Question about Microsoft Xbox 360 Console
PC Selected test failed
WHen I go to test media connection every test is confirmed except the PC selected test. It says I have to leave the screen up while I go to it and install the software. Well my ethernet is plugged into my modem so when I pull the ethernet cord out to put in my internet cord the screen on my Xbox goes away. So I cannot go to the website and have the screen up. Please help what should I do?
  • 1 more comment
  • AK 47 Apr 23, 2008
    It has always worked fine with no problems until that update is over. I play COD4 and it says I need a connection or something like that to play systemlink or game matches.
    But when I go to COD4 it won't let me play cause I need like connection or something yet all my tests pass.. What should I do now? I do not use music or anything like that just games.
  • Anonymous Feb 19, 2009
    on the test connection screen it says everything is working fine except my pc selected i dont know what it means
    Problem Solver:
  • 8 Answers
Hi i had this problem so i went to wireless but my m8 just had the same but it does not matter if it comes up or not it will still wrk all it means is that u can not tranfer any music or anything like that m8 so no need to worrie
Posted on Apr 23, 2008
How to connect roku stick with wireless network
I went over to the RoKu, it took me to the language screen, selected English then took me to the Welcome screen and the to internet screen to set up Wi-Fi and then scan for network. I selected the network and insert the network password and started scanning the wireless network and then fails, "Can't connect to your wireless network. (error 14.
Aug 02, 2014 | Roku Streaming Stick
When i connect the projector to my computer, all it says is no input selected. i need help with this IMMEDIATELY!!!
make sure the computer has the output screen signal enabled on the external rgb connector. you can confirm this by connecting an external lcd monitor to the pc. swap the pc vga output to the projector.
then make sure the vga/rgb input source is selected on the projector.
also select the lowest resolution on the pc to start with. when a picture appears on the projector, then increase the pc screen resolution until it says it's not able to show it, and back off to the last setting that worked
Apr 13, 2011 | ASK Proxima Office Equipment & Supplies
When I turn the computer on, I get the following message: PXE-E61 media test failure, check cable PXE-M0F exiting intel boot agent Reboot and select proper boot device or insert boot media in selected...
This happens when the BIOS can't find the hard disk. If you're lucky it's just the hard disk that has failed, if you're not it's the motherboard itself the one that failed.
To find out which replace the hard disk with a good one then try to boot in th BIOS - if you can it's the hard disk, if you can't it's the motherboard.
Nov 26, 2010 | Gateway 510 X (10272197) PC Desktop
Error message says PXE-E61:media test failure check cable. PXE-M0F:exiting broad com PXErom. Reboot and select proper boot device or insert boot media in selected boot device and press any key.
PXE errors occur when the system attempts to boot to the network adapter and it fails to find a bootable network connection. In most systems, this is due to the hard drive not being detected in the system. So, reseat the HDD and ensure it is seen in the BIOS. If it is not seen in the bios then it has most likely failed and needs replacement.
Nov 03, 2009 | Computers & Internet
Compaq Presario V4215EA won't boot, switches off by self
sorry dude, this seems like a prone problem on your own PC, this is what you do lete a PC engineer check it out. or if it is still on waranty return it. good luck
Aug 28, 2009 | Compaq Presario V4000 Notebook
Ihave alexmark printer and coper iam trying to put it on my new acer computer it downloads it from the disk except for no icon so it wont astart up hw
Please install the Lexmark printer on Windows XP using the "Add Printer Wizard" by following the steps given below:
1. Go to "Start," "Control Panel" and "Printers and Faxes."
2. Click on "Add Printer" and then click "Next."
3. Select "Local Printer" and then click "Next."
4. Select the required Port (USB001 Virtual Printer Port if the printer has already been connected) and click "Next."
Note: If the printer has not been connected, select "File."
5. Click the "Have Disk" button.
6. When the "Install From Disk" screen appears, click "Browse."
7. From the "Locate File" screen, in the "Look In" option, select "Drivers."
8. Click "Open" and then click "OK" in the next screen.
9. When the name Lexmark printer is displayed, click "Next."
10. Leave the name as Lexmark printer and choose whether or not you want the printer to be the default.
11. Indicate whether or not you want to print a "Test Page."
Note: This is the "Windows Test Page." It won't be printed before the cartridges are selected.
12. Click on "Finish." The printer files will then start to copy from the CD.
13. Please follow the on-screen instructions to finish installing the printer.
your's tech expert
Jeeth
Apr 21, 2009 | Lexmark X1270 All-In-One InkJet Printer
Pc with xbox problem
When you get to the Market place scroll down with your D-pad and stop on Redeem Code, insert the code info from your new card, select the profile you want to associate it with and that should update your account with your new paid subscription.
Aug 27, 2008 | Microsoft Xbox 360 Console
I cant get my ps3 to work with my wireless broadband
Settings > Network Settings > Internet Connection Settings (wireless connection)
Internet Connection Settings (wireless connection) This setting is available only on PS3™ systems that are equipped with the wireless LAN feature.
Set the method for connecting the system to the Internet. Internet connection settings vary depending on the network environment and the devices in use. The following procedure describes a typical setup when connecting to the Internet wirelessly.
1.
Check that the settings for the access point have been completed.
Check that there is an access point connected to a network with Internet service near the system. Settings for the access point are typically set using a PC. For details, contact the person who set up or maintains the access point.
2.
Confirm that an Ethernet cable is not connected to the PS3™ system.
3.
Select in_networkset.gif (Network Settings) under in_setting.gif (Settings) in the home menu.
4.
Select [Internet Connection Settings].
Select [Yes] when a confirmation screen is displayed stating that you will be disconnected from the Internet.
5.
Select [Easy].
connectwired002.jpg 6.
Select [Wireless].
connectwireless001.jpg 7.
Select [Scan].
A list of access points within the range of the PS3™ system is displayed.
Depending on the model of PS3™ system in use, you may have the option [Automatic]. Select [Automatic] when using an access point that supports automatic setup. If you follow the on-screen instructions, the necessary settings will be completed automatically. For information on access points that support automatic setup, contact your local retailer.
connectwireless002.jpg 8.
Select the access point that you want to use.
An "SSID" is an identification name assigned to an access point. If you do not know which SSID you should use or if an SSID is not displayed, contact the person who set up or maintains the access point for assistance.
connectwireless003.jpg 9.
Check the SSID for the access point.
10.
Select the security settings that you want to use.
The types of security settings vary depending on the access point. Contact the person who set up or maintains the access point for information on which setting to select.
connectwireless004.jpg 11.
Enter the encryption key.
The encryption key is displayed as a series of [*]. If you do not know the encryption key, contact the person who set up or maintains the access point for assistance.
connectwireless005.jpg When you have finished entering the encryption key and have confirmed the network configuration, a list of settings will be displayed.
Depending on the network environment, additional settings for PPPoE, proxy server or IP address may be required. For details on these settings, refer to the information from your Internet service provider or the instructions supplied with the network device.
12.
Save your settings.
13.
Test the connection.
If you select [Test Connection], the system will attempt to connect to the Internet.
14.
Confirm the connection test results.
If a successful connection has been made, information on the network will be displayed.
Hints
  • If the connection fails, follow the on-screen instructions to check your settings. Also refer to the information from your Internet service provider and the instructions supplied with the network device in use.
  • If you test the connection immediately after selecting [Automatic] > [AOSS™] in step 7, the router settings may not be completed and the connection may fail. Wait approximately 1 or 2 minutes before testing the connection.
Mar 12, 2008 | Computers & Internet
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
