Question about Singer 1525 Mechanical Sewing Machine
Lost manual. how to thread? - Singer 1525 Mechanical Sewing Machine
  • 323 Answers
All machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Posted on May 23, 2008
I'm not sure how to thread my machine, I lost my manual elna lock pro 5Dc
I would suggest that you buy a new manual for this as your overlocker has 5 threads that need to be threaded up correctly to form a stitch and there are several different stitches that can be made with this model such as a rolled hem, chain stitch, three thread overlock, four thread overlock and safety stitch with three thread overlock, lots to learn.
You can buy a manual here for $USD14.99: http://www.sewingpartsonline.com/instruction-manual-elna-pro5dc.aspx
or this website has a copy for $USD10.
http://www.sewusa.com/Sewing_Machine_Manuals/Elna_Manuals/Pro_4DC_DE_Instruction_Manual.htm
Always well worth buying the manual and saving a lot of frustration trying to guess how things work and it adds value if you are going to sell the item.
You can get some general overlocker threading tips from http://sewing.about.com/od/sergersoverlock/ss/serger.htm which may help you too.
Aug 31, 2011 | Sewing Machines
Riccor model 939FA thread keeps breaking, not shure if it is threaded correctly, manual lost years ago, thread has been nesting on bottom of material, now just breaking.
Try looking for a manual for your machine here.
http://www.riccar.com/help/manuals/
If your model number isn't listed try looking for a similar model or the number nearest to your machine.
Usually, sewing machines of the same brand thread in the same way. Hope this helps!
Sep 11, 2010 | Riccar R651 Mechanical Sewing Machine
The air part does not function and I can not thread my loopers on the eclipse
Make sure all the settings are as they should be for threading and try again.
You can manually thread the loopers with a very fine gauge guitar wire or beading thread (looks like fishing line) with a loop on one end to hold the thread.
If you still cannot get the machine threaded, take it to a dealer to see if they have a wire threader instead of the DIY method I explained.
Get a wire threader for the machine from the dealer and store it in a safe place as it is easily lost - I lost mine 2 years ago - they are so thin they disapear!
Feb 09, 2010 | Baby Lock Eclipse Serger
Threading and Bobbing
http://www.brother-usa.com/manuals/default.aspx?ProductGroupID=3&WT.cg_n=Support&WT.cg_s=Manuals
Apr 07, 2009 | Brother LS-1520 Mechanical Sewing Machine
I lost the manual to my Brother Homelock 920D serger. I want to know how to thread and use it.
i need information on threading a 920D brothers serger, on paper so i can take it to my machine to thread
Mar 04, 2009 | Brother Lay-In Thread Serger Mechanical...
How to i thread it
You can download the manual from the link below: http://www.simplicityhomecare.com/manuals/ There is a quick start guide & full manual. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 21, 2007 | Simplicity Liberty SA1600 Mechanical...
Singer 1525 Mechanical Sewing Machine Logo
116 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
