Question about Motorola Mobility H700 Wireless Headset
How do get the pin for my h700 to pair up w/ my m 300 phone
Plkease help
  • mike winston Apr 25, 2008
    how do I get the pin for my H700 Bluetooth Device?
  • Anonymous Apr 26, 2008
    i have forgot the code and not able to connect my blue tooth with my phone
Pin is 0000
Posted on Apr 25, 2008
I need to know the bluetooth pairing code for sanyo M1
Well I know for sure the default pin for the M1 is indeed 0000. However I cannot tell you what the pin would be for your specific bluetooth dongle. If I where you I would try 0000, 1111, 2222 and so on
  • As with all Bluetooth headsets, the H700 needs to be paired with the device before it can be used, which is done in pairing mode. In pairing mode, the H700 makes a transmission so that Bluetooth-enabled devices can pick up the device and connect to the headset. Once connected, no other device can connect with the Bluetooth headset. To enter pairing mode on the H700, open the headset boom located near the microphone. After a few seconds the indicator light will turn purple. Once purple, the H700 is in pairing mode.
Searching for the Device With the M1
  • Once the H700 is in pairing mode, have the M1 search for Bluetooth devices. To do this, press "MENU/OK" and choose "Tools," "Bluetooth," "Add New" and "Search." A list of Bluetooth devices will show up on the screen. Highlight "Motorola H700" and press "MENU/OK." Choose "Add to Trusted," enter "0000" and press "MENU/OK." The devices are now connected and ready to be tested.
Testing the Devices
  • Once the devices are connected, test that both the phone and the headset are working properly together. First, place the headset in your ear. Dial a number on the phone and press "Send." If you can hear ringing, the devices are connected properly and ready for use.
    If the connection was not successful, repeat the previous steps and try again. Make sure the indicator light is glowing purple and is steady. If you have connected the headset to a previous device, make sure that device is turned off so as not to interfere with the connection procedure. Once the other device is off, close and reopen the boom to enter pairing mode.
Feb 16, 2012 | Sanyo Cell Phones
Can pair my h700 w my bberry storm
Hold down the connect button on headset until steady purple light comes on, then open the boom.
Search for Bluetooth devices on the phone. When asked for a pin, use "0000". Now the H700 will show up in the Bluetooth device list, but it will not connect. Put the headset in pairing mode again, this time go to the h700 listed on the phone and select connect. Now the devices will work as normal. When you open the boom on the h700, it will connect to the phone.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Jul 16, 2009 | Motorola Mobility H700 Wireless Headset
I have a blackberry storm and im trying to pair my bluetooth h700 with it. it found the headset but it keeps saying connection successful the 2 seconds later itll say connection terminated. all my...
Jan 18, 2009 | Motorola Mobility H700 Wireless Headset
Motorola H700 won't pair with LG CU720 phone
You will need to enter pairing mode on your device. The H700 User Manual indicates that you do so by first turning off any previously paired device and opening the headset BOOM. The indicator light should light a steady purple while in pairing mode.
You may not need to turn off your phone if you do not desire this, you may be able to get by turning the blue tooth function off and on, on your phone and attempt to pair again.
Pairing Pin is likely 0000.
Dec 29, 2008 | Motorola Mobility H700 Wireless Headset
H-700 motorolla bluetooth
1. Bluetooth enabled?
Dec 19, 2008 | Motorola Mobility H500 Wireless Headset
Motorola H700 Bluetooth Headset
The password is on the H700 and can't be changed. It is 0000 (that is 4 zeros).
May 24, 2008 | Motorola Mobility H700 Wireless Headset
Is H700 compatible with the iPhone?
Here is a straightforward procedure to "pair" the Motorola H700 bluetooth headset with an iphone
1. Turn off the headset by folding the microphone.
2. On your iphone, go to settings-->General-->Bluetooth-->tap tp turn ON
3. To activate your headset, hold down the center button and keep it pressed while you fold out the microphone.
The iphone will immediately detect the device and state "not paiired"
Ignore this message and go ahead and tap on the headset menu displayed on th eipjone screen. You will e prompted fot a security code. Please enter 0000. The iphone will confirm that the devices have een paired successfully.
You arer done! To verify, try placing a call from the iphone and you will see a new menu on iphone asking you to choose the headset H700 or speaker phone.
Step 3 is the most important step in getting the two devices to talk.
Apr 23, 2008 | Motorola Mobility H700 Wireless Headset
Pairing h700 to sanyo s1
After your phone has found the H700 you have to tell your phone to pair with it. It will then ask for the code. Punch in 0000 and confirm. After a little bit the H700 will flash blue several times rapidly and then start blinking about every 5 or 6 seconds. It is then paired with your phone.
Apr 21, 2008 | Motorola Mobility H700 Wireless Headset
Pin code
set up your phone to search for BT devices, press and hold the phone button on your Skywing or H700, once the purple light comes on open the boom. Your phone should see the device. When prompted for a passcode enter 4 zeros, if that doesn't work, try 5 zeros, if still no luck try 1234 and 12345
Oct 29, 2007 | Motorola Mobility H700 Wireless Headset
How to do pairing
Thank you. I called a 1-800 number for tech support but they told me I had to wait 14 days from the date of purchase before they could help me. Your suggestion was right on the money. Thank you.
Jul 18, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
23 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
