Question about Apple iPod MA446LL/A MP3 Player
Ipod's Hardrive just keep spinnign and won't restart
My ipod just recently froze and i tried to reset it by holding menu and the center button and it began the restart cycle but the hard drive just spins and then clicks off. And it wont restore or anything. All i can do is put it in disk mode. I have a warrenty with best but so should i just take it in and get a replacement. I know it is covered for that so. I could just pay the extra 250 dollars and get a ipod touch right. THank for he help
Chad
    Scholar:
  • 186 Answers
The 30 GB iPod's had a Hitachi HD, which seems to have hit and miss problems. The 60 GB's were Toshiba HD, which were much more reliable. The iPod touch went flash based, which is the most reliable so far. If it has warranty, let apple worry about it, then do what ever you want once it's fixed.
Posted on Apr 23, 2008
The screen froze on ipod 30gb. it keeps saying do not disconnect and will not turn off.
Press and hold the center button, while also holding down the menu button ( top of wheel )
It will force the device to restart, and should fix your problem.
I hope this helps.
Oct 17, 2009 | Apple iPod MA446LL/A MP3 Player
My Ipod froze
You can usually reset a frozen iPod by holding down the menu and center buttons for about 10 seconds. Hope this helps!
Jun 23, 2009 | Apple iPod nano
Ipod froze
Try this which should reset your ipod: First, toggle your hold switch back and forward and put it back to the off position. Then press and hold the menu button and the center button simultaneously for about six seconds and the screen should go blank and the apple logo should appear. After that it should work.
Mar 05, 2009 | Apple iPod nano
Please help my IPOD! It froze on the same screen w/ the light on
Slide the hold/lock switch on and off and then hold down the "Menu" button and the center button for about 5 seconds. If this doesnt restart your iPod, try the same procedure, but instead, hold down the "Menu" button and the "Play/Pause" button for 5 seconds. This should reset your iPod.
Hope it works!
Feb 23, 2009 | Apple iPod nano
Ipod freezing
try connecting your ipod to computer and then try reseting it...
To reset your iPod nano:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
this has to resolve your issue
If need help.. reply
Jan 27, 2009 | Apple iPod nano
My iPod Classic keeps shutting off and back on
Just use the reset button in the bottom of ur player now try to restart it
Thank u
Jan 05, 2009 | Apple iPod classic MP3 Player
I have a 8gb ipod nanm and recently it froze and won't move or
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Nov 15, 2008 | Apple iPod nano
Ipod nano
try a reset
To reset your iPod:
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Tip:
  • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
  • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Jun 14, 2008 | Apple iPod nano 3rd Generation
Ipod nano
switch the hold button on and off, then hold horizontally, and push the menu button and center button at the same time. hold them down untill the ipod restarts and the apple logo apears. If that doesen't work, plug into the newest itunes program, and push restore.
Feb 26, 2007 | Apple iPod nano
Applie ipod nanao
hi your ipod will shut itself if no action is on you can determine the period of time that will happen good luck
Mar 22, 2006 | Apple iPod nano
Apple iPod MA446LL/A MP3 Player Logo
75 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
