CANNOT OPEN THE SOAP DISPENSER UP - Washing Machines
  • Anonymous Nov 19, 2008
    My dispenser tray does not release. Have tried running a speed cycle w/o adding detergent, believing it senses that there was some detergent left from prior load, no difference.
  • 240 Answers
Some frigidaires have a latch, otherwise just pull.
Posted on Apr 23, 2008
Dispenser door will not open
Hey friend, thank you for the post!
I understand that your soap dispenser door will not open on your Frigidaire dishwasher, LGBD2432LW0A. You could possibly be seeing an issue with soap dispenser not getting water into it to release the soap from dispensing. I would check to make sure there are no dishes blocking or obstructing the soap dispenser. You could also remove the soap dispenser to clean it and make sure there is no buildup of any previous detergent remaining that would cause the door to not open. If those steps do not solve the issue it could be a problem with the dispenser and I would recommend having a tech come out to the home to properly diagnose and repair the dishwasher. Hope this is helpful. -Matt
Jul 28, 2014 | Frigidaire Dishwashers
Soap is not dispensing soap dispenser will not open up when I run the machine. Not soap is in the area for a blockage. Please advise what I can do. Thank you Terri
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these.
Hope this helps...
Daniel
Mar 25, 2011 | Kenmore Dishwashers
How do I open the dispenser?
how do you open the provon soap dispenser so that you are able to refill the soap. We cannot open the dispenser. What is the trick?????
Jan 14, 2011 | SP Richards Go-Jo Provon FMX-12 Foam Soap...
Soap dispenser lid doesn't open
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it
Oct 25, 2010 | Whirlpool Dishwashers
Soap dispenser does not open during wash
Well you can please follow the below steps -
1. Remove any dishes in the dishwasher. Unhook the dishwasher's dish trays or racks from their tracks, and set aside. Empty the soap dispenser if it contains unused soap that failed to dispense. Use a wet rag to wipe down the interior of the dishwasher, as well as the inside of the dispenser.
2. Close the dispenser, and shut the dishwasher door. Turn the dishwasher on to a manual setting, then stop it and open the appliance. Check to see if the dispenser is open. If it is, continue to Step 2. If the dispenser is closed, skip to Step 4.
3. Switch dishwasher soap. Some dishwasher dispensers have difficulty with dry or liquid dishwashing soap, depending on the make and model of your dishwasher. Incompatibilities typically result in the dispenser sticking shut, which explains why the dispenser opens when empty. Switch to liquid soap if you are using dry powder soap, or vice versa.
4. Check the dishwasher soap dispenser's spring. The spring is located behind the dispenser top's hinge. Consult your dishwasher's original manufacturer's manual or user guide to find a replacement spring. Pop the old spring out with a screwdriver, and replace with a new spring. This should resolve any issues related to the dispenser failing to open.
Please post comments if you need more help or information..........
Good Luck!!
Thanks
Jan 08, 2010 | Kenmore Dishwashers
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Apr 17, 2009 | Dishwashers
Dishwasher problem
Symptoms:
Dispenser lid is open. Caked powder at (what would be during normal operation) bottom edge of soap dispenser or caked powder fallen onto dishes or dishwasher bottom. There may be loose powder in rest of dispenser or spilled down inside door or onto dishes underneath dispenser.
Solution:
Keep the area around the soap dispenser lid clear when loading the top tray.
Explanation:
The soap dispenser needs to swing open during the wash cycle. In many dishwashers the top tray has an indentation as wide as the lid of the dispenser. This allows the top tray to be as large deep as possible while still allowing space for the dispenser lid to open. People often pack their dishwasher with things overhanging this gap.
During the wash cycle the catch will release but the overhanging cutlery or crockery prevents the lid from opening all but a few degrees. Some water will splash in but not enough to wash out the soap powder. The soap powder at the bottom of the dispenser will then cake.
When the front door is opened the spring loaded lid, which is partly open, will of course swing fully open and you'll be convinced that the lid opened normally during operation. If this is the problem then if you're very careful and open the door very slowly you can actually hear the lid flip open. Also, depending on when the lid opens, how far it opened during operation and how fast you open the door you may find soap powder spilled down to cover the dishes at the front or down the inside of the door. This happens when you first open the door and obviously there couldn't be loose powder there if the powder had emerged while there was water washing around. Seeing the lid open as you open the door is a lot harder but can be done on some machines.
Oct 24, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Mar 01, 2008 | Dishwashers
Dishwasher soap dispenser won't open during cycle
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Oct 26, 2007 | Dishwashers
GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
Apr 21, 2007 | GE 24 in. Monogram ZBD6880KSS Stainless...
Washing Machines Logo
228 people viewed this question
Top Washing Machines Experts
