Question about Sony VAIO PCG-K35 Notebook
Testing 1..2...3 just a test of this system, to see what options arise
  • Patrick Michaels
    Patrick Michaels Apr 23, 2008
    thanks dwarfsoft..welcome to fixya..just testing the Geeksquad tie in..
  • 30 Answers
The solution to this is to confirm that your test problem has been successully logged.
Posted on Apr 23, 2008
I have memory loss,impotency, digestive problems and slow on thinking on occasions
This can arise from several causes, which especially affect older men. Some of these tend to occur together. You need specialised tests to ferret out the cause, maybe blood tests, cardio and vascular tests, and neurological tests. Get along to the doctor pretty soon.
Mar 24, 2016 | Health & Beauty
Beep codes
AMI BIOS beep codes Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code Descriptions 1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed Award BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary. Beep Code Description 1 long, 2 short Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information Any other beep(s) RAM problem. If any other correctable hardware issues is found the BIOS displays a message. No Power, Loose Card, or Short.1 Short BeepNormal POST, computer is ok.2 Short BeepPOST error, review screen for error code.Continuous BeepNo Power, Loose Card, or Short.Repeating Short BeepNo Power, Loose Card, or Short.One Long and one Short BeepMotherboard issue.One Long and Two Short BeepsVideo (Mono/CGA Display Circuitry) issue.One Long and Three Short Beeps.Video (EGA) Display Circuitry.Three Long BeepsKeyboard or Keyboard card error.One Beep, Blank or Incorrect DisplayVideo Display Circuitry. Phoenix BIOS Q3.07 OR 4.X Beep Code Description and what to check 1-1-1-3 Verify Real Mode. 1-1-2-1 Get CPU Type. 1-1-2-3 Initialize system hardware. 1-1-3-1 Initialize chipset registers with initial POST values. 1-1-3-2 Set in POST flag. 1-1-3-3 Initialize CPU registers. 1-1-4-1 Initialize cache to initial POST values. 1-1-4-3 Initialize I/O. 1-2-1-1 Initialize Power Management. 1-2-1-2 Load alternate registers with initial POST values. 1-2-1-3 Jump to UserPatch0. 1-2-2-1 Initialize keyboard controller. 1-2-2-3 BIOS ROM checksum. 1-2-3-1 8254 timer initialization. 1-2-3-3 8237 DMA controller initialization. 1-2-4-1 Reset Programmable Interrupt Controller. 1-3-1-1 Test DRAM refresh. 1-3-1-3 Test 8742 Keyboard Controller. 1-3-2-1 Set ES segment to register to 4 GB. 1-3-3-1 28 Autosize DRAM. 1-3-3-3 Clear 512K base RAM. 1-3-4-1 Test 512 base address lines. 1-3-4-3 Test 512K base memory. 1-4-1-3 Test CPU bus-clock frequency. 1-4-2-4 Reinitialize the chipset. 1-4-3-1 Shadow system BIOS ROM. 1-4-3-2 Reinitialize the cache. 1-4-3-3 Autosize cache. 1-4-4-1 Configure advanced chipset registers. 1-4-4-2 Load alternate registers with CMOS values. 2-1-1-1 Set Initial CPU speed. 2-1-1-3 Initialize interrupt vectors. 2-1-2-1 Initialize BIOS interrupts. 2-1-2-3 Check ROM copyright notice. 2-1-2-4 Initialize manager for PCI Options ROMs. 2-1-3-1 Check video configuration against CMOS. 2-1-3-2 Initialize PCI bus and devices. 2-1-3-3 Initialize all video adapters in system. 2-1-4-1 Shadow video BIOS ROM. 2-1-4-3 Display copyright notice. 2-2-1-1 Display CPU Type and speed. 2-2-1-3 Test keyboard. 2-2-2-1 Set key click if enabled. 2-2-2-3 56 Enable keyboard. 