Question about Sony KP-51WS520 51" Rear Projection HDTV-Ready Television
Sony projection blinks 9 times
The tv clicks but the picture doesn't light up.. then the code blinks 9 times. About 5 months ago I changed out the D6116 and D6114 diodes and it started working again until now. I pulled the G board and the diodes seem to check ok with the Fluke diode tester, about .5 volts. I do get some odd readings on the D6109 diode. Please advise. Thanks
  • 1 more comment
  • David Kearney Apr 23, 2008
    At first when it wouldn't come on. No sound, no picture. Then I kept trying turning it on and off. A couple of times no picture and then sound for a minute then nothing. The next day I tried again and everything worked normally. We just didn't turn it off for a few days but when we did, back to nothing again no picture, no sound just blinking code. Tried turning it on several times over the next couple days but nothing. I guess it could be the same diodes I changed out before failing again. Should I go to a 1/2 watt diodes if I can find them.
    Actually I am an electrician working for the power company. I think the voltage stays a pretty steady 123 VAC. But it's always possible we are getting some spikes.
    I replaced the two diodes on the A board. Still when I hit the power button their is a click but no picture or sound, then 10 red blinks, then it eventually will turn itself off.
  • 3,037 Answers
According to the manual
9 times
, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
Buy you have no picture you say? Do you have no sound too or just no picture
Please get back to me on this and I will further assist you
Thank you for using Fixya and Have a Good Day!
Posted on Apr 23, 2008
  • 2 more comments
  • Benjamin Patri
    Benjamin Patri Apr 23, 2008
    instead of "buy" it should be "but"
  • Benjamin Patri
    I would bet the IC went bad out of the components above, have you check all of them because the error no doubt is coming because one or more of them went bad and may not just be an audio error then.
  • Benjamin Patri
    Benjamin Patri Apr 24, 2008
    10 blinks means "HV Protection" and the probable cause locations listed are as follows:
    1. Q8014 or Q8013 have shorted, replace along with R8051 on D board.
    2. IC8005 is damaged (D board).
    These are starting points for qualified service technicians.
  • Benjamin Patri
    Benjamin Patri Apr 29, 2008
    Please don't forget to rate this solution as that is one of the biggest aspects of all this website works
    otherwise please let me know if you have further questions
    Thank you
    Genius:
  • 3,587 Answers
Sounds like they are blown again. You have bad power there, by chance?
  • Patrick Michaels
    Patrick Michaels Apr 23, 2008
    replace the diodes and put a line conditioner in line with power outlet to the unit
TV turns red,shuts off, stand-by light blinking 8Times
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Feb 27, 2014 | Sony KP-51HW40 51" Rear Projection...
Sony wega 51" standby light is blinking 5 times repeatedly. what is this code for?
The picture tube is getting close to failure. Has the picture tube been replaced before? If it hasn't it is probably about due the Vegas were great long lasting T.V. sets but after about 15 years need a new picture tube.
Jan 15, 2013 | Sony Grand WEGA KDP-51WS550 51" Rear...
I have a sony 52" rear projection tv red light
I will need the model number to assist if its the KP51WS520 the 9 blinks is zero cross diodes on the g board.
Aug 02, 2011 | Sony Televison & Video
Sony KDS60R2000 Bravia SXRD Full HD - No picture after its switched on. Green light blinking but no picture. Since it was bought (new about 4 years ago) it would occasionly just "switch off" by...
It is time for new lamp in tv as existing has reached on end of its working life.
Replace lamp in tv to fix the problem, lamp replacement procedure is easy and would be written in user manual.
Please buy Sony original lamp for good picture in tv.
Thanks.
Nov 05, 2010 | Sony KDSR50XBR1 50" Projection HDTV
Red stand by light blinks 8 or 9 times and no picture or sound
hello Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
shaun
Oct 18, 2009 | Sony KP-51WS510 51" Rear Projection...
Sxrd rear projection standby light blinking 4 times. I unplugged tv and when I turn it back on,it comes on for about 5 sec then goes off and red light blinks 4 times. Changed bulb about 2 months ago. And...
check the bulb door and make sure its closed all the way. be sure the bulb is firmly pushed into its socket. if the problem is still there you may need to repair the power supply board.
Jun 17, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
9 red blinks
Can you verify that its 9 blinks? There is no error code in that set for 9. also please verify that its a kdsr50xbr1
Thanks
Tim
Jun 29, 2008 | Sony KDS-R50XBR1 50" HDTV
Sony KDS-R50XBR1 9 red blinks
Isn't that the idicator telling you that its time to change the dlp lamp?
Jun 28, 2008 | Sony KDS-R50XBR1 50" HDTV
20" Trinitron Wega
Good day.
First, Have your tv 's circuitry be resoldered. this might be a case of loose contacts particularly along the crt circuitry. the longer you operate the unit at this condition, the faster you are counting the possibility of shortening the lifespan of your tube. 9 years is quite a young age for a unit which has an average of 18years.
response is highly appreciated.
chris
Mar 29, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony KP-51WS520 51" Rear Projection HDTV-Ready Television Logo
258 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
