Question about Brother LS-1217 Mechanical Sewing Machine
Feed dog & auto threader problems.
Feed dog seems to "slip" and the fabric will not advance when the material is thicker. It sounds as if the teeth of the gears underneath the feed dog of the machine are not lined up properly or are slipping. This creates a thudding sound. Are the gears metal or plastic? I have tried adjusting the feed dog switch on the back of the machine but it does not change anything. Also the automatic threader will not work correctly. I plan on getting the machine serviced and cleaned but is there anything else I can do or adjust to help?
I'm having the same problem. The machine seems okay with one layer of fabric, but it doesn't feed the fabric through if it gets any thicker than that. It, too, is making a weird noise when this happens. I've oiled the machine and cleaned off all the fuzz that I can find.
  • Brother Master
  • 1,388 Answers
Remove the needle plate and clean the lint from between the teeth of feeddogs, also around and inside bobbin case.
The switch for the feeddogs is to raise (normal sewing) or lower (free motion) and if there is no difference, the accumulated lint will have made a felt pad between the teeth forcing the feeddogs to stay down and present with the problem you describe.
When things go a little "weird", the common instinct is OIL EVERYTHING............DON'T DO IT !!! ....this is rarely the solution on its own account, and can make the servicing a great deal longer as the excess must be removed........little oil regularly, not a bucketful every 5 years is a better approach.
Posted on Jun 09, 2008
Singer 6235 - the fabric is not advancing regardless of stitch length or tension
Could be any of a multitude of reasons.
Check whether the feed dogs are actually rising 'above' the needle plate. If not, then they may be in a dropped position used for darning and free motion quilting.
Sometimes the feed dogs and the mechanism underneath is jammed with lint and debris. Make sure the dog teeth are well cleaned. Also check if the tips of the teeth are worn. Also verify that the needle plate is flush with the free arm--if it is raised, it will prevent the feed dogs from doing their job.
The other thing to check is whether the machine has a presser foot pressure adjustment. Some machines have it, others do not. On newer machines, it is usually a dial somewhere around the left side of the head or toward to top of the head. On older machines, unfortunately, some are simply a big screw head on the inside of the case directly above the presser foot bar. It basically applies more pressure to the presser foot, which in turn applies more pressure to the feed dogs. The problem will usually show up when sewing either very heavy or very fine fabric. Perhaps trying a different presser foot will make a difference.
I don't know what is the highest number the stitch length goes to on your machine, but a #2 stitch length is pretty short on mine. Try setting it higher.
Sewing Machine Presser Foot Stuck
Singer 6235 User Manual
Nov 19, 2017 | Singer Sewing Machines
Singer touch tronic 2000 feed dog will not advance fabric
Confirm the feed dogs are raised. Make sure the feed dog teeth, area under the needle plate and the bobbin area are clean of any debris, thread, or buildup. Some machines also have a presser foot pressure adjustment that increases the pressure the presser foot applies to the feed dogs. The feed dogs could be worn (never run the sewing machine without fabric between the presser foot & feed dogs).
https://www.manualslib.com/manual/508740/Singer-Athena-2000.html
Or, the machine has not had a thorough cleaning and oiling recently and the feed dogs are sticking from old oil.
Wheel on right side that controls the needle up and down is very tight...
Jul 30, 2017 | Singer Sewing Machines
Fabric not advancing
Make sure the feed dogs are not in the dropped position (for darning).
If it is very light-weight fabric, most machines will have a presser foot pressure adjustment that will increase the presser foot's pressure on the feed dogs, thus pulling the fabric through better.
Make sure the feed dogs are clean--no debris stuck between the teeth, under the feed dogs, or around the bobbin case. If it is an older machine that has been used a lot, the feed dogs could be worn down and need replacement or adjustment. (Do not run the machine with the presser foot directly on the feed dogs. This will cause excessive wear to the feed dogs and the presser foot.)
Jul 25, 2017 | Sewing Machines
THE FEED DOG ON MY EUROPROX 473B IS NOT MOVING FRONT TO BACK SO IT IS NOT FEEDING MATERIAL THROUGH WHAT COULD BE THE CAUSE?
Check that the feed dogs are in the "up" position for sewing (not dropped for darning). Also, verify that the stitch length is set to around #2 or 2.5. This will move the fabric well enough that it will actually advance with the feed dogs. If the stitch length is too short, the fabric will not advance sufficiently and will cause the needle to stitch in place.
If this does not cure the problem, you should take it for service.