2-2-3-1 Test for unexpected interrupts. 2-2-3-3 Display prompt Press F2 to enter SETUP. 2-2-4-1 Test RAM between 512 and 640k. 2-3-1-1 Test expanded memory. 2-3-1-3 Test extended memory address lines. 2-3-2-1 Jump to UserPatch1. 2-3-2-3 Configure advanced cache registers. 2-3-3-1 Enable external and CPU caches. 2-3-3-3 Display external cache size. 2-3-4-1 Display shadow message. 2-3-4-3 Display non-disposable segments. 2-4-1-1 Display error messages. 2-4-1-3 Check for configuration errors. 2-4-2-1 Test real-time clock. 2-4-2-3 Check for keyboard errors 2-4-4-1 Set up hardware interrupts vectors. 2-4-4-3 Test coprocessor if present. 3-1-1-1 Disable onboard I/O ports. 3-1-1-3 Detect and install external RS232 ports. 3-1-2-1 Detect and install external parallel ports. 3-1-2-3 Re-initialize onboard I/O ports. 3-1-3-1 Initialize BIOS Data Area. 3-1-3-3 Initialize Extended BIOS Data Area. 3-1-4-1 Initialize floppy controller. 3-2-1-1 Initialize hard disk controller. 3-2-1-2 Initialize local bus hard disk controller. 3-2-1-3 Jump to UserPatch2. 3-2-2-1 Disable A20 address line. 3-2-2-3 Clear huge ES segment register. 3-2-3-1 Search for option ROMs. 3-2-3-3 Shadow option ROMs. 3-2-4-1 Set up Power Management. 3-2-4-3 Enable hardware interrupts. 3-3-1-1 Set time of day. 3-3-1-3 Check key lock. 3-3-3-1 Erase F2 prompt. 3-3-3-3 Scan for F2 key stroke. 3-3-4-1 Enter SETUP. 3-3-4-3 Clear in POST flag. 3-4-1-1 Check for errors 3-4-1-3 POST done - prepare to boot operating system. 3-4-2-1 One beep. 3-4-2-3 Check password (optional). 3-4-3-1 Clear global descriptor table. 3-4-4-1 Clear parity checkers. 3-4-4-3 Clear screen (optional). 3-4-4-4 Check virus and backup reminders. 4-1-1-1 Try to boot with INT 19. 4-2-1-1 Interrupt handler error. 4-2-1-3 Unknown interrupt error. 4-2-2-1 Pending interrupt error. 4-2-2-3 Initialize option ROM error. 4-2-3-1 Shutdown error. 4-2-3-3 Extended Block Move. 4-2-4-1 Shutdown 10 error. 4-3-1-3 Initialize the chipset. 4-3-1-4 Initialize refresh counter. 4-3-2-1 Check for Forced Flash. 4-3-2-2 Check HW status of ROM. 4-3-2-3 BIOS ROM is OK. 4-3-2-4 Do a complete RAM test. 4-3-3-1 Do OEM initialization. 4-3-3-2 Initialize interrupt controller. 4-3-3-3 Read in bootstrap code. 4-3-3-4 Initialize all vectors. 4-3-4-1 Boot the Flash program. 4-3-4-2 Initialize the boot device. 4-3-4-3 Boot code was read OK.
http://www.computerhope.com/beep.htm
Jul 09, 2014 | EliteGroup GeForce6100PM-M2 Motherboard
How do i tell that my UPS batteries need to be replaced
UPS makes self simpler tests regularly, if problems arise alerts UPS.
You can break the input voltage to the UPS and have it run on battery for 20 minutes, if your load accept the risk of power interruptions ...
May 23, 2014 | Belkin (F6C550-AVR) (DBF6C550AVR) UPS...
The tv wont light up
1) test the power supply , see the blown fuse or c.breaker tripped and reset.
2) Proof again, if the problem persist the problem arise with the power supply, some diode, capacitor, resistor, etc can be open or short. repair.test the power cord too, and main switch for open
3( see the diagram .God bless you
Jul 12, 2012 | RCA F36650 36" TV
Hello Guys 1010us pavilion dv5 model when I play games it shuts down. So yesterday while watching Youtube it shutted down again. And blue screen is appearing and it shows that there is a problem with hdd...
