Hey Anon, The GM transmissions that are bolted to V8's need to have regular service when they are newer... fluid and filter every 50K for the first 150K, with a full fluid exchange at 150K,.. IF this has NOT happened to this vehicle, its time for a "rebuild-tune-up". I have seen this toooo many times... It should costs around $1400 -$1600..
I use a friend that has a transmission shop, he is a drag racer too...they KNOW how to repair transmissions to make them last! If you live near somewhere that has a drag strip.. go there and ask some of the racers who is the best automatic transmission man in town... USE HIM!!
SOURCE: 1998 Jaguar XJ8L Gear Box (transmission) Fault Light On
If you check, the replacement the dealer installed in your car was likely a "certa" unit which is another word for a factory rebuild. Therefore a rebuilt transmission will not be anything "new"
If you press the issue, you will likely get Jag to replace yours with another certa unit. You may need to make a bit more "noise" though.
In choosing a private shop to do this work, ask around and see who has a really good reputation."Branded" shops are franchises and as different as dogs and cats when it comes to quality. If you have friends with a similar car, see who they have used. If you use a private repair shop ask who they "job" their trans work out to.
It may take a bit of shopping but you likely will find someone who can do the right job for you!
SOURCE: 1997 Dodge Intrepid transmission slipping when warm
I was told to change my Transmission Control Module,located on the transmission . You can get it new for under $200 but, I was advised to get it from a junk yard it's alot cheaper and its easier. I hope this helps
SOURCE: 2001 chevy impala transmission will not stay in gear
a chevy mechanic suspected shift cable was worn or damaged...mine will sometimes engage..and then wont engage at all even tho shifter moves freely....
SOURCE: Cadillac Deville 2000- Engine check light code P0741
i was having the same problem took it to the dealer and they reset the fault. i have been riding good since. they initialy said it was the Torque Converter but turns out it rides fine, been driving that way for about 2 years.
SOURCE: 95 dodge stratus transmission problem
98 dodge stratus at trans goes in 3 forward gears but no reverse...any guesses???