May 12, 2016 | Sewing Machines
My sewing machine wont RUN. The needle goes up and down but the material wont move along.
under the foot around the needle, there should be two rows of what look like teeth, these pull the material through and there will be an adjustment mechanism on the machine. Try leaving the foot up while you run the machine, you should see the teeth going up and down; if they are it is most likely just a case of setting up the amount of pull. I think it is adjusted with the wheel that sets the length of stitch.
Apr 07, 2016 | Sewing Machines
Brother CS6000i with setting 00 for straight line stitch is making a left curve stitches instead going straight.
***Your feed dog under the pressure foot seems to be pulling on one side a little harder which indicates wear. It is likely to solve the problem by replacing the feed dog.
***Before you do this try to lower the pressure on the pressure foot. If the material you are sewing is thick it will have an effect on the pull of the feed dogs. The material you are sewing that you sent appears to be jeans material. It looks like it is thick and somewhat slippery.
Oct 05, 2015 | Brother Sewing Machines
How do i get the material to feed through
depending on the brand of sewing machine you have, make sure it's not in the darn mode,, make sure the presser foot is against the fabric so the feed dogs can pull it thru,,if the presser foot is against the fabric correctly then the feed dogs may need to be check to see if they need a adjustment or replacing
Dec 02, 2014 | Sewing Machines
My machine is not feeding the fabric through the machine
Your feed dogs under neath are probaly down. There is a button to raise and lower them.You can feel them with your fingers underneath the needle. Some machines have three seetins on the feed dog.s Hope this works for you.
Aug 25, 2014 | Sewing Machines
Singer Sewing Machine model #2638 Does not feed fabric
Here is a link to page 22 of the manual. It shows you where to flip the lever to raise the feed dogs. If your feed dogs are not grabbing fabric your feed dogs are lowered.
https://www.manualslib.com/manual/1050311/Singer-2638.html?page=23#manual
Sep 20, 2012 | Sewing Machines
How do I get the teeth to grab and advance the material on my very old Bernina 830?
Well there's a number of reasons why it may not be advancing the material. First, ensure that the teeth are completely cleaned-out - get an old toothbrush, or similar with firm filaments and, with the stitch-plate removed and the bobbin door open, give the teeth a really firm clean across the teeth to remove anything in between ... this is especially important if you've been sewing with metallised fabric or thread. If the teeth are nice and clean, check if they are still pyramidal with a reasonably 'sharp' point facing backwards - if the machine is very old and very well used, the teeth might be rather rounded and it may be time that you have a new feed dog fitted ... some of the old machines are difficult to obtain spares, but they're mostly still out there. Most commonly, check how far the teeth of the feed dogs protrude above the stitch plate ... this is a bit difficult to do and should really be done with a proper gauge, but generally they should protrude 1mm above the stitch plate - less than that and you wont get the material to move properly, especially if its fine material. Lastly, it could be the foot pressure that's the problem ... if there's inadequate foot pressure, the material will not be pushed adequately onto the dogs. Again, unfortunately, you really need a proper gauge to set the foot pressure, but if the dogs are clean, in reasonable condition and have 1mm of clearance above the stitch plate, you can try increasing the foot pressure a bit. This is done by opening the top cover and you will see a large-ish flat-blade screw in a threaded tube just behind where the needle bar goes up and down and to the left of the takeup arm. If the screw is rather near the top of the threaded tube, you can try screwing it down (clockwise) maybe 2-3 turns to see if it makes a difference ... of not, dont be tempted to just keep screwing up the pressure ... there's something else wrong. Oh .... and by the way .... before you've done any of the above, I assume you've checked that the feed-dogs are not dropped ! You can drop the feed-dogs to do embroidery etc on the 830 - there's a small round knob below the stitch length control - make sure its turned to the position that shows a tooth pattern and not the cross-hathced pattern and make sure the feed dogs do actually come above the stitch plate when turning the handwheel - if they dont, or moving the feed-dog drop control doesn't make any difference, then the link mechanism is almost certainly jammed (really, really common on old machines that haven't been regularly maintained!). To free that off, you need to remove the free-arm cover and look to the front right side of the mechanics - you'll see a linkage that should turn when you rotate the feed-dog drop control - if this doesn't separate or is permanently separated, whatever you do with the control, you need to give it a drop or two of Bernina sewing oil and gently help it move - once free, that should solve the problem. I cant think of any other reasons !!
Hope that helps !
Nov 16, 2011 | Bernina Sewing Machines
Brother LS-1217 Mechanical Sewing Machine Logo
140 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