Well if you got an error related to the hard drive then its better to check the hard drive whether is faulty or not..
1.Shut the system down.
2.Restart the system and tap on the F10 key for while till we dont get to the set up utility.
3.As soon as we get to the BIOS screen try locating an optionw which reads as DIAGNOSTICS, it would be the third option at the top,
4.Select that option using the arrow keys on the keyboard and hit enter.
5.It would show us an option which reads as Primary Hard drice self test..
6.Hit enter again to start the test.
7.There are 2 types of tests.
8.As soon as we start the test it would start the SHORT TEST first which would take a couple of minutes.
9.If it comes with any errors then call hp and ask them to replace the hard drive.
10.If the short test passes and the comprehensive test starts then let that test run completely which might take an hour as well..
11.If this test goes fine then the hard drive is fine and you are facing trouble because of the graphices card installed on the system.
12. I am providing you a couple of drivers which you can try installing depending on the operating system installed on the system.but you need to first check the hard drive and then perform these steps..
I believe the system was shipped with a 64 Bit Vista which NVIDIA graphics card.
I am providing you the drivers for that
ftp://ftp.hp.com/pub/softpaq/sp41501-42000/sp41696.exe
You can also try to update the BIOS which would the next step if the above steps does not help..
The link is :
ftp://ftp.hp.com/pub/softpaq/sp45001-45500/sp45138.exe
Hope this works
Regards
KEN
May 11, 2010 | HP Pavilion FE849UA Notebook
System hangs after 5 minute 0f os Ubuntu
The issue might be due hardware malfunction or lack of system performance or corrupt os.
perform hard drive self test:
Hard Drive Self Test:
1. If the notebook computer is running solely on battery power, plug the AC adapter into the notebook.
2. Shut down the computer if it is running.
3. Press the power button to turn on the computer.
4. Press f10 when the HP/Compaq logo displays.
5. After the BIOS Setup Utility displays, use the Right Arrow key to select the Diagnostics menu.
6. Select HDD Self-Test options .
7. Press enter to display a list of HDD/Self-Test options.
8. Select Notebook Hard Drive and then press f10 to display an Estimated test time .
9. Press f10 to continue. The Hard Drive Self Test executes a Quick test , a Comprehensive test, and a SMART test.
If test pass then perform below steps:
Improve system performance:
Follow the steps provided in the below url:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00815926
if persists, restore the ntoebook to factory settings.following below steps in the url
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00809678&product=18703:
Mar 26, 2010 | HP Pavilion dv9000z Notebook
PXE-E61: media test failure check cable
"PXE-E61 Media Test Failure, System won't boot"
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration(F10)
This Will Solve this problem
May 25, 2009 | Compaq Presario-Notebook 700 Series, 2500...
Hi i need to know that how to programmed the timer test
you should have your company program this. howerver her is the infor if you know hoe to get into programing.
Option 16: Auto Phone Test (Default = off)
Determines whether the panel automatically performs a periodic
phone test (on) or not (off).
The test interval can be from 001 - 254 days. Entries must be
3 digits. The time of day the panel performs the test is determined
by Option 72: Supervisory Time, which must be
turned on for this feature to work.
Note
For UL 1635 listed systems, Auto Phone Test must be set to 001
days.
 To set Auto Phone Test, press:
1. Add
2. Option #
3. 16
4. Use the numbered keys to enter the number of
days 001 - 254 (all entries must be 3 digits).
5. DONE
 To turn off Auto Phone Test, press:
1. Delete
2. Option #
3. 16
4. DONE
mj
Dec 05, 2008 | GE Security Simon 3 Wireless Home Security...
Laptop touchpad
Look for a driver on dell... if that doesnt work then get a new touchpad or send it back to dell and tell them to shove it.
May 03, 2008 | Dell Inspiron 6000 Notebook
Sony VAIO PCG-K35 Notebook Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
