Question about Maytag MMV5000 Microwave Oven
Maytag umc5200aas Microwave is totally dead.
When I got home there was no power on the unit. I went to reset the circuit and it wouldn't reset. I then unplugged the unit and tried to reset the circuit. It reset. I opened her up and tried to test the fuse by checking for ohms. It came back with 0 ohms so I assume it is good. What next? I'm not fully confident with tying to discharge the capacitor.
  • BCFIsher Apr 23, 2008
    The outlet is live...
  • wt51243 Sep 29, 2008
    I have had this same problem but I am witness to its failure. Sears repairman said he couldn't find a problem on the computer diagnostic but could clearly see it had tripped itself off. This used to happen only if I was cooking for long times (example 10 minutes) but now it happens in as little as 3 minutes. We don't even put the screws back in the face now so we can pull it out and click the reset. SO MUCH FOR THE MAYTAG REPAIRMAN COMMERCIAL!!
    Scholar:
  • 186 Answers
Be careful, a Microwave can be a death trap. Check outlet to make sure it's live. Could be a failed low voltage transformer.
Posted on Apr 23, 2008
  • Scott
    Scott Apr 24, 2008
    Do you have any warranty left? Also looks for blown capacitors (especially the small ones). If blown, they will most likely have a popped top on the capacitors. When a capacitor fails they typically put out a lower voltage and don't work well under a load. If one has failed, voltage may have dropped below operating level for the panel to power up. See if you get any DC voltage around the board at random points.
Microwave went totally dead while operating; there is power to the outlet.
If the control panel lights up intermittently, then you either have a loose connection somewhere near the panel, or a failing component on the circuit board itself.
Jul 10, 2015 | LG LMV1813ST Microwave Oven
Locating reset button on my microwave
To my knowledge none have a reset button or circuit breaker. If the unit is total dead there will be (has to be) a fuse inside the unit.
Dec 06, 2012 | Whirlpool Gh5184xps Microwave Oven...
It just has no power. Nothing happened, I just went to use it and it was dead.
The main fuse is blown, "ceramic type" usually caused by a defective door switch.
Apr 14, 2011 | Maytag MMV4205 Microwave Oven
I replaced my magnetron, and it went bad also. Why would this happen?
Could it be "finger trouble"?
A magnetron will fail within seconds if no food/liquid is placed in the oven cavity as there is no where for the energy to be dissipated and it will "cook" itself.
Is the high voltage supply and diode pack OK?
Mar 08, 2011 | Maytag UMC5200AAS Microwave Oven
Went to use microwave and it just went dead. Household power is fine and breakers are good. Replaced main fuse behind switch panel and got power back for clock etc.. When I went to run it again, it went...
short circuit in high tension power supply
DUE TO THE VERY HIGH AND DANGEROUS VOLTAGE 4000( V) IT IS NOT WISE TO FIX IT YOUR SELF UNLESS YOU KNOW WHAT YOU ARE DOING
Apr 26, 2010 | Maytag MMV5100A Microwave Oven
No power at display!
You've probably destroyed your magnetron, and the magnetron thermostat.
This kind of abuse will not be covered under warranty.
It will likely run about $75 for a technician to visit the home, $75 to do the work, $75-90 for the magnetron, and about $15 for the thermostat.
You can locate a Maytag-authorized servicer at http://www.maytag.com
Apr 24, 2010 | Maytag MMV4205 Microwave Oven
Sparks fly
This is not good. Get the unit serviced by a professional before you use it again.
Apr 19, 2010 | Maytag UMC5200AAS Microwave Oven
Broken rotating microwave arm - can't find part
That would be the support, and you can find it by entering your model number UMC5200AAS here.
Nov 22, 2008 | Maytag UMC5200AAS Microwave Oven
Maytag Microwave
Mine is a model UMC5200AAW. Same problem as above, no power. Is there a reste button?
Nubi541
Oct 07, 2008 | Maytag MMV5207A Microwave Oven
Maytag microwave - mod# mmv5100aaw
CHECK MAGNETRON RELATED CIRCUIT, HIGH VOLTAGE CIRCUIT, CONTROL CIRCUIT,AFTER CHECK MAINS FUSE.
Aug 29, 2007 | Maytag MMV1153A Microwave Oven
Maytag MMV5000 Microwave Oven Logo
272 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
