Question about Laser 3115cn All-In-One Printer
Can't get the scanning software to work / it is the paper port 10.3 and when i try to get it started it cant find my scanner
  • lanellhall Apr 23, 2009
    I try to scan from my Dell Color Laser 3115 cn machine using a USB. It won't work. I've installed and reinstalled several times. It says "no scan driver has been registered". I have my installation disk. Nothing works. I have PaperPort installed also. I can't scan from my computer, either. Help!
  • Richard Wilbur May 11, 2010
    Is this printer/scanner new or used? Has this scanner ever worked on this computer? What was the last thing you did before it quit working?
    Scholar:
  • 103 Answers
Removing from my que due to inactivity
Posted on May 07, 2008
    Genius:
  • 3,587 Answers
Well..you have the latests print manager from Dell on this? support.dell.com may be of some value
Posted on Apr 23, 2008
As I want to scan a paper, scanner does not work properly. I tried many times but the scanner cut the paper from diffent areas as I tried over and over for several times. I got the exact scan maybe ten...
the drivers for the scanner might have been corrupted
you might have to uninstall the scanner restart your computer then reinstall your scanner
if your printer/scanner came with an installation disc the drivers could be on it
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also have option to troubleshoot
lift the lid on your scanner lay the photo face down then select scan document/photo it will ask what format you want to scan it then it will ask where you want to save it browse select the file/folder where you want to save it (my pictures) most common
hope this helps
May 02, 2011 | Computers & Internet
Why does canon MP258 printer with scanner can't scan japanese yen paper bill amount 10,000. I tried it over 10 times but it stops,. And when i tried US paper bill, it works well. I need some explanation...
When you scan with any scanner it utilised the software with "Optical Character Recognition functions, usually abbreviated to OCR -> OCR is a field of research in pattern recognition, artificial intelligence and computer vision." to scan and record the scanned object, sometimes it does not or cannot recognise certain symbols or characters because of man made software & hardware have its limitations too.
Hope it helps.
Nov 12, 2010 | Office Equipment & Supplies
I am trying to scan a document and it is not working, I have a hp photosmart c4280 printer. How do I install a usb cord
hi
Place the document or image into the scanner for scanning. A scanner with a paper feeder will only receive flat papers and photographs, but a flatbed scanner opens to accommodate books, fabrics and leaves along with flat papers. There is even a attachment for feeding photo slides into flatbed scanners.
  • Step 2 Start the scanning softwaremag-glass_10x10.gif. If the scanner does not engage the software automatically, press the "start" or "scan" button, or click the scanner icon on the computer screen to initialize the software.
  • Step 3 Activate the scan. Click the "file" menu and select "acquire," "import," or another practical choice that applies.
  • Step 4 Preview the item to be scanned. Most scanners have a preview option. This will show the scan area inside dotted lines. The lines can be moved with the mouse to relocate, enlarge or crop the scanning area.
  • Step 5 Set the resolution for images by number of dots per inch (dpi). For computer screen viewing, 100 dpi should suffice. Use 200 to 300 dpi for items to be printed.
  • Step 6 Use the appropriate setting for scanning black and white text. If the scanner does not show a preset for text, use "line art" or "black and white" at 300 dpi. Then use the optical character recognition (OCR) program to convert the image of the text into a file for word processi
  • Jun 09, 2010 | HP Photosmart C4280 Aio Printer
    I can't get my scanner to work it says try starting scan from put
    First you have to load the scanner (twain driver). Then load the scanning software. Then plug the printer/scanner into the usb port on the pc. The pc should then recognize the scanner. You might have to turn your pc off then on again to recognize the scanner. Then try to open the scanning software on your pc and put the document on the scanning glass and press the aquire/scan button on the software. Hopefully, that should work.
    Sep 14, 2009 | HP PSC 2410 All-In-One InkJet Printer
    Scan black only
    I had the same problem. It's because of the Paper port software.
    - Remove Paper port from Add/Remove in Control Panel
    - Use Windows' native scanning software by clicking to the scanner icon which should appear like your own Strobe xp 300 and use the first command from the list.
    - From there, Windows should guide through final step
    That should solve your problem
    May 09, 2009 | Microtek ScanMaker 3800 Flatbed Scanner
    CanoScan Scanner can not complete a scan
    Double-check all connections and try another port if possible. There may also be damage to cables or pins. Do you have another cable to try? Do other devices work in the same port?
    Jan 09, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
    Scanning office docs easily
    Yes, if it has a standard printer port. Software may have come with your machine or use PaperPort Scanning Software. It won't work if all that you have is a USB port.
    Oct 25, 2008 | Canon FAXPHONE L170 Plain Paper Laser
    Laser 3115cn All-In-One Printer Logo
    814 people viewed this question
    Top Laser Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Alun Cox
    Are you a Laser Office Equipment and Supply Expert? Answer questions, earn points and help others
