Question about Vacuums
My Bissel Quick Clean no belt cleaner no longer has any suction power.
    President:
  • 1,673 Answers
You did not give model number, are you sure there is no belt? If no suction, check filters make sure they are clean. Check the hose and dirt inlet by the brush roll to see if you have a clog.
Posted on Apr 24, 2008
When bissel turbo steam cleaner wont suck
google it:
My ProHeat 2X® is not suctioning properly. What ... - Bissell
www.bissell.com/faqdetail.aspx?id=1124 BissellAnswer: Let's start by figuring out where your carpet cleaner has suction. Check for ...If the Lint Screen is dirty, the suction won't be very strong. Cleaning the
Jul 20, 2015 | Vacuums
Bissel powerwash 1690 does not dispence water
Hey George, not having spray when you're ready to clean can be frustrating.
Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1052&cid=ccsocial
Jan 21, 2013 | Bissell Carpet Cleaner Powerbrush Deep...
My bissel vacuum 2x cyclonic action cleaner item #3920 rubber drive belt broke and there isn't any suction.
If you go to this URL http://www.bissell.com/assets/0/132/134/228/e5babada-7240-40ea-93c0-90427ed32741.pdf You will find the users manual that describes what to do to replace the belt. I suggest that when you remove the brush, clean it as best you can, paying special attention to the plastic clips on each end. I would spray some WD40 between the clips and the brush and turn the clips until they move freely. If you find my solution to be of help to you, I would appreciate a Thumbs Up from you. Paul
Oct 13, 2010 | Bissell Vacuums
How can determine when it's time to replace the drive belt on my Bissel Power Steamer? Is there a certain number of hours of usage that I need to keep track of or does the belt replacement depend on the...
Usually, replacement is needed when the brush no longer runs or is intermittent. Check the brush bearings and for debris build-up whenever the belt is changed. Good luck!
Jun 12, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Will not **** the dirty water back in.
check for clogs in hoses and head.mine gets clogged up all the time.
Jun 06, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Water doesn't come out of my Bissel Deep Cleaner
Did you use TAP water...not a good idea.Use de-mineralized water you can get at most pharmacies,there is probably mineral buildup in the lines.
Mar 23, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Bissel pro heat cleaner won't expell water -- seems no suction
The reason that it won't expel water is because your pump belt is stretched and worn. You need to replace that belt, it is pretty easy. Here is the belt you need:
Bissell ProHeat Pump Belt
Jan 30, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
