Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
I have a kawasaki kx60 2 stroke it wants to fire but not run what could be the reason why
  • texastriot1 Dec 08, 2008
    I have the same problem, bike started fine and idled ok then is started to boggs out and backfire on any kind of throttle advancement. The bike had spark yesterday but now it has no spark it wont even fire. I checked the magneto and all alignment marks are good changed the plug, flushed the tank and still no luck. I checked all the wires for frayes, Chaffs and breaks all looks good. HELP!!
  • 27 Answers
Carb settings incorrect? Check / replace spark plug - do plug test to check for good spark. Fuel tap broken or not opening properly? Check flow of fuel to carb. Maybe blocked tubing.
Posted on May 23, 2008
Ok I have a 2004 kawasaki klx125 dirt bike. It was ran on mixed fuel. Will this mess or blow or cease the bike if continued to run on this
Hi, James it won't hurt anything, probably smoke a lot and may oil foul a spark plug, why not just drain it and replace with straight gas if your that concerned for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2 Stroke Fuel in 4 Stroke Bike
What could happen if use 2 cycle fuel in 4 cycle engine
Kawasaki KLX125 2003 2006 Workshop Service Repair Manual Download Manuals... $10 cheap
OEM Parts for Kawasaki
Kawasaki KLX125 Owner Manual
Apr 04, 2017 | 2004 kawasaki KLX 125 L
WHAT IS THE SPARK PLUG ORDER FOR A KAWASAKI NINJA 900 1985
Left coil feeds 1 and 4...right coil feeds 2 and 3...as long as you stick to this it doesn't matter which lead goes to which plug. Left coil will have one short lead and one long...short =1...long = 4. Right coil leads will be about even in length...doesn't matter which goes to 2 or 3.
It's a wasted spark system so plugs 1 and 4 fire together...2 and 3 fire together...only 1 cylinder in each pair will be compressed and ready to fire when the spark happens, the other will be empty and coming on to it's inlet stroke...
Jul 20, 2014 | kawasaki Ninja 1000 Motorcycles
1989 Kawasaki KX250 Manual
1989 Kawasaki KX250 Repair Manual Download
This Manual Covers The Following Machines:
1988 Kawasaki KX125 2-Stroke Motorcycles
1988 Kawasaki KX250 2-Stroke Motorcycles
1988 Kawasaki KX500 2-Stroke Motorcycles
1989 Kawasaki KX125 2-Stroke Motorcycles
1989 Kawasaki KX250 2-Stroke Motorcycles
1989 Kawasaki KX500 2-Stroke Motorcycles
Product Download Information Page
May 23, 2014 | Computers & Internet
Timing..I.E. late firing
Hi, Spiderman699 for backfiring the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a "LOAD" test "WARNING" you can have 12.5 volts or better but little or zero amps and the battery must be replaced.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage check for spark leakage in the dark.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2007 kawasaki KLX 250 timing marks Google Search
Setting up timing chain problem Kawasaki Forums
Krieger Cam Chain Tensioner 2007 Kawasaki KLX 250
Kawasaki KLX250 Tracker Service Manual
Kawasaki KLX250R Owner Manual
May 14, 2017 | 2007 kawasaki KLX 250
I have fire to the spark plug and gas to the engine but will not krank just back fires
I ASSUME IT IS A FOUR STROKE AND IF SO YOU NEED TO CHECK THE TIMING AND THE VALVE CLEARENCE,IF IT IS A 2 STROKE I WOULD LOOK TOWARDS THE REEDS IN FRONT OF THE CARB,CHECK FOR CRACKS OR GAPS,ALSO MAKE SURE IF YOU CLEAN YOU CARB THAT YOU CAN SEE DAYLIGHT THRU YOUR PILOT JETS.JUST BECAUSE YOU SPRAY SOMETHING IN THERE DOESNT MEAN ITS UNGLOGGED GET PROOF
Mar 17, 2011 | kawasaki Z 250 C Motorcycles
I have a 73 kawasakie motorcycle 250cc with two spark plugs and only one plug wire of the coil? The wire off the coil has been taped like maybe the two plugs fire together I am a car mechanic and know a...
You will need a new coil it sounds like someone has mcgivered a coil from a single cylnder. they wont fire together, when one is on the comp stroke the other is on the exaust stroke, but the ignitions often fire a spark on compression annd exhaust strokes ie each time the crank rotates, so they have used this to get it running
Jun 30, 2010 | 1980 kawasaki Z 250 C
What is the oil mixture ratio for a 2005 Kawasaki kx250?
hi,most two strokes in the mx range run about 40-1,but me being me i always prefer to run my 2 strokes a little bit oily around 33 or 35 -1,2 stroke oil is very cheap compared to scored barrels or seized big ends...cheers
Apr 04, 2010 | 2005 kawasaki KX 250
I nee to wire my 1972 kawasaki 100 2-stroke motorcycle so it run
From the dynamo the current generated to induction coil armed with the appropriate capacitor, for relaying the current it via the distributor,(for timing of spark) high voltage/current, and distributed to each plug/Cylinder & called CDI ( Capacitor Discharge Ignition)..........seems the most practical solution I could come up with .
Hope this 1 sparks, fire's &/or a( no pun intended) thread.....................sodeep
Oct 26, 2009 | 1972 kawasaki Mach III H 1C
I have a kawasaki kx 250 2 stroke an it was running good now it wont start. it has spark it wants to fire up but it just backfires.
hi murray,
nice bike you have there.
have you checked on the carb ans see if the jet is right and the mixture is normal, this is usually the case if the carb is not tuned right.
better of reset the card, open it clean it, then set to default even if you are using your mixture of gas and 2t. just set to factory default. once it starts give it a few run, 1-2 hours, then set it to how you want your mixture to be.
hope this helps,
regards,
voodoo
May 17, 2009 | 2003 kawasaki KX 250
What is the true speed (top end) of the 2002 zzr 400 kawasaki
That is so dependant upon "Many Variables!!--If you were shaped like a bullet`weighed no more than 90Lbs & were laying under the paint, with quality high octane rated fuel, without brakes binding , & no accessories like Panniers & the Engine had at least 16,000K'ms Legit on the clock ,& at sea level ( Not High Altitude & on a "moist day" without Pillion Passenger ,& with Engine having Air Cleaners near new,& providing each Cylinder registered similar Compression Pressure , Perhaps 15 Psi & The Engine had correct Viscosity oil , & Drive train was not "MALADJUSTED " this macine , with small tailwind could be expected to top the Ton!---Now, IF YOU REALLY wanted to know just how good KAWASAKI'S earlier prducts were . locate >1974 S3 --2Cycle Triple Fire Breather & Could out accellerate & out run HONDA K1 750/4 --Reason>?"Power To Weight Ratio"--I hope that has been useful!--Whilst I 'm on that aspect, the Triple sounded to be screaming ( As if Ultra High RPM, Not so, it being Clarke cycle ( 2 Stroke , has "power pulse each time piston climbs to Top Dead Centre & the Four Strokes , Rev so much harder, yet do not quite sound so !!---The Mighty Vincent V Twin was an exception though >Guaranteed each Macine would reach 120 MPH 998 CC British, with very short pushrods, & alongside one at The Ton, years pasyt I noted His Tacho was only showing 4,200RPM!--O K -Cheers, Stay Upright", Des
Dec 17, 2008 | 2002 kawasaki ZZR 400
Lands Phones Logo
301 people viewed this question
Top Harley Davidson Lands Phones Experts
David Payne
David Payne
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
