Reg step 7 programming
Hello sir
I want to know about the 611U drive FB 81 block and how it is been executed in plc and how the udt is been called for positioning the axis
The UDT is a user defined table in which an associated data block is created .In this Data block all the paremeters are being showen which the value can be modify by the user
Posted on Apr 26, 2008
Tip
INSTALL WINDOWS 7 USING USB PEN DRIVE !!!!!!!!
Requirements:
*USB Flash Drive (Minimum 4GB)
*Windows 7 or Vista installation files.
Follow the below steps to create bootable Windows 7/Vista USB drive using which you can install Windows 7/Vista easily.
1. Plug-in your USB flash drive to USB port and move all the contents from USB drive to a safe location on your system.
2. Open Command Prompt with admin rights. Use any of the below methods to open Command Prompt with admin rights.
*Type cmd in Start menu search box and hit Ctrl+ Shift+ Enter.
Or
*Go to Start menu > All programs > Accessories, right click on Command Prompt and select Run as administrator.
3. You need to know about the USB drive a little bit. Type in the following commands in the command prompt:
First type DISKPART and hit enter
Next type LIST DISK command and note down the Disk number (ex: Disk 1) of your USB flash drive. In the below screenshot my Flash Drive Disk no is Disk 1.
4. Next type all the below commands one by one. Here I assume that your disk drive no is “Disk 1”.If you have Disk 2 as your USB flash drive then use Disk 2.Refer the above step to confirm it.
So below are the commands you need to type and execute one by one:
SELECT DISK 1
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(Format process may take few seconds)
ASSIGN
EXIT
Don’t close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Next insert your Windows7/Vista DVD into the optical drive and check the drive letter of the DVD drive. In this guide I will assume that your DVD drive letter is “D” and USB drive letter is “H” (open my computer to know about it).
6. Maximize the minimized Command Prompt in the 4th step.Type the following command now:
D: CD BOOT and hit enter.Where “D” is your DVD drive letter.
CD BOOT and hit enter to see the below message.
7. Type another command given below to update the USB drive with BOOTMGR compatible code.
BOOTSECT.EXE /NT60 H:
Where “H” is your USB drive letter. Once you enter the above command you will see the below message.
8. Copy your Windows 7/Vista DVD contents to the USB flash drive.
9. Your USB drive is ready to boot and install Windows 7/Vista. Only thing you need to change the boot priority at the BIOS to USB from the HDD or CD ROM drive. I won’t explain it as it’s just the matter the changing the boot priority or enabling the USB boot option in the BIOS.
Note: If you are not able to boot after following this guide means you haven’t set the BIOS priority to USB. If you got any problem in following this guide feel free to ask questions by leaving comment.
on Apr 02, 2010 | Computers & Internet
I cannot access my transcend Elite software as my computer says publisher unknown. What do I do?
This is what I researched on the Microsoft support page. It seems that you have a issue with what is called the UAC (User Account Control>
Here is the explanation: this is from the KB article.
Explaining the User Account Control (UAC) technology
User Account Control (UAC) was a new security-feature and technology introduced first in Windows Vista™ and later migrated and added to Windows® 7.
The way UAC works: When we execute a normal program, UAC first checks if that program has keywords like "setup", "install", "update" etc, using the UAC Installer Detection Technology (IDT) (If is a setup.exe then elevate). UAC also checks the programs manifest file for the "requireAdministrator" tag added in its manifest configuration, if that is found, UAC will then go to the next step. When UAC has confirmed the first step, UAC will check if that program is
blocked by policy or if the programs publisher is blocked, when UAC successfully confirms that it goes to the next step.
When UAC has confirmed the first two steps, it then checks if the publisher of that program is "Windows®" it's self, but in our case it isn't so UAC goes to the next step and checks for a regular publisher. If the publisher is verified (this means also that the program has a valid digital signature) then UAC will prompt with a gray background and gold shield icon: "The application is Authenticode signed and trusted by the local computer".
UAC in Windows® 7: UAC under Windows® 7 is basically the same, except that they done some "small" modifications. But, still the same rules apply in Windows® 7 as in Windows Vista™.
The modern programs under UAC restrictions
Modern applications/programs that run under UAC restrictions have their power to become "trusted"-apps. Programs like Google Chrome or other (e.g. Avast Antivirus, Mozilla FireFox or any other), are put into trusted directories (e.g. C:\Program Files\ and C:\Program Files (x86)\), and they are of course signed with a digital signature [For example: A signature from the VeriSign Time Stamping CA].
Please contact the manufacturer
You will need updated driver set for your External USB storage device usually found at the manufacturers site. You can disable the UAC but this is not recommended.
Jul 13, 2011 | Transcend Storejet 25m2 500 Gb External...
Error 1722
You may encounter the following error on installation:
Installation ended prematurely because of an error
when trying to install 32-bit or 64-bit qlikView on Windows 7. With or without UAC (User Access Control), installation fails.
Suggestions to (re-)install vbscript.dll using regsvr32 vbscript.dll in the c:\windows\system32 (64-bit equivalent) directory didn't help.
On execution of the installer, c:\program files\common files\wise installation wizard has a new msi added that includes the full installer for the qlikView application.
Installation worked by opening your command window (Start -> (All Programs) -> Accessories ->Command Prompt (right-click and run as Administrator) by calling the msi, above, with a few switches:
msiexec /a WISB3[...].msi
That worked.
The command-line registry fix as below
reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f
didn't do anything...
Mar 30, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Hello sir, my problem is i want install windowxp window7 and sun solaris 10 use kinston pan drive but i am trying after i have failed please tell me, how can i do and please complete solusion, ...
Hello sir, to install window xp and 7 using a kinston pen drive you will to have a software called win to flash. Its a software that allows you to install window 7 and xp from a pen drive and for the sun solaris you also need a software called unetbootin that allows you to install solaris using a pen drive. You can google these softwares to download them for free. I hope this solution is helpful. Have a wonderful day.
Oct 23, 2010 | Computers & Internet
I forgot my password to get on to the computer itself is there a way to figure out the password computer has windows 7
theres no solution for that sir, your only solution is to reformat your laptop so you can use it or if you have another user, download a password hacker..
hope this will help sir! thanks!
Jun 29, 2010 | Toshiba Satellite A100-S8111TD Notebook
When i download the hw conf. in the plc im151 pn/dp after that plc mode is in stop and all modules sf led glowing(group error) Please tell me the solution
Re-check your hardware configuration.Make sure you correctly configured each slot ast to the type of hardware that is there. Make sure your program is not calling for a function (block transfer etc) to a module that isn't there.
Mar 09, 2010 | Siemens ENERGY & AUTOMATION W0404MB1200CT...
How to install rar prog on linux?
You can downoad rar program for linux from following link. Also you can dowbload step by step installation manual.
http://peazip.sourceforge.net/
Mar 03, 2010 | fedora Linux Operating System
S7 226 Siemen's Plc programming
Hi there, you can check out this link Learn PLC programming.
This web site runplc.com is great resource for anything you like about PLC programming, free programs for programmable logic controllers, and much much more about PLC programming basic
Feb 04, 2008 | Computers & Internet
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
