | Brother IntelliFax-2820 Laser Fax
Change toner and it comes up with Toner Life End
Im think you leave the cover open and hold down clear
Jan 21, 2009 | Brother IntelliFax-2820 Laser Fax
INSTALLED toner still get message open door reinstall no cartridge
which toner are you using?brother oem or third part generic? or refills! it is best to always use brother products. the generics always give you problems, brother service center
Jan 15, 2009 | Brother IntelliFax-2820 Laser Fax
Brother intellifax 4100
open front cover, press "clear" and 1, that will clear the change drum soon error
Jan 14, 2008 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
378 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
