Question about Philips GoGear SA178 MP3 Player
HELP MY PHILIPS USB HAS POPPED OUT
Hey my usb popped out and i need to put it bak in but the cover won't come off i need to find out how to take it off
cheers
  • 8,596 Answers
Pull harder.
Posted on May 26, 2008
Lexmark X5495 paper jamming in automatic feeder
It is possible that the hinge that popped out is causing some trouble feeding the paper into the printer. That may be difficult to repair on your own and Lexmark does not have replacement for that part. You can try to have it repaired in some shops.
If not, try to contact Lexmark technical support center for your options. Thanks.
Dec 20, 2011 | Lexmark X5495 All-in-One &USB...
I own a Philips GoGear RaGa 4GB MP3 player, and downloaded Songbird. I imported my iTunes library, along with all playlists, and the transfer from iTunes to Songbird was successful. I only wanted one of my...
I had the exact same thing happen! It was driving me up a wall trying to figure it out. Finally I decided to go to the START menu and hit RUN. Figured I'd go to the E:/ drive and see if I could do something from there.
A little box popped up, saying that the device was not formatted and asked if I'd like to format it. So I hit yes, read the lil info that popped up on the boxes, and clicked the QUICKFORMAT box. That seemed to do it for me, my device took the music back on it.
Hopefully that works for you. Typically I'm a Zune fan, but mine I had for 6 years and it finally croaked on me. Plus I needed something small to take with me jogging and this seemed to be the perfect solution. If that doesn't take care of it, I say take it back to the store and get it replaced or get it repaired.
Jan 21, 2011 | Philips GoGear Flash MP3 Player
Usb thing popped out
this would be alot easier on a desk top but something like this happened to me awhile ago and what i did was open the compuer and find where the cord connecting the usb port is. Your cord most likely got disconnected and you need to connect it again. That should fix it.
Mar 10, 2010 | Logitech ClearChat Pro USB Headset
Firmware download for MAC
hey same problem here, but I just downloaded the CD version anyways... then dropped the .RUF file onto my desktop, selected it, burnt it to a CD-R (RW will also work) and popped it into the BD-P1500, so far it seems to be running along steadily in the update process... hope this solves your problem.
Apr 16, 2009 | Samsung BD-P1500 Blu-Ray Player
I try to download songs, but AutoPlay keeps popping up.
Test another USB port on your computer, and see if you get the same result. If you get the same result, the USB cable may be faulty.
Here is a test you can do to see if the problem really is the USB cable, or if it is something else:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Feb 02, 2009 | Philips SA3025/37 Flash MP3 Player
I can't remove battery cover of new samsung j700
Get some bluetack and place underneath the samsung logo on the battery cover and press down on it firmly to secure the bluetack, then to remove press down really firmly and slide in an upwards motion.
Nov 11, 2008 | Samsung J700 Cellular Phone
Help!!!
If you have clicked repair, and it is telling you that the repair failed, then the player needs to be replaced.
Otherwise:
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jun 26, 2008 | Philips SA5125/37 MP3 Player
USB plug thingy wont come out and slide cover broken
I had the same problem you can go to sony.com and get everything worked out you may need to lie but it will get fixed just don?t say weather or someone broke it or they will say not covered it is a bought $15-25 tops hope this helped. And you can use a small flat head screwdriver to release the USB.
Aug 04, 2006 | Sony Walkman Bean NW-E305 MP3 Player
Philips GoGear SA178 MP3 Player Logo
29 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
