PRINTER CAN NOT COMMUNICATE WITH COMPUTER SERVOR
    Genius:
  • 3,422 Answers
HI,
Try reseting it.I am sure this will fix the problem
Posted on Apr 23, 2008
  • 1 more comment
  • Priya darshan Apr 23, 2008
    First do a hard reset by unpluging all the cords from the back for 30min and then plug it back in.
    Also try uninstalling and reinstalling the drivers
    And if this doesn't help then Open up the printer and look for some loose or broken parts floating around in
    the bottom of the printer. I think you'll find that something has
    fallen into it and caused it to break.
    You can try turning it on without being plugged into a computer and see if it initializes correctly IE moves the print head/s.
    You
    might find something useful here but I think that the you'll find that
    you have a mechanical problem in the printer and that it's cheaper to
    replace than repair
What is the 2851 error code on E90 BMW 320i 2009 model
I believe it is referencing your Valvetronic adjuster motor, the one that advances (changes) the timing of the valvetrain under varying RPM. Here is an excerpt from a do it yourself fix if you are mechanically inclined:
Recently I had a E90 320i come into my shop with the mil light on and running on half power. A scan of the vehicle indicated valvetronic servor motor internal failure. On testing the valvetronic servor motor I found it to be working.
The problem was it was not advancing the valve timing thus the half power of the engine. If you ever have this problem here is a fix that works. Remove the servor motor and. With a screwdriver push the eccentric shaft gear as far back anti clockwise as it can go. Insert the servor motor and connect its 2 pin plug. Them switch the ignition onto position 2 and withing a space of 15 seconds depress the accelarator pedel down to full throttle 10 times and you will hear the servor motor program itself back to factory spec. Re-fit the valve cover and problem solved. I hope you will find this post useful.
Good luck...
Feb 02, 2018 | BMW Cars & Trucks
Lexmark X1190 problem communicating with computer
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
Dec 20, 2011 | Lexmark X Office Equipment & Supplies
My Lexmark Platinum PRO905 does ot print it gives me the message " Communication Not Available, The Printer cannot communicate with the computer"
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if usb-connected), reboot your computer and unplug/replug your printer into the power source to reset it. When the printer turns on, reconnect the printer into the computer. Try to print again.
You may also refer to this article (for Wi-Fi connection issues): How to identify a Wireless Communication Problem and Resolution Tips
Aug 09, 2011 | Lexmark Platinum Pro905 multifunction...
When I try to scan or print a message comes up telling me to ck power and usb connections. I have unplugged and restarted computer 4 times and still have problem
It could be a communications error message, the printer is not communicating with the computer.
  • Disconnect and then reconnect the USB cable.
  • Disconnect and then reconnect the printer power cable.
  • Restart the computer.
  • Remove and reinstall the printer software
  • If your printer does not function properly or communication error messages appear when using your printer, you can remove and reinstall the printer software.
    1. Click Start®Programs or All Programs®Dell Printers®Dell Photo AIO Printer 962®Uninstall Dell Photo AIO Printer 962.
    2. Follow the instructions on the computer screen to remove the printer software.
    3. Restart your computer before installing the software again.
    4. Insert the Drivers and Utilities CD, and then follow the instructions on the computer screen to install the software.
    If the installation screen does not appear:
      1. In Windows XP, click Start®My Computer.
    In Windows 2000, double-click My Computer from your desktop.
      1. Double-click the CD-ROM drive icon. If necessary, double-click setup.exe.
      2. When the printer software installation screen appears, click Install or Install Now.
      3. Follow the instructions on your screen to complete the installation.
    Communications error message
    The printer is not communicating with the computer.
    Dec 06, 2010 | Dell 962 Photo All-In-One InkJet Printer
    Computer isn't communicating with my printer
    computer is not communicating with my printer i unplugged the usb port i and i resart the computer
    Aug 31, 2008 | Nikon COOLPRINT Thermal Printer
    Computer will not communicate with printer
    Go out to Lexmark web site and look for a vista update in their software download section. So this should solve your problem.Most of the cds which come with equipment do not contain vista software and drivers.
    Aug 06, 2008 | Dell 962 Photo All-In-One InkJet Printer
    X2250 not communicating
    will i think theirs two posible options why not communicate the printer first not proper installed the printer driver or maybe your connection from the computer to printer will loss contact that why not communicate...
    Nov 27, 2007 | Lexmark X2250 All-In-One InkJet Printer
    Computers & Internet Logo
    22 people viewed this question
    David Payne
    David Payne
